felixkeaton
Hello,
I need help! I have no idea about the BSOD.
My laptop is crashing everytime i use Ableton Live Lite 8.
It usually happens when im using VST plugins.
When i use BLUESCREENVIEW it says ntoskrnl.exe and stdriver64 are causing the crash.
Can anyone tell me step by step what i need to do to resolve this problem
Windows 7 64bit Premium
Samsung RF511 laptop
Intel Core i5
8Gb Ram
Scarlett 2i2 audio interface
Novation Impulse Controller Keyboard
Uninstall SoundTap. Then download and install a fresh copy of the latest Win7 compatible version from the SoundTap website: Record Streaming Audio - Streaming Audio Capture Software
If that doesn't fix things, then please provide this information for a detailed analysis: Link Removed
Ok So i've done that but now when i go to select the audio interafce in the preferences in Ableton i get this screen
Assertion Failed
Program
File: f:\tmp\build-tmp-2528-\proj\asiodriv\asio_driver.cpp
Line538
While waiting to have the uploaded reports analyzed - please un-install Ableton and reinstall a freshly downloaded copy (I presume that SoundTap comes as a part of it?)
Assertion Failed
Program
Line538
i have Windows 7 64bit ultimate
kraun desktop
Intel 2 Core quad
4Gb Ram
and i am experiencing the same error.
all the applications that needs to control the Scarlett audio interface are crashing with this error (amplitube, presonus studio one, overloud th2)
i tried to reinstall both applications and sound drivers, but nothing canged...
the only application that doesn't crash is presonus studio one x64...
did you resolved the problem? can you please tell me how?
i am about to format everything...
thanks
