jonci
Ok this won't help everyone, but will help all those in the UK using Orange live box and WIFI .
The livebox WILL connect despite orange saying it won't work in 64 bit OS, (i know because i phoned them) to the internet via cable without having to reinstall it.
You CANNOT use the Speedtouch 121g wireless adaptor, as it deffinately does not support vista 64bit. despite what orange tell you.
Belkin works fine for windows 7, using vista drivers.
simply plug it in and let windows pick it up as a new device, it will not load drivers though.
go to Belkin site Link Removed
then click on network adaptors picture or follow this link Link Removed
follow the select 1 button then click on type
follow the select 2 button then click model
follow the select 3 button hit a version then check model (if you struggle for version check the device sticker) failing that just click on any of them, it will then link to a picture of the device and by checking the model no it will tell you which version it is.
scroll down page to correct version and download the correct driver (vista 32 or 64).
save it then run it.
follow instructions and put in your live box key and ID make sure its correct or it won't connect.
as an example of speed (i downloaded nvidea drivers in 2.4 seconds using wireless good luck)
It seems like you've found a workaround to connect the Orange Livebox to the internet on a 64-bit OS, despite Orange's initial claim that it wouldn't work. Here's a summary of the steps you've outlined for users in the UK using the Orange Livebox and Wi-Fi: 1. Connecting the Livebox via Cable: - The Livebox can connect to the internet via cable without needing a reinstallation on a 64-bit OS, even though Orange mentioned it wouldn't work. 2. Wireless Adaptor Compatibility: - The Speedtouch 121g wireless adaptor is not compatible with Vista 64-bit, as confirmed by your experience and despite information from Orange. 3. Recommended Alternative - Belkin Wireless Adaptor: - Belkin wireless adaptors work well with Windows 7 using Vista drivers. - Plug in the Belkin adaptor and let Windows recognize it as a new device, without loading drivers automatically. - Visit the Belkin website, and select the appropriate options to download the correct driver for your device and version (Vista 32 or 64). - Install the downloaded driver, follow the instructions, and enter your Livebox key and ID correctly to establish the connection. 4. Speed and Performance: - As an example of the wireless speed, you mentioned downloading NVIDIA drivers in 2.4 seconds using the wireless connection. It's great that you shared these detailed steps to assist others facing similar issues. If anyone in the UK encounters challenges with the Orange Livebox and Wi-Fi, following your method with a Belkin wireless adaptor might help them establish a connection smoothly.
