system restore in safe mode
Peterr
I finally got this but wondered if you have a better way. Instead of msconfig I chose safe mode but could not find system restore. I clicked recovery on the bottom left.
I hope this helps someone else and if you have a better way please let me know. To begin I used shift and restart. BTW, there is an option along the recovery route that seems to put system restore in an isolated environment. I have not tested that one = security>update>adv till you see system restore.
It sounds like you accessed the recovery options in Windows 10 to try and use System Restore. If you're looking for alternative methods to access System Restore or other recovery options, here are a few more ways to do it: 1. Using Recovery Options: - Press Windows Key + I to open Settings. - Go to Update & Security. - Click on Recovery from the left pane. - Under Advanced Startup, click Restart Now. - Choose Troubleshoot > Advanced Options > System Restore. 2. Using Control Panel: - Press Windows Key + S, type Control Panel, and hit Enter. - Go to System and Security > Security and Maintenance. - Click Recovery from the left pane. - Open System Restore. 3. Using Run Prompt: - Press Windows Key + R to open the Run...
It sounds like you accessed the recovery options in Windows 10 to try and use System Restore. If you're looking for alternative methods to access System Restore or other recovery options, here are a few more ways to do it: 1. Using Recovery Options: - Press Windows Key + I to open Settings. - Go to Update & Security. - Click on Recovery from the left pane. - Under Advanced Startup, click Restart Now. - Choose Troubleshoot > Advanced Options > System Restore. 2. Using Control Panel: - Press Windows Key + S, type Control Panel, and hit Enter. - Go to System and Security > Security and Maintenance. - Click Recovery from the left pane. - Open System Restore. 3. Using Run Prompt: - Press Windows Key + R to open the Run dialog. - Type rstrui.exe and hit Enter. - This directly opens the System Restore window. 4. Using Command Prompt: - Open Command Prompt as an administrator. - Type rstrui.exe and hit Enter. 5. Using Search: - Click on the Windows Search box next to the Start menu. - Type System Restore and click on it to open. If you're specifically looking to perform a System Restore, any of these methods will take you to the System Restore utility, allowing you to choose a restore point to revert your system back to a previous state.
Support hub
