Windows 7 How to directly (!) call printer preferences for printer X?
pstein
Assume I installed previously some printer (drivers) for physical and PDF printers.
They work.
I can access the preferences of e.g. printer X by:
START--->Control Panel--->Devices and Printers--->Right click on Printer X---->printing preferences from context menu
But: Is there a way to access this printer preferences dialog DIRECTLY?
I want to create.e.g. a shortcut to printer-something *.exe or *.cpl and get immediately the dialog window.
How does that work?
Peter
Sure you can do that with a shortcut..
The command would be
RUNDLL32 PRINTUI.DLL,PrintUIEntry /e /n PRINTER_NAME
Just replace PRINTER_NAME with the name of the printer you would like to see preferences for. If the printer name contains spaces then make sure to use quotations.
An example:
RUNDLL32 PRINTUI.DLL,PrintUIEntry /e /n "Ricoh Aficio CL7300DT"
Josephur
Windows Forum Admin
An example:
