TheUnknown
3-4 day's ago my mic was working perfectly, No background noises just my voice but now my mic records my ingame sound and wen i am pressing key's. Wen i go in recording devices,Properties then click listen to device on my microphone i hear sound on my left ear
I found out the problem, I had to plug it into the back of my computer.
edit:nvm the problem is still here, Look's like wen i plug the mic in the back its fine then after awhile i have to switch to the front. Odd
TheUnknown
