The thread revolves around a user experiencing malware or adware issues on their Windows system, likely linked to torrent activities and potentially exposing the system to unwanted content such as adult sites. Multiple contributors suggest various malware removal tools, including Malwarebytes, SuperAntiSpyware, Spybot, and others, to identify and eliminate threats, while others recommend system reimaging or clean installs for severe infections. The overall sentiment emphasizes caution with torrents, thorough malware scanning, and the importance of securing passwords, with the original poster planning to continue testing system upgrades and monitoring for infections.
Saltgrass
I suppose my foray into Torrents ended up causing me a few minor problems. It might be fun to try to remove whatever is actually causing this, but Malware Bytes has found problems prior and these are recent so the problem endures.
If I wanted to try to remove the problem, any suggestions beside Malwarebytes and Defender to attempt to rid the system of this scourge. I found this stuff because I was looking for what was playing an ad on my desktop, which turned out to be a Skype add-on to IE.
Thanks...
An image from 'Anyone think I should rebuild my System !! ;)'. Malwarebytes detected 8 trojans and 2 PUP files for quarantine on a Windows PC.
MikeHawthorne
davehc
WOW. With that lot, I would not even think of cleaning - fresh install. (And keep away from the torrents!!!!!!!)
Trouble
Noob Whisperer
Nice...
Hey Clark, I've seen worse. Maybe give it a go.....
These are the programs I use to generally delouse a computer with virus and or malware issues.
ADWcleaner from here Link Removed
JRT (Junkware Removal Tool) from here http://www.bleepingcomputer.com/download/junkware-removal-tool/dl/131/
Norton Power Eraser from here Link Removed
Malwarebytes from here http://www.malwarebytes.org/mwb-download/confirm/
Ccleaner from here Link Removed
TFC.exe (Temporary Files Cleaner) from here http://www.geekstogo.com/forum/files/file/187-tfc-temp-file-cleaner-by-oldtimer/
ESET Online Scanner from here http://www.eset.com/us/online-scanner/
Eset online scanner is a bit different than the others in that you need to either use
IE or download and run their smart installer if you're using another browser. Then tick
the radio button that says "Enable detection of potentiall unwanted application"
Then click the link that says "Advanced settings", then check all the boxes except the
one that mentions "Use custom proxy settings", unless of course you're using a Proxy
Server. Then just click "Start", it will do a thorough system scan so it takes a long
time.
I don't check the links above everyday, so if you have any problem with any one of them then just Google for the program name but use the site names that I have recommended since I'm relatively certain they are free of extraneous garbage.
OTT
Active Member
Use the programs Trouble recommended and after that use Kaspersky Security Scan.
If that comes back with a clean state all should be fine !
Extra Info :
"winupd.exe" seems to be related to "MSStartOptimizer" and that is related to an "Adult content dialler"...
No torrent involved in that... :blow:
OTT
Saltgrass
Thread Author #6
Ott, this system has not been messing around with any Adult Content sites. But I remember a time last year when I got something like that when I was looking for Truck Parts. During my Torrent experience, I may have clicked on something I should not have...not that familiar with how the torrents work.
I will follow some of the suggestions to see if those utilities find anything. Currently I have run Defender in a Full scan and it did not find anything. Malwarebytes has not found anything the second time.. But rebuilding to a clean install will be on the top of the list if I find more items being installed.
But this got me thinking, since I have been playing with Cortana and Spartan. Cortana asks for permission to have access to your system before it runs. I don't know exactly what or how it accesses the system, but it does open websites, depending on what you ask it to do. I was wondering if it could be used as a conduit for spyware to be placed on your system.
Also, OneDrive is used to sync between computer systems. If one system had been infected, could it be used to transmit malware to another system?
I will post back if the suggested utilizes turn up anything... Thanks.
Saltgrass
Thread Author #7
Well, I tried Mike's Spybot recommendation first and all it found was cookies, none of which showed to be high risk. During the Scan I got a message from something the drive needed to be checked. A reboot resulted in a Blue Screen, so now I am trying the rollback option to see if it even works.
Could just be coincidence or the scanning put extra stress on the drive. None of this is a problem, since all I have to do is reimage, but if I get the system back I will continue with the other suggestions.
Well, the rollback seems to have worked and since this install was an 8.1 upgraded directly to build 10049, it put me back in 8.1.... Another test conducted... 😉
OTT
Active Member
Ott, this system has not been messing around with any Adult Content sites. But I remember a time last year when I got something like that when I was looking for Truck Parts. During my Torrent experience, I may have clicked on something I should not have...not that familiar with how the torrents work...
First and foremost... it was not my intention to accuse you of something ! 😉
Everybody (you or someone else) can click on something that's not what it seems to be...
Second.
To be sure you should run the programs proposed by Trouble and then the Kaspersky Security Scan.
Since it is/was a Trojan (dropper/downloader) you should consider changing your passwords !
OTT
Saltgrass
Thread Author #9
Good idea about changing passwords. I suppose it is good my Windows 8/10 systems are just test systems and I don't use them as primary systems.
Since the problem after Spybot, the situation has basically resolved itself. The rollback to 8.1 seemed to work fine and was much faster than I expected. I am now upgrading to 10049 again to see what happens. I am going to start running Malwarebytes more often to see if I can catch something. I will still assume the Torrent download allowed the bad stuff to invade my system, but not completely sure. The Skype IE Browser Helper Object still has me wondering.
I didn't think you were accusing me of anything, just wanted to point out you can pick up all sorts of things even at sites you might think would be safe. It is also interesting that Defender did not say a peep during the entire situation....
Thanks for the help.
Saltgrass
Thread Author #10
Well, change in plans. Since build 10061 is now available, I will just skip 10049...
MikeHawthorne
Hi
I'm surprised that you had issues with Spybot, it a long established program that goes clear back to Windows 95.
I have it installed now, and use it mostly for the blocking service of identified malicious sites and files.
My main complaint about it was that it was something of a resource hog on my earlier computers.
On my present computer I don't see any slowdown when using it.
I haven't seen any issues running it in Windows 10.
Mike
