Windows 8 Help! No sound in windows 8!
Mazinombies
Sorry if this has been asked before, but all the quick searches i looked at were all for windows 7!
Starting as of a few hours ago, my computer just stopped recognizing my headphones. When I unplug them, and plug them back in they are not recognized. I have restarted my computer a couple of times now, but to no avail. There is also a small icon on the taskbar, which looks like the volume icon, but with a red cross through it.
Any help would be appreciated!
Hi
And if just reinstalling the driver doesn't work, try uninstalling your sound device in Device Manager and rebooting.
The will force Windows to reinstall and reconfigure your sound settings to the default setup.
Mike
MikeHawthorne
Hi
Mike
ussnorway
Windows Forum Team
is this the image?...
An image from 'Help! No sound in windows 8!'. A young woman looks shocked or scared, partly obscured by red-framed glasses.
...note that this one is mute which is not the same thing as driver missing.
MikeHawthorne
Hi
Right click on that Icon, you should get a menu that will let you Check the Volume, and Troubleshoot Sound Problems.
As Ussnorway suggested your sound may just be muted.
Mike
