DrScythe
After experiencing an unexplainable Kernel-Power 41 (63) crash at random seemingly unconnected intervals I decided to reformat my HD and start from scratch to try and fix the issue. Unfortunately my problem still exists. My computer hangs and will loop the last 0.1s of audio until I reach for the restart button.
I have updated all my drivers and Bios to their latest versions also all to no success :(
Ive searched multiple other sources online and have tried things like disabling certain windows squeduled tasks and disabling multiple audio devices in the device manager. Nothing has been successful so far. Any help would be much appreciated
My system is
XFX 790i Ultra
Intel 2.83 Quad Core
DDR3 2G stick (Cosair)
Nvidia GTX260
EDIT: Also it shouldn't be my Power supply as i am running an Odin 800W
To both of you users: Welcome to the Windows 7 Forums :D
This honestly sounds like a heat problem. You say these crashes happen during high CPU usage times. Which causes increased temperatures. Any dust at all and the computer could crash. Try removing the cover, and gently cleaning any dust in the fan and other places. Alternatively, you could buy a can of compressed air and just spray it inside the fan louver.
Agent Data
Banned
okay here what is notable:
File Name : explorer.exe
Friendly Name : Windows Explorer
Version : 6.1.7600.16385 (win7_rtm.090713-1255)
Total Time : 9321ms
Degradation Time : 4321ms
"Background optimizations (prefetching) took longer to complete, resulting in a performance degradation in the system start up process:
Total Time : 41613ms
Degradation Time : 9582ms
Incident Time (UTC) : ‎2010‎-‎04‎-‎15T06:22:15.671600000Z"
File Name : hon.exe
Friendly Name : Heroes of Newerth
Version : 0, 1, 54, 0
Total Time : 7081ms
Degradation Time : 2081ms
001 8:31:07 AM Microsoft-Windows-Diagnostics-Performance 203 Shutdown Performance Monitoring "This service caused a delay in the system shutdown process:
File Name : CryptSvc
Friendly Name : Cryptographic Services
Total Time : 5884ms
Degradation Time : 1884ms
File Name : WinDefend
Friendly Name : Service Module
Total Time : 8505ms
Degradation Time : 4505ms
Warning 14/04/2001 3:11:06 AM Microsoft-Windows-Diagnostics-Performance 501 Desktop Window Manager Monitoring "The Desktop Window Manager is experiencing heavy resource contention.
Reason : Graphics subsystem resources are over-utilized.
Diagnosis : A sharp degradation in Desktop Window Manager responsiveness was observed."
Warning 14/04/2001 3:11:06 AM Microsoft-Windows-Diagnostics-Performance 500 Desktop Window Manager Monitoring "The Desktop Window Manager is experiencing heavy resource contention.
Scenario : The Desktop Window Manager responsiveness has degraded."
Warning 14/04/2001 2:13:10 AM Microsoft-Windows-Diagnostics-Performance 500 Desktop Window Manager Monitoring "The Desktop Window Manager is experiencing heavy resource contention.
Scenario : Video memory resources are over-utilized and there is thrashing happening as a result. Reducing number of running programs and open windows may help resolve this condition."
Warning 14/04/2001 1:57:43 AM Microsoft-Windows-Diagnostics-Performance 501 Desktop Window Manager Monitoring "The Desktop Window Manager is experiencing heavy resource contention.
Warning 14/04/2001 1:57:43 AM Microsoft-Windows-Diagnostics-Performance 500 Desktop Window Manager Monitoring "The Desktop Window Manager is experiencing heavy resource contention.
"This application took longer than usual to start up, resulting in a performance degradation in the system startup process:
File Name : msnmsgr.exe
Friendly Name : Windows Live Messenger
Version : 14.0.8089.0726
Total Time : 8939ms
Degradation Time : 3939ms
looks to me you have ram stress - the system overall behaves a bit draggy watch the degradation times > 1 sec (1000ms). Somehow your box is hogging. My suggestions:
1) cleanup ram/background processes
2) make sure latest chipset/hdd/audio drivers are installed
3) video driver got some issues - sweep the driver then reinstall
4) win defender? - install MSE instead
5) Heroes of Newerth seems a hog too
maybe add another 2GB ram for better performance - your system hdd is stressed! Good idea to run a malware checker or once MSE is installed run a full scan.
Broome your box, buddy, then things will improve.
DrScythe
Thanks for that.
Yea i used to have 4Gb of ram in the machine but the second stick died on me. Was gonna replace it when funds allow.
Shouldn't be any malware issues as i reformatted last week.... but will check anyway
All drivers have been updated. Will try uninstall/reinstalling the video card drivers tho.
Will get MSE in a minute as well and scan with that
Yea Heroes of Newerth has a few reported problems with 7 hogging resources. Hopefully theyl fix those issues soon
Will post back with updates after trying some of these suggestions
EDIT: how do i go about cleaning up my ram?.....
DrScythe
Alright im working on lowering my memory usage.
The key things that are standing out to me right now is one of the svchost.exe is using anywhere between 60-100mb or memory. Also MsMpEng.exe which is the process for MSE which i just installed is consuming a whopping 150mb of memory while not in use.
My computer while idling with MSN / Chrome and some system monitors open is using 50% of my 2GB ram. Doesnt exactly leave much room for games and stuff like hon and whatnot to run....
Any strategies for reducing this memory usage?
Agent Data
Banned
Thanks for that.
depending on your experience level go into the task manager/processes tab and see what processes are active probably pointing to old software supposed to be uninstalled (debris)
try to minimise active software to what you really use and uninstall everything you forgot about . remove hogs where possible. skim through Programs & Features (CP) and get rid of everything unnecessary by uninstalling it.
that svchost ~ 100MB belongs to the audio processor if I am not mistaken - it's normal!
MsMpEng.exe here is using ~70MB not sure why it takes double the ram on your box
simple, get more ram! sorry could not resist ;)
you would sail much smoother with 4GB or more ram
Mitchell_A
Former Moderator
Also, the svchost.exe is actly what it says to be: A service host.
It hosts more than half the running services, all with different parameters.
4 GB of RAM would definitely fix that problem.
DrScythe
haha so overall my problem is that im flat broke :(
alright ill look into getting a second stick again soon
maestro
Heat Problem???
I have the failures on startup at times. The system has not started to heat up at that point. It happens when nothing is being done. Very random.
Mitchell_A
Former Moderator
Do you have the MOST up-to-date BIOS?
Check your manufacturers website for the latest update.
DrScythe
Alright despite the fact i cant afford it i went and got two new sticks of ram and took the old one out.
Been running the system for around 24 hours now and no crash yet.
Hopefully it stays that way
Agent Data
Banned
Probably a smart idea to run a repair install to fix up possible data corruptions on the disk - just to be on the safe side.
