Derbyman32
- Joined
- Jan 15, 2009
I was trying to set up a dual boot windows 7 with vista and was using a partition software and I mistakenly formated the 1st partition on my hard drive. It was a small partition of 1.5 MB and I think that is where the MBR was installed? Anyway after that I tried to fix the problem and as far as I could get was to the repair computer on the windows 7 installation disk. It came back saying computer could not be repaired by it. I tried other rescue CD's I had made over the years but nothing would let me repair my error and reinstall windows. I then (out of desperation) tried to boot from a Ubuntu CD I had made but never used. This worked and I was able to install Ubuntu to my system. To my suprise that part went very smoothly.
The problem is that I don't understand Linux at all yet. What I would like to do is somehow get windows 7 or vista to install and dual boot keeping Ubuntu to learn from.I tried various fixes using fixmbr etc but all I did was corupt my Ubuntu install and I had to reinstall Ubuntu to have a working computer
Can anyone point to any information on fixing my problem so that I can reinstall windows 7 and if possible keep Ubuntu. Or if I can't keep both then tell me how to fix windows 7 mbr so that I can install it again.
Thanks in advance for any info that you guys can give
Derbyman32
Hi, I was able to accomplish the dual boot and everything is now good thanks
Derbyman32
