hawkeye62
I just upgraded to Win 10 on my Surface Pro 3. I had two problems one of which has been solved. The one that is solved was that my Samsung SDXC card was not recognized. It didn't appear in Device Manager or in Computer Management > Disk Management. I "fixed" the problem by re-installing Windows 10, this time with the SDXC card installed in the slot.
The second problem which remains unsolved is that I have only the Balanced Power Plan. powercfg /l shows only the Balanced plan as does Control Panel > Power Options. I checked Hyper-v which had to be on in Windows 8 for the other Power plans to show up. It was already on, I turned it off, then on but it made no difference.
So, I am stuck. I have only the Balanced plan.
Any help will be appreciated.
Thanks, Jim
Microsoft removed them. The easy way to re-add the power saver and high performance is simply click 'Create a power plan', select the template power saver, balanced or high performance and give it a name. Obviously you will want to do this twice and pick power saver for the first and high performance for the second. Done.
Hi Jim,
What power plan were you after? Do you realise that you can create a power plan yourself although usually certain apps will create power plans for you depending on what the situation is (like using a new SSD or similar).
hawkeye62
Hi Jim,
Thanks for your reply. Yes, I know that, but my only starting point would be the Balanced plan. And based on a lot of trial an error in the past, each power plan has settings that are not visible and form a base plan. Even if all user adjustable settings are the same, each plan gives different results on battery life, performance, etc. That is why I want all three power plans that MS says comes as default plans in Windows 10.
Thanks, Jim
hawkeye62
Thanks, Jim
OK, a reply on another forum suggested a registry hack which solved the problem. I now have the three power plans MS says are there as defaults, Balanced, Battery Saver and Performance.
Regards, Jim
Thanks for letting us know Jim and glad to hear you got a solution. Is there any chance you would share the solution with our users too?
davehc
Do you see this:
An image from '(Solved)I Have Only One Power Plan'. Battery power plan options showing Balanced, Power saver, and High performance modes.
You may have tried this, This is on a Laptop, of course. But, if you do have it, try the High Performance and then, in the next picture, and then, on the right the "change plan settings".
Not sure, as I do not have one, but in the surface pro if you have turned off the hyper v, you may need to reboot to activate it again??
davehc
Disregard my post. (of course!). Seems the other two posts came in whilst I was writing!
hawkeye62
Yeah, but you have to be comfortable with making changes to the registry. First, run regedit, then:
HKEY_LOCAL_MACHINE > SYSTEM > CurrentControlSet > Control > Power
Then set the "CsEnabled" parameter to 0 hex
Then set the "HibernateEnabled" parameter to 1 hex (It may already be set to 1)
Then reboot. Control Panel > Power Options should now show all three power plans, Balanced, Power Saver and Performance.
Good luck, Jim
davehc
Just confirm, from what I read. On the surface, when you do this, you can no longer wake from sleep with touch? Something to do with disconnecting the standby and enabling hibernate, perhaps. I need to pass this on to my grandchildren, who being richer than I, all have surface pros
Grant Guenin
Member
I have the same problem but it literally shows only 1 power plan not all three wht do i do ;C
chitownbob
Well-Known Member
Not to be obtuse but cant you borrow a another surface to review their settings, and "create another" as DAVEHC suggested? Simply save as whatever you like. Also review settings for balanced.
Sent from my XT1575 using Tapatalk
hawkeye62
Good luck, Jim
#8 hawkeye62, Aug 18, 2015
hawkeye62
As I said in an earlier post in this thread, the power plans all have settings that cannot be changed, sort of base plans. You can change all three plans to the same settings that can changed, and they will still give different results.
Regards, Jim
kmaxi
Good luck, Jim
I tried this, didnt work for me :/ Still only one power plan
An image from '(Solved)I Have Only One Power Plan'. Windows Control Panel displaying Power Options with the Balanced power plan selected.
Neemobeer
Windows Forum Team
kmaxi
Thank allot
sophienix
Thanks, Jim
I don't know how to fix it but I found out that you can go to Window Mobility Center and it shows you your plans. Your Welcom
Anime-style city background with Chinese text and a Windows display/power settings window overlay.
Peimur
I have the same issue on my Galaxy Book, except when I try to create a new plan, the only one it provides for a template is "Balanced" and I don't feel comfortable editing the registry. If there is no other way, I have a friend that is more familiar with the nuts and bolts and can probably edit it easily. But in the meantime, is there another way to make the other plans appear, even if its just to use them as a template to create them as usable plans? Alternatively, does anyone know a way to prevent the screen from dimming while in "balanced" mode?
Thanks!!
