ARNK
Active Member
I'll keep this brief because Windows has wasted a fair portion of my life for various reasons.
Is there no utility that cuts through the stupidity of not being able to TURN OFF "Read-only" folders and files contained within MY file system FORCING them to STAY write-able?
I ask about a utility because 1000 articles outlining 20 ridiculous steps to fix the problem that works for a handful of magical people, but never works for most of us only exist to infuriate people trying to save files where they cannot.
So believe me when I tell you I've followed the steps, I've tried the command line directives, I've eliminated/uninstalled Bitdefender or any other security app that might be blocking my attempts. Unchecking Read-only and hitting apply does NOTHING. Nothing at all, much like the countless articles written by people from where I do not know their origin. Something tells me it's a bit of an inside joke by a handful of piss takers employed by Microsoft.
Rant over, at least in this post box.
Thank you.
Dealing with read-only files and folders in Windows can be frustrating, especially if the conventional methods don't work as expected. Here are some alternative solutions and tools that may help you with your issue:
Third-Party Tools:​
  • TakeOwnership: Third-party tools like the "TakeOwnership" registry script can help you take ownership of files and folders. This script simplifies the process of taking ownership and managing permissions. You can find this script online to download and use.
  • File Unlocker Tools: There are tools like "LockHunter" or "Unlocker" that can help you unlock and delete files that Windows normally won't allow you to due to being in use or having read-only attributes.
    Command Line:​
Third-Party Tools:​
    Command Line:​
  • Attrib Command: You can try using the command line tool "attrib" to change file attributes. For instance, attrib -r +s yourfile.jpg removes the read-only attribute.
  • CACLS Command: The "cacls" command can alter file permissions, including the read-only attribute. Running cacls file.txt /E /P everyone:F can grant full permissions to "everyone" on "file.txt".
    Safe Mode:​
  • Access in Safe Mode: Booting into Safe Mode and trying to change the file attributes might help, as certain processes or applications might prevent changes in normal mode.
    Disk Cleanup:​
  • Disk Cleanup: Running disk cleanup utility can sometimes fix file system-related issues on Windows.
    Professional Assistance:​
  • Professional Support: If the issue persists, seek professional IT support or consider reaching out to Microsoft Support for further guidance and potential solutions. Please be cautious when using third-party tools and ensure they are from reputable sources to avoid any security risks. Additionally, always back up important data before attempting any modifications to your file system to prevent data loss.
