The forum thread discusses a recurring "limited access" Wi-Fi issue experienced by the original poster, primarily occurring during online gaming sessions on a customized or older Windows XP system. Responders suggest steps like updating router firmware, checking for conflicting processes, and providing diagnostic information, but the original poster notes difficulties locating certain system utilities and questions whether their OS is a legitimate version. Overall, the thread highlights troubleshooting efforts with some uncertainty about the system's setup and the underlying cause of the connectivity problem.
jingyin
Hello,
a long time ago i had this limited access connection issue, but somehow it dissapeared. But since last week, it suddendly popped up.
I have no idea how to fix this problem.
I have a Linksys WRT120N wireless router connected to a modem, and a desktop connected to the router (not wireless) and i have my laptop who sometimes have this "limited access" problem.
It is pretty annoying, happens once a day
and i just unplug and replug the wireless router for it to fonction again
but i want to fix this problem definitively
im not sure what is causing this problem,
however when i ran the windows diagnostic thingy,
i get 2 problems :
"wireless network connection" doesn't have a valid ip configuration
and
the default gateway is not available
thanks, help would be appreciated.
if you guys need more info, please ask
i really want to fix this !!!
(i dont have much knowledge on computers)
You have elements of two different antivirus security suites installed on the Win7 machine
aswmonflt.sys Avast
avgntflt.sys Avira
Probably not a good thing you should probably pick one and get rid of the other or better yet get rid of both and install Link Removed due to 404 Error. Much more network friendly.
Check the properties of the wireless adapter and uncheck any reference to third party filters and see if that helps.
Additionally regarding your Intel(R) WiFi Link 1000 BGN
read this Link Removed post number 4
and this
Link Removed regarding setting the adapter to "Continuously Aware Mode"
For the XP machine.... whatever it is. You can probably overcome any issues that you seem to be having by setting the IPv4...
Trouble
Noob Whisperer
Are you running the latest firmware update from the downloads tab of this page Link Removed - Invalid URL
Make sure you read the release notes and documentation as to how to perform a firmware update
Have you consulted some of the information located here Link Removed
Or here Link Removed
Additionally check the taskmanager on both machines for a process running called mDNSresponder.exe
May be a product of iTunes and or some Adobe apps
In either case you can find it in the services console listed either as
Bonjour
or something showing similar to this
##Id_String1.6844F930_1628_4223_B5CC_5BB94B879762##
If either or both are present you can double click them and click the stop button and set the startup type to disable.
Regards
Randy
jingyin
Thread Author #3
i dont see anything called that on both of my computers
and my desktop is a old windows XP if it matters and my laptop is windows 7
i have the latest firmware
and the limited access normally occure when im playing games
and i also has a another notebook which is connected to the home wireless network
Trouble
Noob Whisperer
You said in your original post that "it happens once a day"
After that can we assume you no longer have issues regardless of what you do or how long you're connected.
and
"i just unplug and replug the wireless router for it to fonction again"
By unplug and replug can we assume you are power cycling the router or just unplugging the network cable?
If you would like us to look more closely at your settings and possible causes attach a copy of the Microsoft Information Utility
Hold the windows logo key and strike the R key on your keyboard
type msinfo32 and hit enter
In the system information utility click File->Save
Give it a name
XP machine name in XpInfo.nfo
7 machine name it Win7info.nfo
Save them to your desktop
Right click the desktop file and choose send to Compressed (zipped) folder
Attach to your next post.
Regards
Randy
jingyin
Thread Author #5
yes it happens once a day
when im playing video games
and unplug and replug the router for power cycling (i dont unplug the network cable)
i cant find msinfo32 on my xp machine, (it is kind of not a real XP machine)
there is no msinfo32.exe in that folder
Trouble
Noob Whisperer
Windows XP location is
C:\Program Files\Common Files\Microsoft Shared\MSInfo\msinfo32.exe
Windows 7 location is
C:\Windows\System32\msinfo32.exe
Trouble
Noob Whisperer
Editing your post on the fly is getting a little confusing and difficult to track.
Can you tell me what
"it is kind of not a real XP machine" means exactly?
jingyin
Thread Author #8
i think it is not the real version of windows XP it is really old, it is assembled by a lot of parts together by a friend it has OINFOP11.exe in the folder sorry for edits :P
Trouble
Noob Whisperer
If it is running a valid copy of the Windows XP Operating System it should still have msinfo32 located where I suggested as per attachment regardless of how it was constructed or what it is made out of.
jingyin
Thread Author #10
i dont see it maybe it is not a valid windows XP ? it is also not in english
jingyin
Thread Author #11
oh yeah,
when i have that limited access thing (triangle with exclamation mark)
i tried to disconnect and reconnect the wireless network connections
and it says : This computer has limited access (something like that)
Trouble
Noob Whisperer
aswmonflt.sys Avast
avgntflt.sys Avira
and this
For the XP machine.... whatever it is. You can probably overcome any issues that you seem to be having by setting the IPv4 addressing scheme manually.
IP address = 192.168.1.222
Subnet Mask = 255.255.255.0
Default Gateway = 192.168.1.1
DNS Server = 192.168.1.1 preferred
24.200.241.37 alternate
DNS Server addresses for mc.videotron.ca
Cable accessPrimary DNS
Auxiliary DNS
Auxiliary DNS
24.200.241.37
24.201.245.77
24.200.243.189
Dial-up accessPrimary DNS
Auxiliary DNS
205.151.222.250
205.151.222.251
jingyin
Thread Author #13
i really dont know much in computer
but i found this
Link RemovedLink Removed
how do i do that on my XP machine ?:confused:
jingyin
Thread Author #14
and what does this do?
Dear Eddie,
I have much the same problem. I received a few days ago my new Lenovo Z560, with an Intel WiFi Link 1000 BGN. The above link (Link Removed) was helpful, though like you, my control panel does not have all those options. I resolved this issue by doing the following (though I'm not entirely sure that this fully solves the problem).
1) Open Control Panel
2) Go to Network and Internet > Network and Sharing Center > Change Adapter Settings.
3) Select your wireless adapter.
4) In the new window, click Properties.
5) In the new window, select Configure.
6) Select the tab, Advanced.
7) Select Transmit Power.
8) Under the dropdown menu, select Highest. If it's already on Highest, select a different value, and re-select Highest.
Again, I am unsure whether this resolves the problem. I am interested if anyone else finds a solution.
Trouble
Noob Whisperer
but i found this
View attachment 17747View attachment 17748
Those look fine for the Win7 machine but I think for now I would go ahead and uncheck IPv6 in the image you uploaded that is on the right.
on the XP machine, assuming this will work
type
ncpa.cpl
into the run dialog box and hit enter
right click the wired adapater and choose properties
select (highlight) Internet Protocol Version 4 and click the properties button
choose the Use the following IP Address: radio button and enter
Select the Use the following DNS server addresses: and enter
DNS Server = 192.168.1.1 preferred (primary)
24.200.241.37 alternate (secondary)
OK your way back out of there and reboot.
Trouble
Noob Whisperer
Dear Eddie,
I really don't know what it does, because I don't have an Intel WiFi Link 1000 BGN to try it on.
So why don't you give it a try and see what it does, if it helps fine, if not seems easy enough to reverse.
jingyin
Thread Author #17
i cant seems to find the power setting you told me to
what does IPv6 do?
jingyin
Thread Author #19
Great thanks
I will see if it works tomorrow
thanks :D
Does it matter if there is also a PS3 that is connected to the wireless internet?
jingyin
Thread Author #20
Hello again
i diagnose problems on my laptop and this appeared :
your computer appears to be correctly configured but the device or resource (DNS server) is not responding
i still can browse the internet and things
and i don't know what does this error means...
how do i fix this?
and im finding that the internet connection is connecting slower than usual,
it takes more time.
when my computer is on sleep mode and i turn it on,
before the internet would auto connect and it takes about 1 sec
and now i need to connect it manually and takes about 1min to connect
not sure why..
