Windows 7 acer 3935 - 64bit ultimate - bt and wireless on and off constantly?
jason4656
I have an acer 3935 laptop, running 64bit ultimate win 7. I have installed the vista 64bit drivers and it worked fine for first week, then after about a week, the bluetooth started restarting constantly it has a little button on it and it just kept flashing on and off its a touch style button, not a press one, and it was constant, then would stop for a while then do it again. I took all the bt drivers out completely and it still turns on and off when its disabled. Now the wireless has started doing exactly the same thing, its controlled in same way by a touch style button and its on and off along with bluetooth, this is bizarre nothing ive seen before, is it win 7 related? or a virus? ive ran all sorts of stuff, malware bytes, spybot, avg av
thanks
Hi
My wife bought a Acer 3935 against my will :/
And she have the same problem att all other here.
I googled it and after 1 min i had an answer on a youtube video.
The problem seems to be the touch panel.
So I just lifted the panel up and removed the cable.
Do as follow:
1. Lift of the battery
2. Behind the battery there is about five holes that you can bend back some plastic bit that keeps the panel on place.
3. Now you can take it of and to remove the cable you lift up the black plastic bit that´s sitting on the white connector.
You will find a lot of grammatic faults here but as long as you understand there shouldn't be any problems :)
Im Swedish you know....
If you would like some pictures how to do this I can fix that later...
I've also got the Aspire 3935, and have also encountered this issue.
However I have also complained (several times) to Acer, and can summarise my experience and results here in the hope it helps.
Initial complaint of the wireless and bluetooth dropping was met by Acer saying send the machine in. Outcome: replaced media board, updated firmware. Returned, and the computer still had the same fault.
Follow on complaint: Acer advised that until they have attempted 3 x repairs, they will not consider a replacement or refund. Also advised that if I send it back again, and they find no fault, I will be charged a £60 fee. Sought legal advice as they are obligated to repair or replace a faulty item, and wrote a "letter before action" drafted by my friendly lawyer at work. Sent it to them. Result was send it back in. Found out local Acer repair location (Plymouth, UK) which fortunately was same city I was in. Took it in personally and spoke to lead Tech who advised this is a common fault on some other Acer models, but not seen before on 3935. Demonstrated fault. Outcome: Installed new heat protection under thermal switch panel, updated, tested. Returned machine to me, fault reoccured same day.
Found out Acer UK's escalation team (as opposed to Indian call centre for first line Acer support). Phoned. Spoke to very helpful UK team. Arranged for laptop to come back in. Was refunded the full purchase price.
Key learnings:
- first line support is not very helpful. Try and get to escalation team asap.
- legal letter was helpful to get their attention. If you want a copy, let me know.
- take videos of the fault occurring so that you can show it actually happening.
- refer to the fact this is widespread and prove via links they can look up (I have loads of links from around the web of this happening to other Acer owners)
- insist on your legal rights, they will refund you in the end.
- buy a different laptop!
Best of luck!!!
Links to other users' experiences of this issue:
PC World forum
Link Removed - Invalid URL
Youtube video of user's experiencing the problem
Attachment of legal help
View attachment Legal note - UK Writing to the trader.doc
I notice nobody has mentioned the possibility of the router/wireless being the problem, try changing the wireless channel broadcast number (usually channels between 1-13) as it's a commonly overlooked issue that if your neighbours are on wireless theres gonna be some major interference if they happen to have the same channel as you, this also applies to house cordeless phones and other broadcasting equipment.
Personally I despise wireless, can't beat a good ethernet cable for speed or reliability.
Hi
Do as follow:
But this tweak has solved the problem for us.
And the panel isn't very important anyway.
hello, you say you disconnect the cables touchpad wifi, and no more ?? fault, my problem is the same, I realized that I connect the charger and start the computer fails, your solution is to disconnect the cables and panel not fail more
