Windows 10 Monitor won't start
Sonny
Fantastic Member
I have been having a problem with my monitor not turning on when computer has been shut down, in hibernate or sleep mode for more than two hours. To get it to work I have to hit the reset button. Once on it will work fine as long as I live the computer on.
I have tried to fix it by unplugging the power cord and pulling the cmos battery out. I would wait about a half hour before turning it back on. No luck. It didn't work.
My motherboard is a MSI B75MA-P45.
Any Ideas on how to fix it?
Not sure if I posted this in the right place but have Windows 10 build 10041 as my operating system.
Hi davehc, It is working. After doing what Saltgrass said about unplugging and letting the monitor reset itself it worked. I am going to disable hibernate since I never use it anyway. Thanks for the command to do that.
Sonny
Fantastic Member
It is an ASUS 24". It is about two years old.
Sonny
Fantastic Member
I don't think the monitor settings had anything to do with it but went ahead and reset all of them.
Saltgrass
You might try unplugging the monitor and letting it sit, perhaps overnight. Maybe it needs resetting.
I had a situation with my triple monitors where the left one would not show the power light. I thought possibly it has just gone out, but after letting it sit unpowered overnight, the power light was working again. This has only happened with Windows 10, so it could be involved.
Sonny
Fantastic Member
Thank you Saltgrass. I will do that and see what happens. It can't hurt to try. Nothing else seems to work.
davehc
Try, in power settings, changing the hard disk setting to "never" Worked for me. But the hibernate feature gives me problems. I usually turn it off.
Sonny
Fantastic Member
Hi Dave, I don't know if I got the right one. If I did, it didn't have never but said do nothing when shutting down.
Sonny
Fantastic Member
This the setting I changed.
An image from 'Monitor won't start'. Windows Control Panel showing power button and sleep button settings with password and shutdown options.
davehc
This one:
An image from 'Monitor won't start'. Settings show hard disk power-off times: 10 min on battery, never when plugged in.
Sonny
Fantastic Member
Ok, I unplugged the monitor like Saltgrass suggested, would have done what Davehc said but don't have laptop. Made a couple of bios changes in graphics. I will see what happens in the morning as to how it is going to work. I did shut it down for about two hours and it worked ok.
davehc
Great. Sorry, I forgot the laptop/stationery issue!
If you still have the same problem, consider the hibernate fix, if you feel you could do without it. For info:
Open an Elevated Command Prompt.
To Disable Hibernate -
type powercfg -h off and press Enter.
To Re enable Hibernate - type powercfg -h on and press Enter.
Close the elevated command prompt. and reset your Power Plan settings to the recommended settings for Hibernate
Sonny
Fantastic Member
