Windows 7 Missing send to > desktop shortcut.
LeanBack
I have a problem. My send to > desktop shortcut link is missing.
This is my shell:sendto folder;
I got Desktop (create shortcut).DESKLINK file, but in the send to menu its gone. I can't use it.
Hi, just found this thread.
I have the same problem and have tried everything suggested. The file Desktop (create shortcut).DeskLink (1KB) exists in my send to folder and now I have yours, Desktop.DeskLink (0 KB). Neither show up when I right click. I have also tried copying the one from the Default profile. That did not help either.
If you set your system to see both hidden and system files, you should be able to see a Desktop.ini in the Send To folder. If you right click and select edit, you will be able to read it. Could you compare it to what is listed below.
[LocalizedFileNames]
Mail [email protected],-4
Desktop (create shortcut)[email protected],-21
Compressed (zipped) [email protected],-10148...
To Saltgrass
Did sfc /scannow. Results were 100% OK
Recap:
"normal" Send To context Menu should look like this:
Link Removed - Invalid URL
My Send To context Menu contains entries as follows:
notepad
Secure delete
Unlocker
DVD RW Drive(D:)
Tested Send To to NOTEPAD with a doc file, a txt file and a jpg file. Send To works for all entries (I did not test unlocker)
I could remove the entries, but I do not think they are doing any harm.
My (shell:sendto) sendto folder contains:
Here I do not see anything to do with a DVD, although this does work. And I also see the Desktop (create shortcut) and Documents.mydocs, both of which do not appear in the context menu.
The Desktop (create shortcut) entry is new (date 10/06/2009), created from the procedure suggested by whs (I´ve tried this one several times in the past!) as is the documents entry (date 21/11/2011), also created from that procedure.
The DEFAULT and DEFAULT USER sendto folders look like this:
All Desktop.ini files are the same.
I have 3 users showing up in the Properties/security view, all have full control. The owner of NOTEPAD and DESKTOP is Administrator, the owner of compressed Folder is PeterN (me=Administrator).
That´s about all I can find on the subject.
