Windows 7 Folder has shortcut to Itself inside and will not delete
ChristopherS
Hi all,
I solved my own problem but I thought that I would post the solution here. I did not see anything on the net for the issue I was having but I am sure it comes up from time to time.
I accidentally created a shortcut inside a folder to itself. I was clicking on the file path at the top and BOOM, suddenly there was a shortcut to the folder INSIDE the folder!
When I went to delete the shortcut the system went into an infinite loop and just kept saying ...deleting....
I tried chkdsk and safe mode but neither worked. Same problem with the infinite delete.
I finally shared the folder out to my network, logged off my system, went to another system and deleted the shortcut from the folder. I figured that the network access, since it does not use the recycle bin, is enough different to allow for the short cut to be deleted.
It worked.
I tried to recreate your problem. Created a folder and then a shortcut of that folder inside the folder itself. The shortcut deleted fine.
I just recreated the exact same problem on two other systems. Caused the same error. Don't know why it deleted fine from your system.
