Microsoft Edge’s Canary channel has begun surfacing experimental controls that explicitly treat passkeys as first‑class syncable credentials in the browser, adding new flags labeled Passkey roaming and Passkey roaming management and settings, and exposing a combined “Passwords and passkeys” sync entry under Profiles > Sync — a clear signal Microsoft is moving to bring passkey creation, roaming, and management directly into Edge’s settings and sync pipeline.
Neon blue cloud-security scene with a monitor showing a chat bubble, surrounded by devices.Background​
Passkeys are built on the WebAuthn and FIDO2 standards and replace passwords with cryptographic key pairs: the private key stays on a device (or in a credential manager) and the public key is registered with the site. Authentication requires unlocking the private key with a local factor such as biometric verification or a PIN (Windows Hello on Windows devices). This model resists phishing and credential reuse because there’s no reusable, server‑side password to capture. Browsers and platforms have taken different approaches to passkey roaming (that is, making a passkey usable across multiple devices). Some platforms provide cloud‑backed synced passkeys (for example, iCloud Keychain on Apple platforms and Google Password Manager in Chrome’s ecosystem), while others primarily rely on local, device‑bound keys protected in a TPM or secure enclave. The industry is rapidly converging on hybrid models that balance usability with hardware‑backed security. (theverge.com, learn.microsoft.com)
Microsoft’s latest Canary experiments — which add explicit passkey controls to Edge’s sync UI — mark a notable step: rather than passkeys being only a platform (Windows Hello) concern, Edge aims to operate as a passkey provider and sync surface in its own right. The Canary screenshots and flag descriptions reveal how Microsoft plans to label and surface those controls inside Edge.
What Microsoft is testing in Edge Canary​
The experimental flags and what they show​
  • Passkey roaming — the flag’s description indicates Edge would act “as a passkey provider” and sync saved passkeys across devices. This wording positions the browser itself as an originator of synced passkey material (or at least the manager/router of passkey storage and sync).
  • Passkey roaming management and settings — this companion flag exposes management UI and settings intended to give users more granular control over how synced passkeys are handled. The description explicitly calls out management support, implying options to review and control stored passkeys.
After toggling these flags, a new entry appears under Profiles > Sync in the Canary build: Passwords and passkeys with the description “Stored securely and made available on all your devices. Review security settings to help make your Microsoft account even more secure.” This is the first time passkeys have been listed alongside traditional passwords in Edge’s sync options, showing a change in how Microsoft packages credential sync in the browser.
Where this fits in Microsoft’s broader passkey strategy​
Windows already integrates passkeys through Windows Hello and platform authenticators, and Microsoft has been rolling passkey support and cloud‑backed sync capabilities across the Windows ecosystem (including APIs to enable third‑party passkey managers like 1Password and Bitwarden to integrate with Windows Hello). The Edge flags suggest an additional — and sometimes overlapping — strategy: give the browser its own passkey provisioning and sync controls, tied to Microsoft Account sync.
Why this matters — benefits for users and developers​
Usability: fewer recovery headaches, smoother device transitions​
  • Cross‑device continuity: Synced passkeys remove the need to re‑register credentials when a user moves to a new device. If Edge can serve as a passkey provider and sync platform, users who sign in with their Microsoft Account could gain immediate passkey access across signed‑in devices. This reduces friction for non‑technical users. (windowsreport.com, learn.microsoft.com)
  • Unified control surface: Listing “Passwords and passkeys” under the same sync control can make credential management simpler: a single place to review which credentials are synced and to apply privacy/security controls.
Developer adoption and WebAuthn integration​
  • Clearer browser semantics: If Edge advertises itself as a passkey provider, site developers and password‑manager vendors gain a predictable point of integration — enabling better UX flows for passkey creation, replacement, and recovery that work consistently in Edge. This clarity can speed implementation of WebAuthn flows and reduce site‑side complexity.
Security analysis — benefits and risk tradeoffs​
Security strengths (what passkey roaming improves)​
  • Anti‑phishing: Passkeys remove shared secrets that can be captured via phishing. Because authentication depends on a key pair bound to a specific origin and unlocked locally, phishing pages cannot obtain usable credentials. This remains true whether the private key is device‑bound or synced and encrypted in the cloud.
  • Strong local protection: On Windows devices the use of Windows Hello + TPM provides strong hardware‑backed protection for stored keys. If Edge’s roaming relies on encryption bound to a TPM or a secure vault on each device, the local security posture remains robust.
Security risks and practical caveats​
  • Sync implies copyability: By design, synced passkeys must be transferable (encrypted, then stored in the cloud) so they can be used on multiple devices. This increases the attack surface compared with strictly device‑bound credentials. The main mitigation is robust end‑to‑end encryption and client‑side keys that Microsoft (or any provider) cannot decrypt without user approval. This architecture must be audited carefully because a cloud‑backup capability changes the threat model. (theverge.com, learn.microsoft.com)
  • Account compromise becomes higher‑stakes: If passkeys are synced through a Microsoft Account, attackers who compromise that account or its recovery methods could potentially mis‑use passkeys or enable new devices. Strong account protection (MFA, hardware security keys, recovery limitations) must be required to make synced passkeys safe in practice. Microsoft’s own guidance emphasizes secure account settings and recovery planning.
  • Enterprise policy and attestation: Organizations that enforce attestation or require specific key models may find synced passkeys complicate compliance. Administrators will need controls for attestation enforcement, revocation, and auditing — especially where hardware‑backed attestations are required. Microsoft documentation and third‑party identity vendors highlight this operational complexity.
  • Recovery edge cases: Synced passkeys are convenient — but recovery paths must be explicit. Device‑bound passkeys offer strong security but are unrecoverable if the device is lost. Cloud‑synced passkeys improve recoverability but rely on the security of the cloud account. Users must understand backup and recovery tradeoffs before adopting roaming passkeys widely.
How Edge’s approach compares with other ecosystems​
Google / Chrome​
Google has built passkey sync into Google Password Manager and Chrome, including PIN‑protected access flows to move passkeys across platforms. Google’s approach uses its own cloud key manager to enable cross‑device passkey usage while preserving end‑to‑end encryption of private keys. The practical effect is a similarly convenient roaming experience, but with the trust anchored in Google account protection.
Apple​
Apple’s iCloud Keychain provides seamless passkey sync for Apple ID users across macOS, iOS, and iPadOS; keys are end‑to‑end encrypted and tied to the owner’s Apple ID, with device‑based unlocking required for use. Apple’s integration benefits from tight OS‑level control, but is limited to Apple ecosystems by design.
Microsoft / Edge​
Microsoft’s Edge experiments aim to bring a comparable capability tied to the Microsoft Account and Edge’s sync infrastructure. The difference is the mixed environment: Windows provides strong OS‑level authenticators (Windows Hello + TPM), but Edge must bridge browser, OS, and cloud services in a way that respects both platform guarantees and cross‑platform usage. The vendor that manages sync (Apple, Google, Microsoft) ultimately becomes the custodian of recovery and the guardian of that ecosystem’s threat model. (windowsreport.com, learn.microsoft.com)
Practical guidance: what users and admins should know now​
For enthusiasts and early testers (Edge Canary users)​
  • Canary builds are experimental: these flags are in test code and may change or be removed. Use a secondary profile or machine; do not rely on Canary for critical accounts.
  • If the flags are available, enabling them will add a Passwords and passkeys option under Profiles > Sync. That entry is where Edge shows its intent to surface passkeys with passwords.
  • Test with non‑critical accounts first. Confirm how passkeys are backed up and whether recovery flows (e.g., recovery codes, device backups) are created when you enable roaming. If no clear recovery flow is offered, treat the feature as experimental.
For everyday users​
  • Keep your Microsoft Account protected with strong MFA, preferably a hardware‑backed key (FIDO2) for account sign‑in. If passkey sync is tied to your Microsoft Account, that account becomes the anchor for recovery and access approval.
  • Maintain backup sign‑in methods on critical accounts (a second passkey on another device, or a security key) before you remove old passwords or modify account recovery settings.
For enterprise administrators​
  • Review identity governance: if your organization relies on attestation, attestation lists, or locked AAGUIDs, validate how synced passkeys will interact with existing conditional access and attestation policies. Enterprises should plan pilot groups and document incident‑response actions for lost or deprovisioned devices.
  • Decide policy on cloud‑synced credentials: some regulated environments may prefer device‑bound keys or centrally managed security keys instead of cloud‑backed passkeys. Entra ID and Intune policies will likely need updates to manage lifecycle and revocation.
Implementation details and technical signals to watch​
What the flags imply technically​
  • A browser acting as a passkey provider implies Edge will register and manage passkey metadata and likely host key‑wrapping functionality that ties private keys to the Microsoft Account sync encryption keys.
  • “Management and settings” implies UI that lists passkeys, allows deletion or migration, and exposes per‑credential metadata (origin, storage type — local vs synced). These are the basic ingredients for making passkeys feel manageable to mainstream users.
Important engineering questions still unanswered​
  • Where are keys wrapped and stored? If Edge’s roaming stores an encrypted copy in Microsoft’s cloud, who manages the wrapping keys — Edge client, Microsoft Account service, or TPM‑derived keys? The security model depends on this detail.
  • How is device attestation handled? For enterprise uses that require attestation that a private key is hardware‑backed, will Edge’s roaming preserve attestation semantics, or will it degrade to software‑based protections?
  • Recovery and revocation flows: Clear, auditable flows for revocation and emergency recovery are essential before wide adoption; the current Canary flags don’t fully describe the backend behavior. These topics remain to be demonstrated. (windowsreport.com, learn.microsoft.com)
Broader implications​
For the passwordless transition​
Edge exposing passkeys in the sync UI is one more indicator that browsers and platforms intend to make passkeys the primary credential model for mainstream users. When browsers present passkeys and passwords as co‑equal syncable items, the mental model shifts: passkeys are no longer an exotic developer feature but a routine credential type. This is a necessary step for mass adoption. (windowsreport.com, theverge.com)
For competition and interoperability​
Competition among Apple, Google, and Microsoft around syncing passkeys benefits users: all major vendors are refining UX, backup models, and security protections. The industry is steering toward an interoperable WebAuthn ecosystem, but vendor‑hosted sync models will remain a point of differentiation for years — and a governance challenge for IT teams managing heterogenous fleets. (theverge.com, learn.microsoft.com)
What to watch next​
  • Canary → Dev/Beta migration: If these flags and UI elements survive Canary and appear in Dev/Beta it will show Microsoft is ready to broaden testing with real users.
  • Documentation updates: Look for Microsoft and Edge documentation that clarifies the cryptographic model for roaming (key wrapping, E2EE guarantees, recovery procedures).
  • Enterprise controls: New Intune/Entra policies or administrative controls for passkey lifecycle, attestation enforcement, and revocation are essential prior to wide enterprise adoption. (windowsreport.com, learn.microsoft.com)
Microsoft Edge’s experimental passkey roaming flags in Canary, and the introduction of a combined “Passwords and passkeys” sync control, represent a decisive move to fold passkeys into the browser’s identity surface. This aligns Edge with broader industry trends toward passwordless authentication and positions the browser as not just a conduit for platform authenticators like Windows Hello, but potentially as an independent passkey provider tied to Microsoft Account sync. (windowsreport.com, learn.microsoft.com)
The benefits are clear: improved usability, easier multi‑device sign‑in, and a simpler mental model for users. The risks are also clear: increased reliance on cloud account security, new recovery and attestation complexities, and enterprise governance challenges. Careful product design — transparent cryptographic models, robust E2EE, explicit recovery and revocation flows, and granular admin controls — will be necessary for synced passkeys to deliver convenience without sacrificing the very security gains that make passkeys valuable in the first place. (learn.microsoft.com, windowsreport.com)
Practical next steps are straightforward: security teams should review identity governance and recovery plans, power users should protect Microsoft Accounts with hardware MFA before enabling experimental sync features, and developers should continue to implement WebAuthn flows that respect platform differences while testing for cross‑browser compatibility. The transition away from passwords is underway; Edge’s Canary experiments are one of the clearer signs that passkeys are moving from specialized tech demos into mainstream browser UX. (windowsreport.com, learn.microsoft.com)
Source: Windows Report Microsoft Edge Experiments With Passkey Roaming and Sync Controls
Support hub
