Windows 7 Assorted errors please help
Tobias Brandenburg
Hi I'm running windows 7 ult. 32bit Intel Pentium d cup 3.00ghz with 4gb or ram with service pack 1
I'm getting assorted blue screen errors the most common is 0x-----19
but i have seen 0x---- a , 7e , 24, d1 , 8e,
I have ran every driver check i can think of as well as a memory check. I am at a loss please help attached are my dump flies This is my first post and help request so if i need something i left out please let me know i have a basic it background but this is over my head.
BugCheck 19, {3, 86430b18, 86430b18, 86430b10}
Probably caused by : Pool_Corruption ( nt!ExDeferredFreePool+312 )
Followup: Pool_corruption
as your already aware your dump files are quite varied with the most common being the above. This could be down to a hardware issue...
as your already aware your dump files are quite varied with the most common being the above. This could be down to a hardware issue, Bios in need of updating or corrupt drivers.
BiosVersion = 0406
BiosReleaseDate = 10/27/2005
There has been quite a few releases since the above version and your losing better functionality. Please update making sure I have the correct page for your motherboard.
http://www.asus.com/Motherboards/P5LD2VM/HelpDesk_Download/
Check to see if Windows is corrupt. Look in the start menu for command prompt and right click on it, choose properties and then run as admin. Type:
sfc /scannow
Press enter and await results.
Check your HDD is running ok by using a chkdsk scan. This guide will explain how:
I know you said that you'd ran a memory check but which application did you use? Memtest86 is the industry standard and nothing else comes close. Please run for a few passes:
http://www.memtest.org/
Norton AV is also known for causing issues. Please un-install to test. Try using this app to remove:
https://support.norton.com/sp/en/uk/home/current/solutions/kb20080710133834EN_EndUserProfile_en_us
MSE is a good replacement as it's known to be extremely stable:
Please update your Intel drivers (driver update utility):
nvlddmkm.sys Thu Jan 31 07:32:52 2013: Nvidia GPU driver, please uninstall using this application which will remove any other old bits of driver lying around:
Install latest version:
http://www.nvidia.com/Download/index.aspx?lang=en-us
Post any new dump files.
