help, WIN 7 BSOD
hi, i'm apheng.
This problem started last week. BSOD occurs repeatedly. I tried to reinstall windows installed a (clean install), but the same problem occurs again, the BSOD happens over and over again. I've also tried chkdsk and memtest but did not find any error. please help. thank you
spec
Proc - Intel Pentium DualCore 2,2 GHz
Chipset - Mobile Intel GL40 Express Chipset
Graphic - Intel GMA 4500M HD hingga 828Mb Shared, ATI Radeon HD5145GPU 512Mb
Display - 14" WXGA 1366 x 768 piksel, HD LED Backlight (16:9) with clear superview teknologi
Memory - 1GB RAM DDR2 Standart hingga 4GB
Storage - 320GB/500GB SATA with shock absorbers
Optical Drive - DVD-R/W Super Multi Double Layer
Koneksi - Wi-Fi 802.11 b/g/n, Bluetooth (Optional), LAN 10/100Mbps, 56Kbps Modem
Port - 2xUSB 2.0, 1xHDMI, 1xVGA Port, 4-in-1 Card reader, 1xRJ45
camera - Built in web kamera with smart face technology
Battery - 6 cell Lithium-ion
Windows Forum Admin
Microsoft MVP
BugCheck 124, {0, 85007024, b2000040, 800}
Probably caused by : GenuineIntel
Followup: MachineOwner
most of your dump files were like the above which usually means a hardware error occurred. Typically we see this bugcheck when someone has been overclocking and the CPU is overheating. I'm not saying your overclocking but could it be that the lappie is overheating? Ensure all vents are clear from any dust or build up. Monitor your temps using this app:
http://www.cpuid.com/softwares/hwmonitor.html
check your CPU is ok by running this diagnostic tool from Intel:
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool-64-bit-
Windows 7 Kernel Version 7600 MP (2 procs) Free x86 compatible
These figures tell us that your missing a service pack which contain critical updates. Please download and install SP1:
http://www.microsoft.com/en-gb/download/details.aspx?id=5842
Any problems installing the service pack may mean you need to install the readiness tool:
http://www.microsoft.com/en-gb/download/details.aspx?id=3132
Does the bsod happen when you do something particular or just random?
Thank you for your response.
bsod most often happens when I turn on internet connection. while not connecting to internet, bsod rarely occurs. when browsing, using chrome or firefox, bsod persists. thank you
Windows Forum Admin
Microsoft MVP
have you made sure your browsers,flash player and network driver are the latest versions? You might not be able to update the network driver as your limited to what the manufacturer releases driver wise. Looking at your machines support page (please check I have the correct one) it doesn't appear to be an update available.
http://support.toshiba.com/support/modelHome?freeText=2464743
See how you go updating with the service pack and if you could post the results of your temps that would be great.
