Hello, recently I've getting getting numerous errors with my PC, and at first I thought it was hard drive related, however now I am not so sure. I will list problems in order from when they started happening to what's happening now (after a clean system restore)
C:120G D: 1TB
(SSDSC2CT120 120G SSD)paired with (WDC WD10EZEX-OOBN 1TB) < Possibly failing?
Problem 1. When playing games that boot from my secondary hard drive, they would run fine for a given time (anywhere from 30 minutes to a few hours) then I they would freeze, and a error box would pop up saying Microsoft Windows has stopped responding would you like to close? And it would either A. Resolve itself after a period of time in witch I would return to my computer with my D: drive would be disconnected. (A computer restart would usually resolve this).
Or B. End in a BSOD.
Games that caused it (that I played that were on my D: drive) Rocket League, The Division, Dying Light, World of Warcraft.
Problem 2. In addition to problem 1. I was also getting the occasional blue screen caused by this issue that was either Critical Process Died (being the rarer one) or something to the extent of a kernal impage error. (both of witch seemed to happen randomly in conjunction with the freezes however random in witch BSOD I received.
Problem 3.Eventually I was able to do a clean reformat of my PC (the long one) and get everything re downloaded and reinstalled. However I was still having issues, only now the only BSOD I seem to get is Critical Process Died. I decided to move my Rocket League over to my C: drive so that I could play it without issues (because I can play CS:GO and LoL, without any problems both being on my C: Drive. However even with it moved it still causes the BSOD, while the other games do not. I would also like to note that I replaced the sata cables on both my disks as I believed that to be the issue originally.
I have tried Memory Diag, checked my disks for errors, and done general diagnosing to the best of my ability, I can normally fix these kind of things myself With the help of google of course, however there seems to be a unlimited number of possibilities witch are caused by this BSOD as well as the other issues.
I have included a SystemReport file below that I created using PowerShell any help would be greatly appreciated.
C:120G D: 1TB
