The thread discusses an issue where a user’s custom cursor pack stops working after restarting their Windows system, defaulting to the Aero cursor until manually reset. Despite reinstalling the pack, the problem persists, requiring repeated adjustments at each boot. A respondent advises caution with third-party cursor apps and suggests checking the source for possible support or updates. The overall sentiment indicates frustration with the recurring issue and a recommendation to verify the cursor pack's compatibility or support.
andreioniscu
Hi, i installed a custom cursor pack on my system that looks awesome. It worked perfectly, until some days ago. When i boot the computer the mouse is the aero default cursor. If i change the cursor pack to none and then back to the custom one it works, but it's anoying because i have to do this after every boot. I tried reinstalling the cursor pack, no luck.
personally I try not to use apps like these and they usually end up breaking in some way or they break something else on the os. Have you checked the site where you go the pack from, perhaps they have support for their product?
