deadtheory
Hi guys,
hopefully someone can help me with this as it is starting to drive me crazy
I have built a new system and components are as follows:
Core i3 2120
Asus P8H67-m-pro B3 revision
OCZ3G1333LV4GK ram (2 x 2gb sticks DDR3 dual channel)
Samsung 1TB HDD
CoolerMaster case with 420W PSU
Windows 7 Premium 64bit
ATI Radeon 4650 Graphics Card (from an existing system) This is the only part of the system that is not brand new.
The system was first built without the 4650 card installed as I intended to use the i3 2120's graphics for basic day to day functionality. During the first installation of Windows the installation froze at the checking video performance screen. I restarted and the installation continued without incidence. Later that night i received a number of blue screens all with different error headers.
As i couldn't find a fix for these errors I formatted and re-installed the OS, this time with the 4650 installed. This time the installation was trouble free. The system ran for close to 12 hours with no errors until another BSoD.
I have installed all available Windows 7 updates as well as all current drivers available for devices listed in device manager. There are no 3rd party games, antivirus/firewall or software installed as yet except for CPUID and other diagnostic programs used to try and solve this issue.
I have run both the windows memory diagnostic tool and Memtest+86 v4 for 12hr+ sessions with not one error recorded. I have run the sfc /scannow utility as proposed in a number of threads and it crashed during the first 3 attempts before it finally completed the scan. BSoD continued however.
There doesn't seem to be any consistency in terms of when the system crashes. So far it has happened during downloading of windows updates, running of sfc /scannow, general web browsing, it crashed twice while using the SF Diagnostic tool requested for this thread. If i leave the computer sitting by itself during the day just at the desktop it will eventually crash.
Also, on a couple of occasions it has locked up while in the Asus Bios page when clicking on the advanced settings tab. This was after I had entered Bios straight after a crash. I thought at one stage that it might have been the ram voltage as manufacturer website lists it at 1.65volts and bios had it shown as 1.5volts. I have sinced tried 1.5, 1.65 and auto with seemingly no difference.
BTW, the 4650 card is from a system that has run the last 12 months or so with no problems whatsoever. That OS was WinXP though.
Also, as i have been trying to type this thread i have received numerous reports about windows explorer and internet explorer having stopped working and crashing.
I'm not sure if any of this helps but if there is anything else you guys require let me know and I will get it to you a.s.a.p.
Thanks in advance.
  • RAMMon - SPD Info.txt
  • Seven Forums -.zip
    Seven Forums -.zip
Your getting memory corruption, could you go into you bios and set the mem to 1.65V and The Command Rate to 2T in the memory timings page. See if it behave then. Anychance of a photo of the pc health page in the bios while your in there.
Elmer
With driver verifier, if you discover what you think is crashing it. Do it for 5-6 times. Trying to establish a pattern, if in fact there is one.
Then load those dumps up.
HTH.
Saltgrass
Well, after going through this thread, I have some questions and then some comments.
The fact you seemed to have a problem with the basic onboard video does not fare well for your system. What video output were you using and how was it connected and what was it connected to?
What drivers have you loaded from either the CD or off the ASUS site?
I had Windows update give me a video driver for my on board video and it crashed the system. Luckily it seemed to auto uninstall without input from me.
Some comments:
There is always a chance the motherboard is bad. If you can exchange it, I would think about it.
Remove the 4650 card until you get your system stable. I have noticed some problems being reported with that card and Windows 7. Even though it was not part of the original situation, it might be part of another.
The next time you reload the OS, you might try the 32 bit version to test.
Although I have no good reason for suggesting this, I would look into getting a slightly larger power supply, maybe 550.
deadtheory
Ok,
well i setup driver verifier as requested last night and within 30sec of the first reboot i got a BSoD referencing a particular driver. On the very next reboot after 5min i got another BSoD. This time no driver was listed.
I turned system off for the night and when i got home this afternoon the pc had trouble performing a cold boot. It would either hang or crash. I performed a system restore through startup recovery and it booted fine the first try after.
However I have lost the 2 minidump files from the night before. I viewed them with BLUESCREENVIEW last night so i know they were there but the restore must be responsible. I do have the pics of the 2 BSoD though which will hopefully mean something to one of you.
I have not yet downloaded the stress test programs "Prime95 & Furmark" but i will do that and post results.
There is no consistency with the apparent causes of the Blue Screens. Sometimes it will crash 30sec after startup and other times it will run for 5 or 6 hours, surfing the net, playing videos. The only thing that is consistent is that at some stage after startup the system will crash. Even if i leave it sitting at the desktop with no open applications running it will eventually crash. It has only run for more than 12 hours once since it was built a few weeks ago.
The video issue turned out to be a faulty DVI-D port on the monitor. Using the D-SUB port through either the onboard video or 4650 I have not had any problems since. I did have some BSoD without the 4650 earlier but I will take it out over the weekend and see what happens.
I'm also going to grab some RAM from another system for testing over the weekend as well. Although last time I swapped out the RAM I still had instability issues as well.
I have loaded the chipset and ethernet drivers off of the Asus disk. I have tried searching for updated drivers for all devices listed in Device Manager but it tells me that all the drivers are the most recent. Even the HDD driver that Microsoft has installed for my Samsung HDD is supposed to be the most recent version but is dated 2006? Does this sound right? I can't find a more recent one on the Samsung website either. I know that WIN7 does not like drivers pre-2009 but there are a few listed that are older.
Hopefully the pics of the Blue Screens from last night will help some.
I appreciate all the help guys.
nmsuk
Can you uninstall all the drivers etc off the asus disc. The drivers you need are available Link Removed Get the chipset drivers from there. Get you audio drivers from Link Removed - Invalid URL
Get you Lan drivers also from Realtek. In my opinion using the drivers from the products cd in most cases ends up being problematic.
HTH
