Windows 7 Taskbar problem
ProParkour
Normally I have my taskbar settings set to Never combine. Which is fine except for today when I turned on my computer whenever I opened a program the program would fill the entire taskbar. Does anyone have any clue why this would happen. Note that I didn't install any programs.
You are right, it is with every program that I open. I have tried changing the settings but that has had no effect. I will try a cold boot now though.
Problem solved. Apparently Auslogics changed some of my settings. Sorry for the hassle
Are you running any special toolbars? I will assume the program pictured is not the only icon that does this.
Have you done a cold boot lately? Maybe change the combine setting in the properties then change it back later.
Also make sure you do not ...snip
OK, I now see the problem has been solved.....
