Hi jakemb and Welcome to The Forum.
STOP 0x000000F4: CRITICAL_OBJECT_TERMINATION
Usual causes:
Your latest dump file lists
csrss.exe as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes can often indicate hardware issues.
As a Priority:
Make sure your system is fully updated
including SP1.
sptd.sys Tue Aug 24 07:13:12 2010 The
sptd.sys driver is notorious for causing BSOD's with Windows 7. It's a driver used and installed along with Daemon Tools and Alcohol 120 which you'll also have to uninstall.
Then use the correct (32bit or 64bit) download from
Link Removed to uninstall the SPTD.SYS driver.
Make sure to select the
uninstall button!
DO NOT SELECT INSTALL!!
Avira is known to be a cause of BSOD's on many Windows 7 systems.
Uninstall Avira through the Control Panel. Then run the
Link Removed to clean up any remaining registry entries. Download BSOD friendly
Link Removed due to 404 Error as its replacement. Make sure Windows firewall is enabled!
Drivers that pre-date Windows 7. Update:
speedfan.sys Sun Sep 24 14:26:48 2006 Speedfan.
Rt64win7.sys Thu Feb 26 09:04:13 2009 Link Removed If you're unsure about manually installing drivers then choose the
Win7 and WinServer 2008 R2 Auto Installation Program (SID:1477671) option to download.
000.fcl Fri Sep 26 14:11:22 2008 CyberLink FCL Driver
ElbyCDIO ElbyCDIO.sys Tue Feb 17 17:11:23 2009
ElbyCDFL.sys Thu Dec 14 21:22:27 2006 Link Removed - Invalid URL
FNETURPX.SYS Sat Oct 04 03:27:02 2008 Link Removed - Invalid URL
GEARAspiWDM.sys Mon May 18 13:17:04 2009 Gear Software CD-ROM Class Filter Driver v4.019.1 (Oct 2011). Also loads with
iTunes
GenBus.sys Tue Nov 25 08:59:58 2008 USB Server Bus Enumerator
purendis.sys Tue Oct 28 04:31:28 2008 Link Removed - Invalid URL
stwrt64.sys Fri May 22 23:58:59 2009 SigmaTel High Definition Audio Codec
OEM
Bugcheck Analysis:
* Bugcheck Analysis *
BugCheck F4, {3, fffffa800824ab30, fffffa800824ae10, fffff80003f8a2d0}
Probably caused by : csrss.exe
Followup: MachineOwner
3: kd> !analyze -v
CRITICAL_OBJECT_TERMINATION (f4)
A process or thread crucial to system operation has unexpectedly exited or been
terminated.
Several processes and threads are necessary for the operation of the
system; when they are terminated (for any reason), the system can no
longer function.
Arguments:
Arg1: 0000000000000003, Process
Arg2: fffffa800824ab30, Terminating object
Arg3: fffffa800824ae10, Process image file name
Arg4: fffff80003f8a2d0, Explanatory message (ascii)
Debugging Details:
PROCESS_OBJECT: fffffa800824ab30
IMAGE_NAME: csrss.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 0
MODULE_NAME: csrss
FAULTING_MODULE: 0000000000000000
PROCESS_NAME: csrss.exe
EXCEPTION_CODE: (NTSTATUS) 0xc0000006 - The instruction at 0x%p referenced memory at 0x%p. The required data was not placed into memory because of an I/O error status of 0x%x.
BUGCHECK_STR: 0xF4_IOERR
CUSTOMER_CRASH_COUNT: 1
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`07749ac8 fffff800`0400df62 : 00000000`000000f4 00000000`00000003 fffffa80`0824ab30 fffffa80`0824ae10 : nt!KeBugCheckEx
fffff880`07749ad0 fffff800`03fb5a23 : ffffffff`ffffffff fffffa80`0837db60 fffffa80`0824ab30 fffffa80`0824ab30 : nt!PspCatchCriticalBreak+0x92
fffff880`07749b10 fffff800`03f3d90c : ffffffff`ffffffff 00000000`00000001 fffffa80`0824ab30 00000000`00000008 : nt! ?? ::NNGAKEGL::`string'+0x17666
fffff880`07749b60 fffff800`03c80993 : fffffa80`0824ab30 fffff880`c0000006 00000000`0176f810 fffffa80`0837db60 : nt!NtTerminateProcess+0x20c
fffff880`07749be0 00000000`7796f97a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0176e518 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7796f97a
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
FAILURE_BUCKET_ID: X64_0xF4_IOERR_IMAGE_csrss.exe
Drivers:
fffff880`04a00000 fffff880`04a2b000 000 000.fcl Fri Sep 26 14:11:22 2008 (48DCDF7A)
fffff880`03fb6000 fffff880`03ff4000 1394ohci 1394ohci.sys Tue Jul 14 01:07:12 2009 (4A5BCC30)
fffff880`03e2a000 fffff880`03e6e000 a00xws9p a00xws9p.SYS Sat Jul 17 11:58:04 2010 (4C418CBC)
fffff880`03e6e000 fffff880`03e7a000 Accelerometer Accelerometer.sys Tue Jun 15 17:41:27 2010 (4C17AD37)
fffff880`01038000 fffff880`0108f000 ACPI ACPI.sys Tue Jul 14 00:19:34 2009 (4A5BC106)
fffff880`03002000 fffff880`0308c000 afd afd.sys Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`0140f000 fffff880`01425000 AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`07e5b000 fffff880`07f7d000 agrsm64 agrsm64.sys Mon Nov 10 15:01:35 2008 (49184CCF)
fffff880`00cc0000 fffff880`00ccb000 amdxata amdxata.sys Tue May 19 18:56:59 2009 (4A12F2EB)
fffff880`08b6b000 fffff880`08b76000 asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`00e76000 fffff880`00e7f000 atapi atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00e7f000 fffff880`00ea9000 ataport ataport.SYS Tue Jul 14 00:19:52 2009 (4A5BC118)
fffff880`04c1b000 fffff880`05232000 atikmdag atikmdag.sys Tue Aug 18 04:05:47 2009 (4A8A1A8B)
fffff880`013bb000 fffff880`01400000 auf7oidl auf7oidl.SYS Tue Jul 14 22:12:55 2009 (4A5CF4D7)
fffff880`07c9e000 fffff880`07cbd000 avgntflt avgntflt.sys Fri May 27 15:33:08 2011 (4DDFB624)
fffff880`03f51000 fffff880`03f75000 avipbb avipbb.sys Tue Jun 14 14:57:13 2011 (4DF768B9)
fffff880`00fbf000 fffff880`00fcb000 BATTC BATTC.SYS Tue Jul 14 00:31:01 2009 (4A5BC3B5)
fffff880`01666000 fffff880`0166d000 Beep Beep.SYS Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`03f40000 fffff880`03f51000 blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`08595000 fffff880`085b3000 bowser bowser.sys Tue Jul 14 00:23:50 2009 (4A5BC206)
fffff880`0460c000 fffff880`04628000 bridge bridge.sys Tue Jul 14 02:01:48 2009 (4A5BD8FC)
fffff960`00790000 fffff960`007b7000 cdd cdd.dll Wed Jan 26 06:31:34 2011 (4D3FBFC6)
fffff880`0152f000 fffff880`01559000 cdrom cdrom.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00c00000 fffff880`00cc0000 CI CI.dll Tue Jul 14 02:32:13 2009 (4A5BE01D)
fffff880`00d26000 fffff880`00d84000 CLFS CLFS.SYS Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`03fb1000 fffff880`03fb5500 CmBatt CmBatt.sys Tue Jul 14 00:31:03 2009 (4A5BC3B7)
fffff880`014a1000 fffff880`01514000 cng cng.sys Tue Jul 14 00:49:40 2009 (4A5BC814)
fffff880`00fb6000 fffff880`00fbf000 compbatt compbatt.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`03e7a000 fffff880`03e8a000 CompositeBus CompositeBus.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`07e49000 fffff880`07e57000 crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`03e9f000 fffff880`03f22000 csc csc.sys Tue Jul 14 00:24:26 2009 (4A5BC22A)
fffff880`03f22000 fffff880`03f40000 dfsc dfsc.sys Tue Jul 14 00:23:44 2009 (4A5BC200)
fffff880`01400000 fffff880`0140f000 discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`0312b000 fffff880`03150000 dnelwf64 dnelwf64.sys Fri Feb 04 01:03:56 2011 (4D4B507C)
fffff880`07d75000 fffff880`07d97000 drmk drmk.sys Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`07cbd000 fffff880`07cc9000 dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`07cc9000 fffff880`07cdc000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`07ff5000 fffff880`08000000 dump_msahci dump_msahci.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`03e0e000 fffff880`03e2a000 dvdfab dvdfab.sys Thu Jan 13 08:57:46 2011 (4D2EBE8A)
fffff880`07f8e000 fffff880`07f9a000 Dxapi Dxapi.sys Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`05232000 fffff880`05326000 dxgkrnl dxgkrnl.sys Wed Jan 26 04:22:56 2011 (4D3FA1A0)
fffff880`05326000 fffff880`0536c000 dxgmms1 dxgmms1.sys Wed Jan 26 04:22:12 2011 (4D3FA174)
fffff880`03e00000 fffff880`03e0e000 ElbyCDFL ElbyCDFL.sys Thu Dec 14 21:22:27 2006 (4581C093)
fffff880`031f6000 fffff880`03200000 ElbyCDIO ElbyCDIO.sys Tue Feb 17 17:11:23 2009 (499AEFBB)
fffff880`08b91000 fffff880`08bc7000 fastfat fastfat.SYS Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff880`00dd0000 fffff880`00de4000 fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`00d84000 fffff880`00dd0000 fltmgr fltmgr.sys Tue Jul 14 00:19:59 2009 (4A5BC11F)
fffff880`0166d000 fffff880`01676000 FNETURPX FNETURPX.SYS Sat Oct 04 03:27:02 2008 (48E6D476)
fffff880`01525000 fffff880`0152f000 Fs_Rec Fs_Rec.sys Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01a00000 fffff880`01a3a000 fvevol fvevol.sys Sat Sep 26 03:34:26 2009 (4ABD7DB2)
fffff880`01600000 fffff880`0164a000 fwpkclnt fwpkclnt.sys Tue Jul 14 00:21:08 2009 (4A5BC164)
fffff880`053f3000 fffff880`05400000 GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff880`04742000 fffff880`0474e000 GenBus GenBus.sys Tue Nov 25 08:59:58 2008 (492BBE8E)
fffff800`041ee000 fffff800`04237000 hal hal.dll Tue Jul 14 02:27:36 2009 (4A5BDF08)
fffff880`0536c000 fffff880`05390000 HDAudBus HDAudBus.sys Tue Jul 14 01:06:13 2009 (4A5BCBF5)
fffff880`07cdc000 fffff880`07d38000 HdAudio HdAudio.sys Tue Jul 14 01:06:59 2009 (4A5BCC23)
fffff880`07fc5000 fffff880`07fde000 HIDCLASS HIDCLASS.SYS Tue Jul 14 01:06:21 2009 (4A5BCBFD)
fffff880`07fde000 fffff880`07fe6080 HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`07fb7000 fffff880`07fc5000 hidusb hidusb.sys Tue Jul 14 01:06:22 2009 (4A5BCBFE)
fffff880`01dd0000 fffff880`01dda000 hpdskflt hpdskflt.sys Tue Jun 15 17:41:28 2010 (4C17AD38)
fffff880`084c3000 fffff880`0858b000 HTTP HTTP.sys Tue Jul 14 00:22:16 2009 (4A5BC1A8)
fffff880`01dc7000 fffff880`01dd0000 hwpolicy hwpolicy.sys Tue Jul 14 00:19:22 2009 (4A5BC0FA)
fffff880`061d1000 fffff880`061ef000 i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`03f9b000 fffff880`03fb1000 intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`061ef000 fffff880`061fe000 kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`07fe7000 fffff880`07ff5000 kbdhid kbdhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff800`00b97000 fffff800`00ba1000 kdcom kdcom.dll Tue Jul 14 02:31:07 2009 (4A5BDFDB)
fffff880`046ff000 fffff880`04742000 ks ks.sys Thu Mar 04 04:32:25 2010 (4B8F37D9)
fffff880`01487000 fffff880`014a1000 ksecdd ksecdd.sys Tue Jul 14 00:20:54 2009 (4A5BC156)
fffff880`017d4000 fffff880`017ff000 ksecpkg ksecpkg.sys Fri Dec 11 06:03:32 2009 (4B21E0B4)
fffff880`07d97000 fffff880`07d9c200 ksthunk ksthunk.sys Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`03e8a000 fffff880`03e9f000 lltdio lltdio.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`07c7b000 fffff880`07c9e000 luafv luafv.sys Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00cce000 fffff880`00d12000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 02:29:10 2009 (4A5BDF66)
fffff880`07f7f000 fffff880`07f8e000 modem modem.sys Tue Jul 14 01:10:48 2009 (4A5BCD08)
fffff880`07e0d000 fffff880`07e1b000 monitor monitor.sys Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`05a52000 fffff880`05a61000 mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`07e00000 fffff880`07e0d000 mouhid mouhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00e5c000 fffff880`00e76000 mountmgr mountmgr.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`085b3000 fffff880`085cb000 mpsdrv mpsdrv.sys Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`085cb000 fffff880`085f8000 mrxsmb mrxsmb.sys Sat Feb 27 07:52:19 2010 (4B88CF33)
fffff880`08400000 fffff880`0844e000 mrxsmb10 mrxsmb10.sys Sat Feb 27 07:52:28 2010 (4B88CF3C)
fffff880`0844e000 fffff880`08471000 mrxsmb20 mrxsmb20.sys Sat Feb 27 07:52:26 2010 (4B88CF3A)
fffff880`00fe0000 fffff880`00feb000 msahci msahci.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`015ae000 fffff880`015b9000 Msfs Msfs.SYS Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`0108f000 fffff880`01099000 msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01429000 fffff880`01487000 msrpc msrpc.sys Tue Jul 14 00:21:32 2009 (4A5BC17C)
fffff880`031eb000 fffff880`031f6000 mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01c3f000 fffff880`01c51000 mup mup.sys Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`01682000 fffff880`01774000 ndis ndis.sys Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`0464c000 fffff880`04658000 ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`04b01000 fffff880`04b14000 ndisuio ndisuio.sys Tue Jul 14 01:09:25 2009 (4A5BCCB5)
fffff880`04658000 fffff880`04687000 ndiswan ndiswan.sys Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`047ba000 fffff880`047cf000 NDProxy NDProxy.SYS Tue Jul 14 01:10:05 2009 (4A5BCCDD)
fffff880`03150000 fffff880`0315f000 netbios netbios.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`0308c000 fffff880`030d1000 netbt netbt.sys Tue Jul 14 00:21:28 2009 (4A5BC178)
fffff880`01774000 fffff880`017d4000 NETIO NETIO.SYS Tue Jul 14 00:21:46 2009 (4A5BC18A)
fffff880`05a65000 fffff880`061c4000 NETw5s64 NETw5s64.sys Wed Jan 13 16:37:13 2010 (4B4DF6B9)
fffff880`015b9000 fffff880`015ca000 Npfs Npfs.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`031df000 fffff880`031eb000 nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`03c11000 fffff800`041ee000 nt ntkrnlmp.exe Wed Oct 27 03:43:09 2010 (4CC791BD)
fffff880`01218000 fffff880`013bb000 Ntfs Ntfs.sys Tue Jul 14 00:20:47 2009 (4A5BC14F)
fffff880`0165d000 fffff880`01666000 Null Null.SYS Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`04aae000 fffff880`04b01000 nwifi nwifi.sys Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`030e5000 fffff880`0310b000 pacer pacer.sys Tue Jul 14 01:09:41 2009 (4A5BCCC5)
fffff880`00fa1000 fffff880`00fb6000 partmgr partmgr.sys Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00f6e000 fffff880`00fa1000 pci pci.sys Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00feb000 fffff880`00ffb000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`046dd000 fffff880`046f1380 pcouffin pcouffin.sys Tue Dec 05 14:39:30 2006 (457584A2)
fffff880`01514000 fffff880`01525000 pcw pcw.sys Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`04b44000 fffff880`04bea000 peauth peauth.sys Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`04b14000 fffff880`04b20000 pnarp pnarp.sys Tue Oct 28 05:57:00 2008 (4906A9AC)
fffff880`07d38000 fffff880`07d75000 portcls portcls.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00d12000 fffff880`00d26000 PSHED PSHED.dll Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`04b20000 fffff880`04b2c000 purendis purendis.sys Tue Oct 28 04:31:28 2008 (490695A0)
fffff880`00de4000 fffff880`00defe00 PxHlpa64 PxHlpa64.sys Fri May 15 22:43:06 2009 (4A0DE1EA)
fffff880`04628000 fffff880`0464c000 rasl2tp rasl2tp.sys Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`04687000 fffff880`046a2000 raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`046a2000 fffff880`046c3000 raspptp raspptp.sys Tue Jul 14 01:10:18 2009 (4A5BCCEA)
fffff880`046c3000 fffff880`046dd000 rassstp rassstp.sys Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`0318e000 fffff880`031df000 rdbss rdbss.sys Tue Jul 14 00:24:09 2009 (4A5BC219)
fffff880`046f2000 fffff880`046fd000 rdpbus rdpbus.sys Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`01676000 fffff880`0167f000 RDPCDD RDPCDD.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`0159c000 fffff880`015a5000 rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`015a5000 fffff880`015ae000 rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01b94000 fffff880`01bce000 rdyboost rdyboost.sys Tue Jul 14 00:34:34 2009 (4A5BC48A)
fffff880`04b2c000 fffff880`04b44000 rspndr rspndr.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`05a00000 fffff880`05a32000 Rt64win7 Rt64win7.sys Thu Feb 26 09:04:13 2009 (49A65B0D)
fffff880`01009000 fffff880`01038000 SCSIPORT SCSIPORT.SYS Tue Jul 14 01:01:04 2009 (4A5BCAC0)
fffff880`05a32000 fffff880`05a52000 sdbus sdbus.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`08471000 fffff880`0847c000 secdrv secdrv.SYS Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`01c00000 fffff880`01c3f000 snapman snapman.sys Tue Sep 08 08:57:04 2009 (4AA60E50)
fffff880`01dc0000 fffff880`01dc7000 speedfan speedfan.sys Sun Sep 24 14:26:48 2006 (45168798)
fffff880`01db8000 fffff880`01dc0000 spldr spldr.sys Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`0109f000 fffff880`011fc000 sptd sptd.sys Tue Aug 24 07:13:12 2010 (4C7362F8)
fffff880`08a64000 fffff880`08afa000 srv srv.sys Fri Aug 27 04:38:00 2010 (4C773318)
fffff880`04a2b000 fffff880`04a92000 srv2 srv2.sys Fri Aug 27 04:37:46 2010 (4C77330A)
fffff880`0847c000 fffff880`084a9000 srvnet srvnet.sys Fri Aug 27 04:37:24 2010 (4C7732F4)
fffff880`07c00000 fffff880`07c7b000 stwrt64 stwrt64.sys Fri May 22 23:58:59 2009 (4A172E33)
fffff880`046fd000 fffff880`046fe480 swenum swenum.sys Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01803000 fffff880`01a00000 tcpip tcpip.sys Mon Jun 14 04:39:04 2010 (4C15A458)
fffff880`084a9000 fffff880`084bb000 tcpipreg tcpipreg.sys Tue Jul 14 01:09:49 2009 (4A5BCCCD)
fffff880`015e8000 fffff880`015f5000 TDI TDI.SYS Tue Jul 14 00:21:18 2009 (4A5BC16E)
fffff880`01c52000 fffff880`01db8000 tdrpm251 tdrpm251.sys Fri Jul 31 14:59:53 2009 (4A72F8D9)
fffff880`015ca000 fffff880`015e8000 tdx tdx.sys Tue Jul 14 00:21:15 2009 (4A5BC16B)
fffff880`0317a000 fffff880`0318e000 termdd termdd.sys Tue Jul 14 01:16:36 2009 (4A5BCE64)
fffff880`01a53000 fffff880`01b38000 timntr timntr.sys Mon Aug 17 08:16:13 2009 (4A8903BD)
fffff960`00530000 fffff960`0053a000 TSDDD TSDDD.dll unavailable (00000000)
fffff880`03f75000 fffff880`03f9b000 tunnel tunnel.sys Tue Jul 14 01:09:37 2009 (4A5BCCC1)
fffff880`07d9d000 fffff880`07df1000 udfs udfs.sys Tue Jul 14 00:23:37 2009 (4A5BC1F9)
fffff880`0474e000 fffff880`04760000 umbus umbus.sys Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`07f9a000 fffff880`07fb7000 usbccgp usbccgp.sys Tue Jul 14 01:06:45 2009 (4A5BCC15)
fffff880`07f7d000 fffff880`07f7ef00 USBD USBD.SYS Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`04c00000 fffff880`04c11000 usbehci usbehci.sys Tue Jul 14 01:06:30 2009 (4A5BCC06)
fffff880`04760000 fffff880`047ba000 usbhub usbhub.sys Tue Jul 14 01:07:09 2009 (4A5BCC2D)
fffff880`0539d000 fffff880`053f3000 USBPORT USBPORT.SYS Tue Jul 14 01:06:31 2009 (4A5BCC07)
fffff880`05390000 fffff880`0539d000 usbuhci usbuhci.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`07e1b000 fffff880`07e48200 usbvideo usbvideo.sys Thu Mar 04 04:40:57 2010 (4B8F39D9)
fffff880`00f61000 fffff880`00f6e000 vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`0310b000 fffff880`03115000 vfilter vfilter.sys Thu Nov 19 00:06:23 2009 (4B048BFF)
fffff880`01559000 fffff880`01567000 vga vga.sys Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`01567000 fffff880`0158c000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`01b38000 fffff880`01b48000 vmstorfl vmstorfl.sys Tue Jul 14 00:42:54 2009 (4A5BC67E)
fffff880`00fcb000 fffff880`00fe0000 volmgr volmgr.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00e00000 fffff880`00e5c000 volmgrx volmgrx.sys Tue Jul 14 00:20:33 2009 (4A5BC141)
fffff880`01b48000 fffff880`01b94000 volsnap volsnap.sys Tue Jul 14 00:20:08 2009 (4A5BC128)
fffff880`061c4000 fffff880`061d1000 vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`03115000 fffff880`0312b000 vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`0315f000 fffff880`0317a000 wanarp wanarp.sys Tue Jul 14 01:10:21 2009 (4A5BCCED)
fffff880`0158c000 fffff880`0159c000 watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00eae000 fffff880`00f52000 Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f52000 fffff880`00f61000 WDFLDR WDFLDR.SYS Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`030dc000 fffff880`030e5000 wfplwf wfplwf.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`000a0000 fffff960`003b0000 win32k win32k.sys Wed Jan 05 03:59:44 2011 (4D23ECB0)
fffff880`04c11000 fffff880`04c1a000 wmiacpi wmiacpi.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`01000000 fffff880`01009000 WMILIB WMILIB.SYS Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`030d1000 fffff880`030dc000 ws2ifsl ws2ifsl.sys Tue Jul 14 01:10:33 2009 (4A5BCCF9)
fffff880`047cf000 fffff880`047f0000 WudfPf WudfPf.sys Tue Jul 14 01:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`0858b000 fffff880`08595000 vwifimp.sys
Checksum: 00000000
ImageSize: 0000A000
fffff880`01bce000 fffff880`01bfe000 CLASSPNP.SYS
Checksum: 00000000
ImageSize: 00030000
fffff880`01dda000 fffff880`01df0000 disk.sys
Checksum: 00000000
ImageSize: 00016000
fffff880`08bc7000 fffff880`08bf8000 WUDFRd.sys
Checksum: 00000000
ImageSize: 00031000
fffff880`08b76000 fffff880`08b91000 USBSTOR.SYS
Checksum: 00000000
ImageSize: 0001B000
fffff880`08afa000 fffff880`08b6b000 spsys.sys
Checksum: 00000000
ImageSize: 00071000
fffff880`01df0000 fffff880`01dfe000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`01a3a000 fffff880`01a46000 dump_pciidex
Checksum: 00000000
ImageSize: 0000C000
fffff880`01a46000 fffff880`01a51000 dump_msahci.
Checksum: 00000000
ImageSize: 0000B000
fffff880`0164a000 fffff880`0165d000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
