bonbontintin
More than a few billion PC users around, yet the are NO answers for 100% disk problem. The problem has appeared a very long time and still NO one can help!
Hello bonbontintin,
100% disk is likely referring to your hard disk/ hard drive. It means you've run out of storage space. You should delete at least 10-15% of your files that are taking up your hard drive space as soon as you can to give your hard disk some relief. This can usually be found by heading to Start menu > File Explorer > This PC > OS C:/ drive.
Do you have a lot of movies, music, etc. on the computer? If so try deleting some of those files and it should solve your problem.
Legit Labs
Well-Known Member
Hello bonbontintin,
Neemobeer
Windows Forum Team
If you mean 100% disk usage then that can be caused by a lot of different reasons. The most common being malware, buggy or corrupt software/OS components.
  • Try booting into safe mode and see if the issue continues
  • Also try running sfc /scannow and chkdsk C: /R
You can also download procexp Process Explorer - Windows Sysinternals and enable the disk IO column. That should at least tell you what process and even particular thread causing the high disk IO
bochane
One of the reasons I have seen, is an under dimensioned system, specifically a lack of memory. If this is true for your system some maintenance task will take endlessly. Try to leaving it alone for say 15 minutes and see if cools down. Then you have an indication that you have to upgrade.
