kobonline
I'm Getting Random BSOD.
Sometimes its a couple minutes apart, sometimes it might be days apart.
I'm a noob, so i'm not very descriptive.
Here is the info.
Thanks.
Kobonline
cpu-z-spd.webpView attachment 2 minidumps.zip
kobonline
My specs are
CPU = Intel Pentium E6500 Socket 775 LGA @2.93ghz
Motherboard = ASUS P5KPL-CM
BIO = American Megatrends
Memory = 4gb DDR2 400mhz
Video = NVidia GeForce 9400 GTT
cybercore
Hello and Happy New Year. : )
The memory timings are set right, thank you for attaching. : )
Uninstall ZoneAlarm and enjoy:
Link Removed due to 404 Error
If crashes persist, uninstall Avast too and install MSE as the replacement:
Uninstall Daemon Tools:
A few days later when bsods are gone, install DT latest version:
Downloads :: DAEMON-Tools.cc
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\123110-23181-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02a4d000 PsLoadedModuleList = 0xfffff800`02c8ae50
Debug session time: Fri Dec 31 23:30:13.999 2010 (UTC - 5:00)
System Uptime: 0 days 0:05:35.684
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 7F, {8, 80050031, 406f8, fffff80002ac2d91}
Probably caused by : NETIO.SYS ( NETIO!CompareSecurityContexts+6a )
Followup: MachineOwner
1: kd> !analyze -v
UNEXPECTED_KERNEL_MODE_TRAP (7f)
This means a trap occurred in kernel mode, and it's a trap of a kind
that the kernel isn't allowed to have/catch (bound trap) or that
is always instant death (double fault).  The first number in the
bugcheck params is the number of the trap (8 = double fault, etc)
Consult an Intel x86 family manual to learn more about what these
traps are. Here is a *portion* of those codes:
If kv shows a taskGate
        use .tss on the part before the colon, then kv.
Else if kv shows a trapframe
        use .trap on that value
Else
        .trap on the appropriate frame will show where the trap was taken
        (on x86, this will be the ebp that goes with the procedure KiTrap)
Endif
kb will then show the corrected stack.
Arguments:
Arg1: 0000000000000008, EXCEPTION_DOUBLE_FAULT
Arg2: 0000000080050031
Arg3: 00000000000406f8
Arg4: fffff80002ac2d91
Debugging Details:
BUGCHECK_STR:  0x7f_8
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from fffff80002abcca9 to fffff80002abd740
STACK_TEXT:
fffff880`009eec68 fffff800`02abcca9 : 00000000`0000007f 00000000`00000008 00000000`80050031 00000000`000406f8 : nt!KeBugCheckEx
fffff880`009eec70 fffff800`02abb172 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff880`009eedb0 fffff800`02ac2d91 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDoubleFaultAbort+0xb2
fffff880`06b91fb0 fffff800`02a85f6a : fffffa80`073ab940 00000000`00000001 00000000`00000000 fffffa80`04bfb068 : nt!SeAccessCheckWithHint+0x301
fffff880`06b92090 fffff880`0177cc5a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!SeAccessCheckFromState+0x102
fffff880`06b92780 fffff880`0177a94f : 00000000`c0000022 00000000`00000000 00000000`00000000 00000000`00000000 : NETIO!CompareSecurityContexts+0x6a
fffff880`06b927f0 fffff880`0177c9b5 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : NETIO!MatchValues+0xef
fffff880`06b92840 fffff880`0177c845 : fffffa80`05043160 fffffa80`07308120 fffff880`06b92a68 fffff880`06b931a0 : NETIO!FilterMatch+0x95
fffff880`06b92890 fffff880`0177dccb : 00000000`00000000 00000000`00000000 fffff880`06b931a0 fffff880`06b92a50 : NETIO!IndexListClassify+0x69
fffff880`06b92910 fffff880`0183f417 : fffff880`06b92de8 fffff880`06b92de8 fffff880`06b93b20 fffffa80`06c44d50 : NETIO!KfdClassify+0xa4e
fffff880`06b92c80 fffff880`0183883e : fffff880`01947690 00000000`00000000 fffffa80`068d6db0 00000000`00000000 : tcpip!WfpAleClassify+0x57
fffff880`06b92cc0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : tcpip!WfpAlepAuthorizeSend+0x94e
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff880`0177cc5a 448b442470      mov     r8d,dword ptr [rsp+70h]
SYMBOL_STACK_INDEX:  5
SYMBOL_NAME:  NETIO!CompareSecurityContexts+6a
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: NETIO
IMAGE_NAME:  NETIO.SYS
DEBUG_FLR_IMAGE_TIMESTAMP:  4bbe946f
FAILURE_BUCKET_ID:  X64_0x7f_8_NETIO!CompareSecurityContexts+6a
Loading Dump File [F:\a\Minidump\D M P\DMP\123110-24367-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02a0a000 PsLoadedModuleList = 0xfffff800`02c47e50
Debug session time: Fri Dec 31 23:42:12.784 2010 (UTC - 5:00)
System Uptime: 0 days 0:10:55.470
BugCheck 7F, {8, 80050031, 406f8, fffff80002a7fd91}
0: kd> !analyze -v
Else
Endif
Arguments:
Arg4: fffff80002a7fd91
Debugging Details:
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from fffff80002a79ca9 to fffff80002a7a740
STACK_TEXT:
fffff800`041a0d28 fffff800`02a79ca9 : 00000000`0000007f 00000000`00000008 00000000`80050031 00000000`000406f8 : nt!KeBugCheckEx
fffff800`041a0d30 fffff800`02a78172 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff800`041a0e70 fffff800`02a7fd91 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDoubleFaultAbort+0xb2
fffff880`08ad7fb0 fffff800`02a42f6a : fffffa80`0735f940 00000000`00000001 00000000`00000000 fffffa80`04bfe068 : nt!SeAccessCheckWithHint+0x301
fffff880`08ad8090 fffff880`01782c5a : ff146a84`ff146a84 ff146a84`ff146a84 ff146a84`ff146a84 ff146a84`ff146a84 : nt!SeAccessCheckFromState+0x102
fffff880`08ad8780 fffff880`0178094f : ff146a84`c0000022 ff146a84`00000000 ff146b84`ff146a84 ff146b84`ff146b84 : NETIO!CompareSecurityContexts+0x6a
fffff880`08ad87f0 fffff880`017829b5 : ff146b84`ff146b84 ff146b84`ff146b84 ff146b84`ff146b84 ff146b84`ff146b84 : NETIO!MatchValues+0xef
fffff880`08ad8840 fffff880`01782845 : fffffa80`06133370 fffffa80`073a5290 fffff880`08ad8a68 fffff880`08ad91a0 : NETIO!FilterMatch+0x95
fffff880`08ad8890 fffff880`01783ccb : 00000000`00000000 00000000`00000000 fffff880`08ad91a0 fffff880`08ad8a50 : NETIO!IndexListClassify+0x69
fffff880`08ad8910 fffff880`01840417 : fffff880`08ad8de8 fffff880`08ad8de8 fffff880`08ad9b20 fffffa80`045a4d50 : NETIO!KfdClassify+0xa4e
fffff880`08ad8c80 fffff880`0183983e : fffff880`01948690 00000000`00000000 fffffa80`06988720 00000000`00000000 : tcpip!WfpAleClassify+0x57
fffff880`08ad8cc0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : tcpip!WfpAlepAuthorizeSend+0x94e
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff880`01782c5a 448b442470      mov     r8d,dword ptr [rsp+70h]
MODULE_NAME: NETIO
Drivers:
fffff880`03c00000 fffff880`03c3e000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`0116f000 fffff880`011c6000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`040af000 fffff880`040b8000   Afc      Afc.sys      Wed Jul 12 01:48:20 2006 (44B48D24)
fffff880`02e8d000 fffff880`02f17000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`040d5000 fffff880`040eb000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`00ea9000 fffff880`00eb4000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`1008a000 fffff880`10092000   ASACPI   ASACPI.sys   Wed Jul 15 23:31:29 2009 (4A5E9F11)
fffff880`054b1000 fffff880`054ba000   aswFsBlk aswFsBlk.SYS Tue Sep 07 10:47:09 2010 (4C86506D)
fffff880`05477000 fffff880`054b1000   aswMonFlt aswMonFlt.sys Tue Sep 07 10:47:32 2010 (4C865084)
fffff880`02f17000 fffff880`02f21000   aswRdr   aswRdr.SYS   Tue Sep 07 10:47:47 2010 (4C865093)
fffff880`00dd5000 fffff880`00df8000   aswSP    aswSP.SYS    Tue Sep 07 10:52:07 2010 (4C865197)
fffff880`01bcc000 fffff880`01bdc000   aswTdi   aswTdi.SYS   Tue Sep 07 10:52:27 2010 (4C8651AB)
fffff880`067bd000 fffff880`067c8000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00e76000 fffff880`00e7f000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00e7f000 fffff880`00ea9000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff960`00890000 fffff960`008f1000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`10043000 fffff880`10046e80   BdaSup   BdaSup.SYS   Mon Jul 13 20:06:40 2009 (4A5BCC10)
fffff880`01b20000 fffff880`01b27000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`015ee000 fffff880`015ff000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`0592e000 fffff880`0594c000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff880`00fda000 fffff880`00fee000   CBDisk   CBDisk.sys   Wed Jan 13 04:15:47 2010 (4B4D8F43)
fffff960`00770000 fffff960`00797000   cdd      cdd.dll      unavailable (00000000)
fffff880`01aed000 fffff880`01b17000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cc9000 fffff880`00d89000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01a87000 fffff880`01ab7000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c6b000 fffff880`00cc9000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0154a000 fffff880`015bd000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`040c5000 fffff880`040d5000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`067ce000 fffff880`067d7000   cpuz135_x64 cpuz135_x64.sys Tue Nov 09 08:33:36 2010 (4CD94DB0)
fffff880`041f1000 fffff880`041ff000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`10d97000 fffff880`10df3780   cxpl_ctx cxpl_ctx.sys Thu Apr 17 20:55:59 2008 (4807F19F)
fffff880`01bdc000 fffff880`01bfa000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`01a68000 fffff880`01a77000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`015d8000 fffff880`015ee000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05568000 fffff880`0558a000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`03df0000 fffff880`03df9000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`10df4000 fffff880`10e00000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01ad8000 fffff880`01aeb000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`0558a000 fffff880`05596000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`03c89000 fffff880`03d7d000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`10d2d000 fffff880`10d73000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`1007d000 fffff880`1008a000   fdc      fdc.sys      Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`00eb4000 fffff880`00ec8000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`0405a000 fffff880`04065000   flpydisk flpydisk.sys Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`00d89000 fffff880`00dd5000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`015ce000 fffff880`015d8000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01486000 fffff880`014c0000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0162b000 fffff880`01675000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`040b8000 fffff880`040c5000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`02fe6000 fffff800`0302f000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`10d73000 fffff880`10d97000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`054cf000 fffff880`0552b000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`055b2000 fffff880`055cb000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`055cb000 fffff880`055d3080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`055a4000 fffff880`055b2000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`05866000 fffff880`0592e000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`0167d000 fffff880`01686000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`04067000 fffff880`04085000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`011f2000 fffff880`011fa000   intelide intelide.sys Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03c73000 fffff880`03c89000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`0585b000 fffff880`05866000   ISWKL    ISWKL.sys    Wed May 26 09:21:13 2010 (4BFD2049)
fffff880`04085000 fffff880`04094000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00ba4000 fffff800`00bae000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`10000000 fffff880`10043000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`01530000 fffff880`0154a000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01600000 fffff880`0162b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`10047000 fffff880`1004c200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`1004d000 fffff880`1005f000   L1E62x64 L1E62x64.sys Sun Mar 28 22:08:44 2010 (4BB00BAC)
fffff880`0582e000 fffff880`05843000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`05454000 fffff880`05477000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`041a0000 fffff880`041dc880   mcdbus   mcdbus.sys   Tue Feb 24 05:34:07 2009 (49A3CD1F)
fffff880`00c13000 fffff880`00c57000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`013a4000 fffff880`013f9000   MDFSYSNT MDFSYSNT.sys Tue May 18 10:07:22 2010 (4BF29F1A)
fffff880`017ee000 fffff880`017fb000   MDPMGRNT MDPMGRNT.SYS Wed May 05 10:38:13 2010 (4BE182D5)
fffff880`05596000 fffff880`055a4000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04094000 fffff880`040a3000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`055d6000 fffff880`055e3000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00e5c000 fffff880`00e76000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0594c000 fffff880`05964000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`05964000 fffff880`05991000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`05991000 fffff880`059df000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`05800000 fffff880`05823000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`01b85000 fffff880`01b90000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`011c6000 fffff880`011d0000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`067cc000 fffff880`067cdc00   MSPCLOCK MSPCLOCK.sys Mon Jul 13 20:00:17 2009 (4A5BCA91)
fffff880`067c8000 fffff880`067c9a80   MSPQM    MSPQM.sys    Mon Jul 13 20:00:17 2009 (4A5BCA91)
fffff880`014d2000 fffff880`01530000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`01a5d000 fffff880`01a68000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`067ca000 fffff880`067cbf80   MSTEE    MSTEE.sys    Mon Jul 13 20:00:17 2009 (4A5BCA91)
fffff880`017dc000 fffff880`017ee000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0168a000 fffff880`0177c000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0410f000 fffff880`0411b000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`0411b000 fffff880`0414a000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`054ba000 fffff880`054cf000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02e2f000 fffff880`02e3e000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02f21000 fffff880`02f66000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`0177c000 fffff880`017dc000   NETIO    NETIO.SYS    Thu Apr 08 22:43:59 2010 (4BBE946F)
fffff880`01b90000 fffff880`01ba1000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01a51000 fffff880`01a5d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02a0a000 fffff800`02fe6000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`01201000 fffff880`013a4000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`01b17000 fffff880`01b20000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`10d2b000 fffff880`10d2c180   nvBridge nvBridge.kmd Fri Jul 09 17:07:54 2010 (4C378FAA)
fffff880`10099000 fffff880`10d2ae00   nvlddmkm nvlddmkm.sys Fri Jul 09 17:15:58 2010 (4C37918E)
fffff880`02e09000 fffff880`02e2f000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`03dd3000 fffff880`03df0000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`011dd000 fffff880`011f2000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f86000 fffff880`00fb9000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`01000000 fffff880`01010000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`015bd000 fffff880`015ce000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`0626f000 fffff880`06315000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0552b000 fffff880`05568000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c57000 fffff880`00c6b000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`00fce000 fffff880`00fd9e00   PxHlpa64 PxHlpa64.sys Tue Jun 23 19:16:35 2009 (4A416253)
fffff880`040eb000 fffff880`0410f000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0414a000 fffff880`04165000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`04165000 fffff880`04186000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04186000 fffff880`041a0000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`01a00000 fffff880`01a51000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`01b6a000 fffff880`01b73000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01b73000 fffff880`01b7c000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01b7c000 fffff880`01b85000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0144c000 fffff880`01486000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`05843000 fffff880`0585b000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`01140000 fffff880`0116f000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`06315000 fffff880`06320000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`040a3000 fffff880`040af000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02e3e000 fffff880`02e5b000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`01675000 fffff880`0167d000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`01011000 fffff880`01137000   sptd     sptd.sys     Sun Oct 11 16:55:14 2009 (4AD24632)
fffff880`0667b000 fffff880`06711000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`0635f000 fffff880`063c6000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`06320000 fffff880`0634d000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`041dd000 fffff880`041de480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01803000 fffff880`01a00000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`0634d000 fffff880`0635f000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`01bbf000 fffff880`01bcc000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`01ba1000 fffff880`01bbf000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02e76000 fffff880`02e8a000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00450000 fffff960`0045a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`03c4d000 fffff880`03c73000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`05400000 fffff880`05454000   udfs     udfs.sys     Mon Jul 13 19:23:37 2009 (4A5BC1F9)
fffff880`041df000 fffff880`041f1000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`067b3000 fffff880`067bd000   umpass   umpass.sys   Mon Jul 13 20:06:52 2009 (4A5BCC1C)
fffff880`055d4000 fffff880`055d5f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`1006c000 fffff880`1007d000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04000000 fffff880`0405a000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`03d7d000 fffff880`03dd3000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`055e3000 fffff880`055fe000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`1005f000 fffff880`1006c000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`011d0000 fffff880`011dd000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01b27000 fffff880`01b35000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01b35000 fffff880`01b5a000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00fb9000 fffff880`00fce000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01400000 fffff880`0144c000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02f66000 fffff880`02ffb000   vsdatant vsdatant.sys Sun May 09 12:28:58 2010 (4BE6E2CA)
fffff880`02e5b000 fffff880`02e76000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`01b5a000 fffff880`01b6a000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00ed3000 fffff880`00f77000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f77000 fffff880`00f86000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02e00000 fffff880`02e09000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00070000 fffff960`00380000   win32k   win32k.sys   unavailable (00000000)
fffff880`01137000 fffff880`01140000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`01ab7000 fffff880`01ad8000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`06711000 fffff880`06742000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`06742000 fffff880`067b3000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01ab7000 fffff880`01ac5000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01ac5000 fffff880`01ad1000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01ad1000 fffff880`01ada000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01ada000 fffff880`01aed000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
kobonline
Just uninstalled Zone Alarm, and no BSOD in 3 hours so far. Thanks and I will continue to monitor and update you on my situation and follow instruction accordingly.
One Question though....
Why would a firewall like Zone Alarm and or Avast cause an error like this?
Aren't these apps supposed to relatively safe for your computer? Aren't they supposed to help, not hurt?
Kobonline
cybercore
It's how they use system resources. ZA does not work well with Avast alongside.
