Windows 7 Flash video causing problems
cyrill666
BSOD on AMD Phenom X4 9500 running Windows 7/64bit.
I've had this problem for around a year now, it's very intermittent though, I can be BSOD free for a few weeks, then it'll hit me three of 4 times a day. The common demoninator seems to be web pages with flash content, whether it's music streaming through a flash based player, BBC iplayer viewing or general browsing of web pages with flash ads.
Any advice or tips would be very welcomed.
View attachment minidump.zip
Alright, I spent about 15 minutes looking into things. All of your drivers are now excellent, but what I've noticed is that you are missing SATA, RAID and audio drivers for some unknown reason.
Install this in the normal method by simply running the .exe:
NVIDIA DRIVERS 15.49 WHQL
Then install this for the audio:
See how it goes and good luck.
Welcome.
1) Completely uninstall LogMeIn.
2) Update NVIDIA network driver:
nvm62x64 nvm62x64.sys Fri Oct 17 17:01:06 2008
The easiest way to do so is to download the latest chipset package for the HIGHEST nForce series available. Extract. Go into network folder. Copy the nvm62x64.sys driver and paste it over the one at C:\Windows\System32\drivers
Link Removed - Invalid URL
Reboot.
3) Navigate to C:\Windows\System32\drivers. Delete this then reboot:
pcouffin pcouffin.sys Tue Dec 05 09:39:30 2006
4) Update Wacom drivers from their site:
wacommousefilter wacommousefilter.sys Fri Feb 16 13:12:17 2007
Enjoy.
Thanks for the fast response, it's very much appreciated.
I removed LogMeIn and updated my network driver as requested. Then deleted pccouffin.sys - I couldn't upgrate the Wacom mouse driver as there doesn't appear to be a new one (I installed new Wacom drivers, but the mouse driver remained the same - so I renamed the file to keep it out of the test).
This seemed to work for a while, but after 30 minutes or so hammering YouTube it happened again, I've attached the last minidump - is there anything else you recommend?
View attachment 122310-18532-01.zip
Thanks for you time,
Gary.
Yep, uninstall Boinc:
Debugging Details:
BUGCHECK_STR:  CLOCK_WATCHDOG_TIMEOUT_4_PROC
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  boinc.exe
CURRENT_IRQL:  d
And then navigate to C:\Windows\SysWow64\drivers and delete this old one I missed before:
Afc Afc.sys Wed Jul 12 01:48:20 2006
Reboot.
You're welcome.
Looking over all the drivers, the only one that would be likely to cause the CLOCK_WATCHDOG_TIMEOUT errors which all of your crashes have been, is this one:
wacomvhid wacomvhid.sys Mon Sep 21 19:29:14 2009
You can rename that to .BAK to test.
It is also a great idea to update the motherboard bios to newest.
And there is a 2010 version for this driver:
nvm62x64 nvm62x64.sys Thu Jul 30 19:48:18 2009
Another driver to rename to .BAK to test with would be:
srvnet srvnet.sys Thu Aug 26 23:37:24 2010
I renamed wacomvhid.sys and srvnet.sys.
I couldn't find a 2010 version of nvm62x64.sysfor windows7/64bit?
I'm also already running the latest mobo bios as supplied by ECS.
Still blue screening though :(
View attachment 122410-15397-01.zip
Thanks for your help.
Thanks for you help and time on this, unfortunately nothing worked, I continued to experience regular blue screens (several per day) - so I eventually bit the bullet and reinstalled a 32bit version on Windows7 - this seems to be stable at the moment with no blue screens at all.
Happy New Year... <:-P
