32bit 8800m m1730 problem
#21
SMBios V2.4 DMI V2.4 Count 44 Size 1993 Description BIOS Phoenix Unknown
BIOS A09 Date: 05/29/2008 [ Options 1 ] Dell Inc. ROM Base 0xF000 Size 2MB
System MXG071 Dell Inc. Serial XXXXXXX
Board 0KX412 .XXXXX.CN701668AV0F58. Intel Raid ISM Cfg Sig. 1.0.00
Chassis XXXXXX Dell Inc.
CPU-0 Microprocessor Intel 3.3 volts Intel® Core™2 Duo CPU None Intel® Core™2 Duo CPU 2.60GHz Max 2.60GHz Ext 200MHz Cores 2 Threads 2
L1 Cache Cur: 32KB Max: 32KB Write Back 4-Way Set-Associative
L2 Cache Cur: 6MB Max: 6MB Address Speed 15ns
Port USB USB External Access Bus (USB)
Port MONITOR Video External DB-15 female
Port FireWire FireWire External IEEE 1394
Port Ethernet Network External RJ-45
Onboard 1 [Y] Video Device 1 NVIDIA GeForce 8800M GTX
Onboard 1 [Y] Sound Device 1 Sigmatel 9228
Strings 3 String 1 Dell System
... 2 5[0003]
... 3 13[PP06XA]
Active Language en|US|iso8859-1 Available 1
Memory on Motherboard System Memory Handle 0xFFFE Maximum capacity 4.00GB, 2 devices with No correction
Memory DIMM_A Size 2.00GB Bits 64 DDR RAM DIMM Speed 667MHz Man 7F7F7F0B00000000 Ser 1424-FB31 Tag 000842 Part NT2GT64U8HD0BN-3C
Memory DIMM_B Size 2.00GB Bits 64 DDR RAM DIMM Speed 667MHz Man 7F7F7F0B00000000 Ser 1224-FEF4 Tag 000842 Part NT2GT64U8HD0BN-3C
Built-in Pointer Touch Pad Buttons 2 Interface Bus Mouse
Battery DELL XG5288A Sanyo Sys. Battery Bay 1.0
Cooling Device 0 RPM Status OK Type Fan Handle ID 0xFFFF
Temperature Probe Status OK Location Processor Minimum 0.0°C Maximum 127.0°C Description CPU Internal Temperature
System Boot Length 1 00
Product Microsoft Windows XP V5.1 Build 2600 CSDVersion Service Pack 3
Key: XXXXX-XXXXX-XXXXX-XXXXX-XXXXX ID: 76487-640-0102396-23345 Type: Multiprocessor Free
Owner AAAAA SystemRoot C:\WINDOWS
InstallDate 2009-03-04 10:59:16 Wednesday (1236164356) Licensed CPUs 2 Registered CPUs 2
Product Type WinNT Product Suite
Windows Desktop Display WinSta0\Default
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
[CPU-0 GenuineIntel Patch 0C A0033FFF] Intel Core 2 Duo T9400 (Penryn) [C0] 2.60GHz Socket P BGA-479 (Intel(R) Core(TM)2 Duo CPU T9500 @ 2.60GHz) (x86 Family 6 Model 23 Stepping 6) <SIIICD>
[CPU-1 GenuineIntel Patch 0C A0033FFF] Intel Core 2 Duo T9400 (Penryn) [C0] 2.60GHz Socket P BGA-479 (Intel(R) Core(TM)2 Duo CPU T9500 @ 2.60GHz) (x86 Family 6 Model 23 Stepping 6) <SIIICD>
Mains Power, High (C) (97% Charged) Time Zone Eastern Standard Time (Eastern Daylight Time) Adjustment 15,625µs
[Physical Memory 3.00GB in 3 Areas] Current Profile Profile 1, Desktop System HAL ACPI 1.0 - APIC platform MP
Identifier AT/AT COMPATIBLE
System Bios Date 05/29/08 System Bios Version DELL - 27d8051d Phoenix ROM BIOS PLUS Version 1.10 A09
Video Bios Date 12/21/07 Video Bios Version Version 62.92.2C.00.01
Primary Desktop Display #1 Plug and Play Monitor (LGD0032) (\\.\DISPLAY1\Monitor1)
NVIDIA GeForce 8800M GTX NV4_DISP 1920 x 1200 @0.0 60 Hz 32 bit colour
Video Description NVIDIA GeForce 8800M GTX 512 MB memory
Video Adapter nVidia G92 [GeForce 8800M GTX] (GeForce 8800M GTX)
Video DAC Integrated RAMDAC Video Chip GeForce 8800M GTX Bios 62.92.2C.00.01
Display #2 Default Monitor (Default_Monitor) (\\.\DISPLAY2\Monitor3)
Video Description GeForce 8800M GTX 512 MB memory
Video DAC Integrated RAMDAC Video Chip 8800M GTX Bios 62.92.2C.00.01
Display #3 Unknown (\\.\DISPLAYV1)
Video Description NetMeeting driver
Display #4 Unknown (\\.\DISPLAYV2)
Video Description RDPDD Chained DD
Monitor names from C:\Documents and Settings\Anyone\Desktop\siv\MONDEVS.txt Date 2009-10-22 Version 044 (8,253)
reghakr
#22
Could you please fill in your computer specs in the UserCP link at the top left hand side of the page.
Then click Edit Your Details.
This freeware program will give you all the information you will need:
SIV (System Information Viewer) 4.03
#23
Same exact issue. Same laptop and video cards. Can some times get both started, but when you enable SLI, it will BSOD quickly and then you lose a card again "Code 43". Has been working flawlessly under Windows 7 64-bit.
