Windows 7 Bluetooth driver does not work on Asus K42F
rezabd99
Hello,
I am in a problem. I am using Windows 7 Ultimate, 32 bit on ASUS K42F dual core notebook. I used it well before reinstalling. I have reinstalled windows7 ultimate and updated it. Everything is ok but bluetooth does not work. When i press fn+f2 (in ASUS notebook) to switch WAN and Blutooth, but only WAN is showing, not bluetooth pop-up. Tried to install bluetooth driver, but cannot install.
Please do something for me.
Thank you
The easiest way could be to try a Program called DriverMax - free driver download program for Windows XP & Vista
It'll recognize missing drivers, and it won't install anything automatically. I've used it for several years, no problems. I suggest you only choose the Bluetooth to be installed - ignore everything else. It's also for Windows 7, and all in 32 and 64bit. And when it asks you if you want to create a Restoration Point DO SAY YES.
