- Joined
- May 25, 2009
- Messages
- 6,676
- Thread Author
- #1
Hi everyone!
I have been having problems with my internet connection for the last few weeks.
I had to constantly restart it by going into network connections and disabling and re-enabling it.
I always had this when Bonior Services was installed, but I looked and it didn’t show up as installed.
It was driving me buggy.
Well tonight I was looking through running services and there is was “Bonjour Services”!
Only I can’t just uninstall it because it doesn’t show up as installed.
I ran a search, and this is what I found, on another forum, by “Raine”
The only error in this post was the path to the Bonjour folder in Windows 7 which I have corrected.
I ran through this whole process and so far I haven’t had any connection problems.
After 2 years wouldn’t you think that someone would have solved this conflict?
It makes me wonder if this isn’t Apples way of sabotaging Windows 7.
So if you are having problems staying connected and I have seen a number of posts lately from people who have, check this out…
Mike
1. Identify if Bonjour is installed:
From the Start menu, select Control Panel, and then type services. Click on the View local services link in the Administrative Tools group.
If the first line in the list of services looks similar to (I just looked for Bonjour Services and there is was)
##Id_String2.6844F930_1628_4223_B5CC_5BB94B879762##, you have Bonjour on your system.
You may now close the Services window.
2. Open a command prompt with Administrative privileges:
3. Execute the following commands:
cd \Program Files (x86)\Bonjour
mDNSResponder.exe -remove
ren mdnsNSP.dll mdnsNSP.old
4. Finally...
Close the command box and restart the computer, then delete the Bonjour folder from the C:\Program Files (x86) folder.
Chow, Bonjour!
Note from Adobe: Removing Bonjour prevents Version Cue clients (Photoshop, Illustrator, InDesign, Flash, Bridge) from automatically discovering Version Cue Servers and Version Cue projects in your local network. You will need to connect manually using Connect to Server and the URL or IP address of the machine running Version Cue Server instead
Mike
4. Finally...
Chow, Bonjour!
