warri0r19
Member
This is a carry on from this thread as I was told I should come here.
To put it simply, I started having regular BSODs since I installed my GTX 780, I was pretty confident that it was just a driver issue, and decided I would be sending it back as I didn't want the hassle (tried lots of things).
Today I got a BSOD with my hd 6790's, which is making me think maybe it wasn't a problem with my 780. All my BSODs relate to ntoskrnl.exe.
Attached the necessary files.
note: only the 010614-5734-01 dump file related to my current gpus. The other dump is from when I had my 780. If you goto the other thread I linked at the top there are other dump files available.
Please tell me if I need to add or edit something, thanks :)
Quick note:
I have a few hours (tops) to contact the seller of the 780 and cancel the return, if this problem isn't infact related to the nvidia card afterall, I would rather keep it.
Thanks for the info I'll check it up. I'm currently working through some ideas based on your recent dmp files and will post shortly. As for the RAM just do a pass on each stick if your short for time.
Edit: This app will apparently keep your SSD up to date regarding firmware etc:
Just had a thought... I'd forgotten that one of the top guy's in that forum is actually a member here in our forum. I'll pm him a message and hopefully he'll have a look see.
That's great, what with my pm and your post hopefully the issue will be picked up soon.
warri0r19
Member
Yeah :)
Hopefully I can get one of my dads friends to test out my gpu in a build of his, he's the kinda guy that would most likely nail whether or not I have a faulty gpu.
I just got another 'black screen' This is the third or fourth time it's happened. My screen went blank and my bios splash screen came up, then booted into windows normally.
