Sean1082
I am having troubles running things like FireFox 32-bit and Internet Explorer 32-bit UNLESS I stop all 32-bit programs currently running by going into Task Manager >> Processes. Only then am I able to run IE and FF 32-bit.
I don't know if any of you are familiar with the program Steam, but it to is affected by this issue. Although Steam itself runs fine, I cannot run any games using it. I am running Windows 7 Home Premium 64-bit (Upgrade kit I got when I bought my PC)
Although this temp fix works just fine, I would like to get this figured out.
Thanks.
EDIT: This is the process that is creating the issue "HsMgr.exe" Am I able to simply delete this from the Windows Folder? Or is this an important program? Couldn't find too much on Google.
It seems like you are experiencing an issue where you are unable to run 32-bit programs like Firefox, Internet Explorer, and games through Steam unless you stop all 32-bit programs running in Task Manager. This is an unusual problem, and it might be related to certain processes conflicting with these applications. The process "HsMgr.exe" you mentioned could potentially be related to this issue. However, before taking any action, it's essential to identify what "HsMgr.exe" is and whether it is safe to remove. Here are some steps you can take to investigate and potentially resolve this issue: 1. Identifying "HsMgr.exe": - Try to locate the file "HsMgr.exe" in your Windows folder or any other location it might be present. - Check the...
It seems like you are experiencing an issue where you are unable to run 32-bit programs like Firefox, Internet Explorer, and games through Steam unless you stop all 32-bit programs running in Task Manager. This is an unusual problem, and it might be related to certain processes conflicting with these applications. The process "HsMgr.exe" you mentioned could potentially be related to this issue. However, before taking any action, it's essential to identify what "HsMgr.exe" is and whether it is safe to remove. Here are some steps you can take to investigate and potentially resolve this issue: 1. Identifying "HsMgr.exe": - Try to locate the file "HsMgr.exe" in your Windows folder or any other location it might be present. - Check the properties of the file to see if you can identify its origin or purpose. - Use online resources like VirusTotal to scan the file and see if it is flagged as malicious. 2. Verifying Program Legitimacy: - Check if "HsMgr.exe" is associated with any legitimate software installed on your system. It's crucial to ensure you are not deleting a part of a necessary application. 3. Disabling "HsMgr.exe" for Testing: - You can try disabling "HsMgr.exe" temporarily to see if it resolves the issue with running 32-bit programs and games through Steam. This can be done through Task Manager or by changing its startup settings. 4. Further Troubleshooting: - If disabling "HsMgr.exe" resolves the issue, you can consider researching further to understand its function and whether it is safe to permanently remove. - If the issue persists even after disabling or removing "HsMgr.exe," you may need to investigate other potential causes such as system conflicts or software compatibility issues. Deleting system files without understanding their purpose can lead to system instability or malfunctions. It's always recommended to proceed with caution and ensure you have appropriate backups before making significant changes to your system. If you need further assistance or clarification on any step, feel free to reach out.
