hi,
i have an acer 3935 as well. I had it for 2 weeks working fine, then encountered the same problem. Here is summary of my testing so far, without success.
Vista Home Premium 32 bit
Tried with factory conditions, then updated with Acer specific wireless and bluetooth drivers/software.
Removed Acer bundled software and updated with Intel drivers from Intel, and from Windows update all with no success. The problem still occurs randomly.
Upgraded to Windows 7 Home Premium 32 bit, Acer upgrade disk from Vista, problem still occured, then Updated drivers from Acer disk/website when problem still occured, then updated drivers from Intel and windows update. Still problem.
Formatted hard disk, and did a clean install with Windows 7 Acer CD and updated drivers from Acer and updated drivers from Intel, each with no success.
After sending to acer repairs, they first sent it back No fault found. After sending it back a second time, they replaced the wireless card, stating that they found a faulty wireless card. The problem still occurs, though not as frequently. I am on barebones system, with no additional software instsalled except virus scanner. Here are the different variations of the problem i have encountered with no discernable pattern.
Wireless and Bluetooth turn on and off
4 Scenarios how it occurs:
1) Wireless/Bluetooth/data transfer lights flash simultaneously on and off
2) The wireless/bluetooth lights flash simultaneously on and off
3) Bluetooth turns on or off on it's own (depending on if it was on or off)
4) Wireless turns on or off on it's own (depending on if it was on or off)
Have not been able to work out a pattern. Each time all i was doing was browsing the web or doing nothing.
At times have been able to get a few hours uninterrupted, the last day I had it on all day next to me (the day i got it back from repairs second time), without doing anything and it did not drop out once. Now it has started to drop out erratically again.
Problem occurs on battery mode, and on AC.
Any suggestions on how to fix this would be appreciated!!!
(Are ALL Aspire 3935's having this problem or only a few users? I wonder if i get a replacement machine whether it would still occur)
I also noticed that when I installed Live Mesh, that the problem worsened, and 1 and 2 occured more often for longer periods of time. I removed it and it didn't occur as much, though was not as regular a problem. The only thing i can think of there is that it was while it was downloading and syncing files, so when there was high throughput through the device? I don't think this is the direct cause, but i think it may point somehow to the root of the problem maybe?? anyone else with this problem using Live Mesh?
