ljcap
I have done a clean install onto a Acer Aspire M1610 (Celeron) desktop computer using Windows 7 (32 bit). I'm getting the dreaded "Windows did not detect a properly installed network adaptor. If you have a network adapter, you will need to reinstall the driver."
I have only moved house recently and the drivers that came with the computer could be anywhere. :confused:
I am having problems locating the correct ethernet controller for this computer. After getting into the BIOS, the motherboard details are as follows;
Mainboard ID: F672CR
Bios Version: 6.00PG
Bios ID: R01-A3
I have gone into the Device Manager which has a mark against the ethernet controller. I have uninstalled and rebooted and it still comes up with the same problem. I have also tried using a Netgear WG111 wireless USB reader instead and it still won't connect. Comes up with a compatibility issue even when I choose VISTA in Troubleshoot Compatibility.
Any assistance would be greatly appreciated. I have sent an email to Acer Australia and I'm awaiting a reply (I don't hold too much hope of a descent reply).
Cheers
Laurie
Thanks , but sorry,
just b4u sent this , i just got connected, i downloaded the Sis 900 driver for the ethernet connection, it works, Thank you so much!!!! . ;):redface::D
hammydown
Go to this page and go down to the Windows VISTA SP1 and Choose LAN Driver. See if that works.
ljcap
Something doesn't seem right there. I downloaded the 16kb file and tried running the zip file. I got the message "Please insert the last disk of the Multi-Volume set and click OK to cintinue".
It's got me there.........
Cheers
Laurie
hammydown
The file was 3.7mb not 16 kb. Look at the attached image for the appropriate driver to download.
ljcap
Yep, that's the one, I click SAVE and it's 16kb in size and takes 1 sec to download. I'm going to reboot the computer and try again but I don't think that will change anything.
Cheers
Laurie
ljcap
You are a legend. Installed, rebooted and all is good.
I can't thank you enough. 2 days I've been trying to get that to work.
All the best.
Cheers
Laurie
Sean9895
Windows7 Ethernet controler prbolems
Hi thanks for reading this, I have a problem, ijust got windows 7 today and I can't connect to the Internet , I had xp yesterday,connects no problem the other two pc's in the house connect fine, even the xbox360...... So I went to control panel, device manager, ilooked down and I saw Ethernet controller withe a yellow triangle and a !, so I scaned my c drive to see if there was a driver it found , SiS900 - based pci fast Ethernet adapter, nut it encounters an error when installing, my mo is - k7s41gx. Thanks if you can help me and I really need help
I did a little googling and some have had success using that driver with win 7. (As your probably aware the last driver release was for xp only)
Download the driver from here: Link Removed - Invalid URL
Before you install it though, rightclick on the start up exe and choose properties. Then look along the top for compatibility and change it for xp. Let me know how you get on..
Sean9895
Thanks , but sorry,
