Windows 8 Please help BSOD - 0xa000001
MrOnizuka
I had the issue with screen freeze with automatic turn off monitor. It crashed when i try to wake my screen back.
Recently I had error with blue screen of dead with code 0xa00001. please help me to slove this error.
PS: sorry for my bad english
Hi Mr Onizuka,
you may have some corrupt windows files. Look in the Start menu for command prompt. Right click on it and choose properties. Click 'Run as admin' and type:
sfc /scannow
Press enter and await results.
BugCheck 109, {a3a01f589fac1b8a, b3b72bdef22b0861, fffff80000321bf8, 1}
Probably caused by : memory_corruption
Followup: memory_corruption
of the two dump files sent, one as you know was 0xA00001 which is quite a rare bugcheck specifically for AMD GPU's and drivers. The above bugcheck occurs when a corrupt process has tried to take place and could be RAM, data or drivers.
Norton AV is also known for causing issues. Please remove and install MSE which is very stable:
Please uninstall your AMD GPU drivers using this application:
That will remove anything left behind by previous installations. Install latest driver release:
If after making the above changes bsod continues check your RAM using this application:
http://www.memtest.org/
Please post any new dump files.
MrOnizuka
Dear Kamical. There is no more BSOD but there are some freeze screen after monitor turn off.
I set never turn off hard disk, never turn off usb, and never sleep or hibernate but only set turn off monitor after 20mins.
Once my monitor turn off i couldn't wake my computer back and need to push restart button. Please advise me.
Maybe because i set alarm from Link Removed this may be the cause of my frozen screen
Thank you so much for your help
Hi Mr Onizuka,
sfc /scannow
MrOnizuka
Dear Kemical
This is the result.
Windows Resource Protection found corrupt files but was unable to fix some
of them. Details are included in the CBS.Log windir\Logs\CBS\CBS.log. For
example C:\Windows\Logs\CBS\CBS.log. Note that logging is currently not
supported in offline servicing scenarios.
I also attach the csb.log as enclosed
Looking at the CBS logs I don't think the files that were not fixed are critical. It does look like many files were repaired however does the machine still exhibit the same issue?
