Windows 7 Shortcut problem and position
Marios
Active Member
Can i change a position of a shortcut on Windows 7 inside a folder that is been used as program execution place on the screen desktop? If yes then how? Also when i create a shortcut from a link on the internet, the shortcut has is own icon from the company on the internet but when i store it in a folder on desktop, a globe
icon appears (a windows 7 default icon). What should i do to fix it?
To change the position of a shortcut within a folder on your Windows 7 desktop and customize its icon, you can follow these steps:
Changing Shortcut Position:​
  • Open the Folder: Navigate to the folder on your desktop where you want to change the position of the shortcut.
  • Rearrange the Shortcuts: Click and drag the shortcut to move it within the folder. You can place it in a desired position by dragging it to the spot you want.
Customizing Shortcut Icons:​
  • Changing Shortcut Icons:
  • Right-click the Shortcut: Right-click on the shortcut for which you want to change the icon.
  • Select "Properties": Choose "Properties" from the context menu.
  • Change Icon: In the...
  • Change Icon: In the Properties window, go to the "Shortcut" tab and click on the "Change Icon" button.
  • Choose an Icon: Browse for the icon you want to use or select from the available options.
  • Apply and Save: After selecting the new icon, click "OK" to apply the changes.
Fixing Icons for Internet Shortcuts:​
  • Download Favicon: For Internet shortcuts, the icon displayed is usually the website's favicon. To get the proper website icon:
  • Visit the Website: Open the webpage the shortcut is linked to.
  • Copy the URL: Copy the URL of the webpage from the address bar.
  • Convert to Shortcut: Right-click on the desktop, choose "New," and then "Shortcut."
  • Paste URL: Paste the URL and complete the wizard. This will create a new shortcut with the correct website icon.
  • Organize: Move the new shortcut into the desired folder. By following these steps, you can adjust the position of shortcuts within a folder on your desktop and customize their icons to suit your preferences.
