In the forum thread, the original poster asks if it's possible to modify their single audio jack to support a headset with both headphones and microphone. A responder suggests using a headphone/microphone combo splitter to connect separate inputs, noting that modifying the jack itself would be complicated and potentially unfeasible without proper connections on the motherboard. The overall solution leans towards using an external splitter rather than hardware modification.
Mason
I have a headphones that have built in Microphone. I was wondering if there was a way to change my audio jack to support the microphone (because my headphones only have one connection to put it in)
I believe what you need is the a Headphone/Microphone Combo Jack Splitter such as this: Link Removed
Then you can use your microphone/speaker jack for each input, as modifying your audio jack to support both would be a pain.. first of all if its not a combo jack it wont have all the connections to your motherboards PCB to carry audio in/out..
Josephur
Windows Forum Admin
