- Thread Author
- #1
Hi there,
New to Windows 7 and these fora, just hoping someone could help me out with my annoying crash problem.
I recently installed Windows 7 RC (clean install, empty partition), but whenever I shutdown or restart, after installing updates and the "Shutting down..." screen it crashes to a bluescreen, giving the error BUGCODE_USB. Have been sending the minidumps to MS, but if they fix it I imagine it'll be some time before we see the patch, so hoping someone here has some info.
Here's some info from the problem report:
Problem signature:
OS Version: 6.1.7100.2.0.0.256.1
Locale ID: 2057
Additional information about the problem:
BCCode: fe
BCP1: 0000000000000008
BCP2: 0000000000000006
BCP3: 0000000000000006
BCP4: FFFFFA8007C1D000
OS Version: 6_1_7100
Service Pack: 0_0
Product: 256_1
And my specs:
AMD X2 3Ghz
6GB 800Mhz DDR2 RAM (2x1GB, 2x 2GB)
Asus M2N32-SLI motherboard
NVidia GeForce 9800GT 1GB
As for USB devices, I'm using a microsoft keyboard and mouse, so pretty sure there's proper drivers for those in 7, but I am also running an internal Akasa card reader, plugged direct into the motherboard USB socket. Card reader is working fine though.
There's also an unknown device listed in my device manager, but not too sure what it is, possibly something to do with ACPI? (Hardware IDs: ACPI\AWY0001, *AWY0001). I could download latest motherboard drivers from Asus, but they don't have windows 7 drivers listed yet, should I just use the Vista ones?
Any help or advice greatly appreciated, will be happy to post additional info if it'd help.
Regards,
Misha
Problem signature:
Locale ID: 2057
BCCode: fe
Service Pack: 0_0
Product: 256_1
And my specs:
AMD X2 3Ghz
Regards,
Misha
