The thread discusses a user experiencing audio issues after a clean OS installation, specifically with distorted sound when multiple audio sources run simultaneously. Despite installing the appropriate drivers from the motherboard and device manufacturer, Windows repeatedly reinstalls Nvidia HD audio drivers for onboard audio devices that remain visible even after being disabled in BIOS. Other contributors advise reinstalling all necessary drivers from official sources, removing unwanted drivers using uninstallers, and pointing out that certain onboard audio drivers (Realtek) should not be replaced by Nvidia drivers, suggesting the user may have misconfigured or conflicting driver setups. The overall sentiment indicates difficulty resolving driver conflicts and ensuring proper audio device management post-installation.
seekermeister
Honorable Member
Since having done a clean install of the OS, I've been having some problems with audio, which weren't occurring with the old installation. Generally the sound is normal, so long as there is only one app running that uses sound, but say there is a movie playing, and at the same time one is playing Spider Solitaire, the sound became tinny and distorted.
I thought that I had found the solution when Windows popped a message saying that the sound was missing a driver. That seemed odd because the Device Manager shows all sound devices working normally, but I decided to give it a shot anyway. The driver that it led me to was for a C Media Oxygen HD audio device, which I believe is for my Asus sound card, but when I attempted to install it, it squawked that the device for it needed to be installed.
That is when I noticed that in addition to the sound card, there were four HD audio devices listed below it. All 4 of them were using the same driver, which was labeled as a Microsoft driver. It was then it dawned on me that these devices were probably for the onboard sound, rather than the sound card, so I uninstalled them and checked the BIOS where I found that the onboard sound had somehow become enabled. I disabled it and rebooted, but upon reaching desktop, Windows started installing the drivers for HD audio again. However, now instead of Microsoft drivers, they are Nvidia drivers. I suppose that I could disable the devices, but checking in the old Windows installation, none of them appear in the Device Manager. I checked in services, but didn't find anything that looked like it was related to this. Since they are disabled in the BIOS, how could Windows be seeing them?
It seems like you have two audio systems, C-Media Oxygen HD Audio Device from Club 3D, and Xonar D2X, from Asus, the motherboard manufacturer. These two collide. Realtek is hardly the boogie, it works fine with almost all motherboards.
I would suggest that you uninstall everything that has to do with audio, from Control Panel\All Control Panel Items\Programs and Features or with Revo Uninstaller. Then, use the original CD / DVD you got with the motherboard, and install any drivers it shows to be needed. And ONLY update from Asus page. You'll probably find Realtek there.
Hope you get it working. :)
seekermeister
Honorable Member
Thread Author #21
It has has now become clear to me that we are not thinking on the same frequency, and our thoughts and opinions are out of sync. I have never found it necessary to enable or install drivers for an on-board sound system to be able to get quality sound from a quality add-on sound card. My objective is as it has always been, to eliminate all traces of the on-board sound system. Therefore this discussion is going nowhere.
