- Thread Author
- #1
So I'm new to the forum, and I was hoping you guys can help me with a problem I have with one of my laptops. So the laptop I'm having trouble with is the one I use for fiction writting and I'm worried that if I dont get help or find out what's happening all my work will get deleted. So the problem I am having is from time to time my screen like has a defect, it goes crazy it starts to flicker. I usually move the screen and it stops flickering, but at times it takes a couple minutes to come back to normal. I heard that it's usually a loose wire, which I am thinking it is because I reaaly dont handle with care my laptop. It's chipped from the top right side of the side screen and I also noticed It's missing a screw in the sides. Any help guys? If it helps I'm a try to upload some pictures tommorow. Any help is greatly appriciated.
