Please provide this info for a complete analysis:
The memory dump suggests that there might be problems with your eamon.sys driver - this is a part of your NOD32 antivirus.
Please:
- Download a fresh copy of the program
- Un-install the current copy of the program
- Install the freshly downloaded copy
- Update your virus definitions and perform a full system scan
- monitor for further BSOD's
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Win7 systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions).
Please un-install the program,
then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration):
[DEL] Link Removed [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012):
Link Removed (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link:
Disc-Tools.com
Manual procedure here:
Link Removed - Invalid URL
Many of your drivers are older (and may not be compatible with Win7 SP1).
mdmxsdk.sys Mon Jun 19 17:27:26 2006 (449716BE)
Conexant Modem Diagnostic Interface x86 Driver
SjtWinIo.sys Tue May 20 04:17:17 2008 (4832890D)
SpeedJet Technology
ewusbmdm.sys Fri Dec 12 22:28:19 2008 (49432BD3)
USB Modem/Serial Device Driver - "Huawei Mobile Connect" package
CAX_CNXT.sys Fri Feb 13 16:19:32 2009 (4995E3E4)
Conexant Modem
CAXHWAZL.sys Fri Feb 13 16:20:54 2009 (4995E436)
Conexant Modem
CAX_DPV.sys Fri Feb 13 16:24:50 2009 (4995E522)
Conexant Modem
NTIDrvr.sys Tue Mar 24 23:09:39 2009 (49C9A073)
NTI CD-ROM Filter Driver by NewTech Infosystems (likely a part of Acer Empowering Technology)
DKbFltr.sys Wed Mar 25 23:15:42 2009 (49CAF35E)
Dritek Keyboard Filter driver
UBHelper.sys Mon Apr 27 04:48:19 2009 (49F57153)
NTI CD &DVD-Maker or NTI Backup NOW! or NTI CD-Maker by NewTech Infosystems (usually in Acer Empowering Technology)
mwlPSDFilter.sys Tue Jun 2 06:07:30 2009 (4A24F9E2)
EgisTec Inc. Fingerprint Biometrics
mwlPSDNServ.sys Tue Jun 2 06:07:39 2009 (4A24F9EB)
mwlPSDVDisk.sys Tue Jun 2 06:15:29 2009 (4A24FBC1)
k57nd60a.sys Sun Jun 7 03:36:34 2009 (4A2B6E02)
Broadcom NetLink Gigabit Ethernet NDIS6.x Unified Driver
ATSwpWDF.sys Fri Jun 26 16:08:01 2009 (4A452AA1)
Swipe Fingerprint Sensor USB Driver AuthenTec, Inc.
iaStor.sys Fri Aug 7 08:23:37 2009 (4A7C1CC9)
Intel Storage drivers
nvhda64v.sys Fri Aug 21 16:23:50 2009 (4A8F0256)
nVidia HDMI Audio Device (nForce chipset driver)
SynTP.sys Thu Sep 3 20:33:28 2009 (4AA06058)
Synaptic Touch Pad Driver
HECIx64.sys Thu Sep 17 15:54:16 2009 (4AB293E8)
Intel Management Engine Interface
TurboB.sys Tue Sep 29 20:25:28 2009 (4AC2A578)
Intel Turbo Boost driver
athrx.sys Mon Oct 5 12:33:57 2009 (4ACA1FF5)
Atheros network adapter driver
Impcd.sys Mon Oct 12 22:00:51 2009 (4AD3DF53)
Intel(R) Turbo Boost Technology Driver
RTKVHD64.sys Tue Oct 13 05:39:34 2009 (4AD44AD6)
Realtek High Definition Audio Function Driver
nvBridge.kmd Sat Oct 31 03:20:17 2009 (4AEBE531)
nVidia Compatible Vista Kernel Mode Driver (likely belongs to nForce chipset drivers)
nvlddmkm.sys Sat Oct 31 03:51:02 2009 (4AEBEC66)
nVidia Video drivers
Analysis:
[font=lucida console]**************************Fri Sep 28 13:51:30.680 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092912-68000-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17835.amd64fre.win7sp1_gdr.120503-2030
System Uptime:[B]0 days 11:09:36.272[/B]
BugCheck Code: [B]BugCheck 19, {20, fffffa8005356820, fffffa8005356a60, 4240004}[/B]
*** WARNING: Unable to verify timestamp for eamonm.sys
*** ERROR: Module load completed but symbols could not be loaded for eamonm.sys
Probably caused by :[B]eamonm.sys ( eamonm+75e5 )[/B]
BugCheck Info: [B]BAD_POOL_HEADER (19)[/B]
BUGCHECK_STR: 0x19_20
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
PROCESS_NAME: [B]iexplore.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x19_20_eamonm+75e5[/B]
CPUID: "Intel(R) Core(TM) i5 CPU M 430 @ 2.27GHz"
MaxSpeed: 2270
CurrentSpeed: [B]2260[/B]
BIOS Version V1.03
BIOS Release Date 12/02/2009
Manufacturer Acer
Product Name Aspire 4740
[/font]
3rd Party Drivers:
[COLOR=RED][B]mdmxsdk.sys Mon Jun 19 17:27:26 2006 (449716BE)[/B][/COLOR]
[COLOR=RED][B]SjtWinIo.sys Tue May 20 04:17:17 2008 (4832890D)[/B][/COLOR]
[COLOR=RED][B]ewusbmdm.sys Fri Dec 12 22:28:19 2008 (49432BD3)[/B][/COLOR]
[COLOR=RED][B]CAX_CNXT.sys Fri Feb 13 16:19:32 2009 (4995E3E4)[/B][/COLOR]
[COLOR=RED][B]CAXHWAZL.sys Fri Feb 13 16:20:54 2009 (4995E436)[/B][/COLOR]
[COLOR=RED][B]CAX_DPV.sys Fri Feb 13 16:24:50 2009 (4995E522)[/B][/COLOR]
[COLOR=RED][B]NTIDrvr.sys Tue Mar 24 23:09:39 2009 (49C9A073)[/B][/COLOR]
[COLOR=RED][B]DKbFltr.sys Wed Mar 25 23:15:42 2009 (49CAF35E)[/B][/COLOR]
[COLOR=RED][B]UBHelper.sys Mon Apr 27 04:48:19 2009 (49F57153)[/B][/COLOR]
[COLOR=RED][B]mwlPSDFilter.sys Tue Jun 2 06:07:30 2009 (4A24F9E2)[/B][/COLOR]
[COLOR=RED][B]mwlPSDNServ.sys Tue Jun 2 06:07:39 2009 (4A24F9EB)[/B][/COLOR]
[COLOR=RED][B]mwlPSDVDisk.sys Tue Jun 2 06:15:29 2009 (4A24FBC1)[/B][/COLOR]
[COLOR=RED][B]k57nd60a.sys Sun Jun 7 03:36:34 2009 (4A2B6E02)[/B][/COLOR]
[COLOR=RED][B]ATSwpWDF.sys Fri Jun 26 16:08:01 2009 (4A452AA1)[/B][/COLOR]
intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
amdxata.sys Fri Mar 19 12:18:18 2010 (4BA3A3CA)
mbrguard.sys Thu Jun 10 20:07:39 2010 (4C117E4B)
tap0901.sys Thu Mar 24 17:20:03 2011 (4D8BB583)
eudskacs.sys Fri Aug 5 12:48:51 2011 (4E3C1EF3)
eubakup.sys Fri Aug 5 12:48:55 2011 (4E3C1EF7)
EUBKMON.sys Fri Aug 5 12:49:18 2011 (4E3C1F0E)
EuFdDisk.sys Fri Aug 5 12:49:22 2011 (4E3C1F12)
a09hv9ct.SYS Tue Dec 27 17:30:45 2011 (4EFA4715)
[COLOR=RED][B]sptd.sys Sat Mar 3 11:45:52 2012 (4F524AC0)[/B][/COLOR]
EpfwLWF.sys Wed Mar 7 09:28:51 2012 (4F5770A3)
epfwwfp.sys Wed Mar 7 09:28:51 2012 (4F5770A3)
epfw.sys Wed Mar 7 09:28:53 2012 (4F5770A5)
eamonm.sys Wed Mar 7 09:32:36 2012 (4F577184)
ehdrv.sys Wed Mar 7 09:33:42 2012 (4F5771C6)
brnfilelock.sys Mon May 7 17:07:57 2012 (4FA839AD)
cfosspeed6.sys Mon Jul 2 10:14:18 2012 (4FF1ACBA)
SbieDrv.sys Sat Aug 25 16:27:46 2012 (50393542)
idmwfp.sys Sun Sep 23 18:12:31 2012 (505F894F)
[/font]
mbrguard.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
a09hv9ct.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
brnfilelock.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
