- Joined
- Aug 28, 2007
- Messages
- 36,160
The other day a friend and I decided to have a game of L4D2 although for some strange reason the game would start but then crash.
Whilst searching for a fix, a solution was found which involved using the System file scanner to repair system files.
The trouble is that with recent builds the SFC has strangely refused to work. This solution however worked for me and may work for you:
Let us know if this worked for you too.
ref:Note: you will need the ISO for build 10041
1. Mount the .ISO file by double clicking on it.
2. Open 'Windows Powershell' or 'Command Prompt' with Admin privileges (right click -> Run as Administrator)
3. Let's check the System Health first, by running these commands:
3.1 dism /online /cleanup-image /scanhealth
3.2 dism /online /cleanup-image /checkhealth
3.3 dism /online /cleanup-image /restorehealth
4. I'm sure that 3.3 will give you an error stating that it could not perform the task. And now it's when the mounted ISO comes into play. Let's specify the file from the ISO so that we can fix it. Run the following command: (Notice that X must be the drive letter on which your system has mounted the ISO)
4.1 DISM /Online /Cleanup-Image /RestoreHealth /source:WIM:X:\Sources\Install.wim:1 /LimitAccess
5. Now let's repair any damage in the system files, shall we?
5.1 Run sfc /scannow in an admin command prompt.
Now it should work for you, guys! I hope this will help. My system seems more responsive since then. Please report if you encounter any problems following these instructions.
I don't know if this solution will work on previous builds such as 9926, but I have the feeling it may.
