Suumpmolk
unfortunately i can't make this post to 1 problem specific...
heres the deal, i was on XP and i waited for 7, now using Home Premium and i like 7 very much
but some things are realy weird and buggy.
i use untouched (final version) installation, it was fresh after format, my pc is well capable for 7, my drivers are for 7,
i got no BSOD's and via NOD32 (was only one i could install to work normal) report is NO viruses + i use firewall (outpost)
no modification was made on ISO which was burned on 7x speed and installs OS inside 25 minutes.
problems:
1. System Restore, i cant even run it, every time i try i get this:
2. svchost has extreme CPU usage, if i kill it via task manager, system starts to act weird and i lose sound reproduction capability, if i run music player or watch movie in movie player, system is choked:
3. When CD/DVD is inserted and i get that splash screen of choices, and select to open folder to view contents,
every so little i get below folder in explorer added task that is on waiting "to burn desktop.ini" on disk
4. some programs (i came to 3 or 4 in last 2 days) after exit stay as process in task manager, they continue
to drain system resources, they cannot be killed via task manager or cmd taskkill, sysinternals pskill or process explorer,
some if ran again duplicate its process and also cannot be killed, logoff doesn't help, only solution is reboot
5. dont know if this is native so, but if i disable aero snap in control panel, i will lose aero shake too (which is stupid IMO)
Suumpmolk,
Go to msconfig and uncheck everything, except your anti-virus, spyware detector, and /or personal firewall if you have one.
I need you to restart your computer and do not start any programs except your browser, then post back with the screen shot.
I need to see the applications that are using the highest amount of memory at the top.
Right now, you have way too many processes running.
Suumpmolk
well i dont want to seem rude towards all you helpers here and i realy liked 7, last night i unfortunately
had to revert on XP :P (and i dont like it anymore hehe)
but regarding burn speed, before i installed home premium which was burned at 7x, i also burned ultimate
on 4x and had it installed before home premium, as on home premium i had major troubles with ultimate,
some things started to dissapear, had some weird side effects... so i thought maybe beacuse ultimate was
full of everything maybe was too much for my config so i went on home premium
none of both were tried do "crack", i had them both on 30 day evaluation period
non of them were modified
to who give blame, i dont know, but would sound stupid that configuration which is OK
to run OS would produce such weirdness...
as regarding constant formatting drive and trying clean installs... well as user who wants to use OS
thats realy a hassle :P think all of you can understand "user wants to install OS and have it working"
dont know what else to say... i'm sad for those glitches but they realy made usage of 7 (to me) hard...
with 100% cpu consuming i wasnt able to run simplest program without "lag"
with all those others glitches i mentioned, it made OS half-usable -_-
Sorry we couldn't help you at this time.... Please post again if you need support...:)
nehoma
Honorable Member
I wonder if the windows programs that you downloaded were any good.
I have never heard of 30 day evaluations nor have I heard of a Home Premium evaluation RC.
Where did you download them from?
Did you Pay for them?
apart from the original Officia Microsoft download of RC for Windows 7 Ultimate I would not trust any of the other offered downloads. I knowm there are a lot about and others have used them.
Anyone like to comment on this please
Suumpmolk
err until WinOS is activated it is in its evaluation mode, 30 day limit. (without rearm)
the only difference between RTM (which i had from MSDNAA) and RC/Beta
is that RTM does not display how many days user has in winver and no tag on desktop
only in system it says how many days user has left...
but this you know :P
