Windows 10 Bsod every 5 minutes ntoskrnl.exe
Tyream
Its really ridiculous I'm not sure what to do. I can't update my drivers because when I try it crashes I can't even reset it because it crashes at about 30% every time.
What should I do its a custom built computer
if you can read this thread and post the results:
How to ask for help with a BSOD problem
If you have windows 10 on disk or usb then you could boot from that and try a repair or if worst comes to the worst a clean install.
You can download it here:
Can you recall how the bsod started, new drivers/software or hardware?
