- Thread Author
- #1
I have an Acer M5640 desktop. I want to upgrade (32 bit) to Windows 7.The Windows 7 Upgrade advisor tells me that I have a program named ATI Catalyst Install Manager that should be uninstalled before the upgrade and then installed again after the upgrade. I'm confused about this software since my display adapter is a Nvidia geforce 7100/nforce 630i and I don't see any ATI hardware. I'm not an expert in this area by any means.
Google searches for the last 2 hours haven't helped much either.
Can someone shed some light on this problem??? This is the only thing holding me back from doing the upgrade.
Captain Jack
Former Moderator
- Joined
- Mar 6, 2010
- Messages
- 1,888
- Thread Author
- #3
Here it is:
Summary
Summary
Operating System
MS Windows Vista Home Premium 32-bit SP2
CPU
Intel Pentium E2160 @ 1.80GHz 84 °F
Conroe 65nm Technology
RAM
3.0GB Single-Channel DDR2 @ 333MHz (5-4-4-14)
Motherboard
ACER MCP73 (SOCKET775 M/B)
Graphics
HF229 @ 1680x1050
256MB GeForce 7100 / nForce 630i (Acer Incorporated [ALI])
Hard Drives
244GB Seagate ST325031 0AS SCSI Disk Device (RAID)
Optical Drives
HL-DT-ST DVDRAM_GH15N SCSI CdRom Device
Audio
Realtek High Definition Audio
Operating System
Installation Date: 23 March 2008, 22:54
Serial Number: xxxxx-xxxxx-xxxxx-xxxxx
Windows Security Center
Firewall Enabled
Antivirus Disabled
Windows Defender
Windows Defender Disabled
CPU
Intel Pentium E2160
Cores 2
Threads 2
Name Intel Pentium E2160
Code Name Conroe
Package Socket 775 LGA
Technology 65nm
Specification Intel(R) Pentium(R) Dual CPU E2160 @ 1.80GHz
Family 6
Extended Family 6
Model F
Extended Model F
Stepping D
Revision M0
Instructions MMX, SSE, SSE2, SSE3, SSSE3, EM64T
Bus Speed 200.1 MHz
Rated Bus Speed 800.3 MHz
Stock Core Speed 1800 MHz
Stock Bus Speed 200 MHz
Average Temperature 84 °F
Caches
L1 Data Cache Size 2 x 32 KBytes
L1 Instructions Cache Size 2 x 32 KBytes
L2 Unified Cache Size 1024 KBytes
Core 0
Core Speed 1800.2 MHz
Multiplier x 9.0
Bus Speed 200.1 MHz
Temperature 87 °F
Thread 1
APIC ID 0
Core 1
Multiplier x 9.0
Bus Speed 200.1 MHz
Temperature 81 °F
Thread 1
APIC ID 1
RAM
Memory slots
Total memory slots 2
Used memory slots 2
Free memory slots 0
Memory
Type DDR2
Size 3072 MBytes
Channels # Single
DRAM Frequency 333.5 MHz
CAS# Latency (CL) 5 clocks
RAS# to CAS# Delay (tRCD) 4 clocks
RAS# Precharge (tRP) 4 clocks
Cycle Time (tRAS) 14 clocks
Bank Cycle Time (tR?) 20 clocks
Command Rate (CR) 2T
SPD
Number Of SPD Modules 2
Slot #1
Type DDR2
Size 2048 MBytes
Manufacturer Hyundai Electronics
Max Bandwidth PC2-5300 (333 MHz)
Part Number HYMP125U64CP8-Y5
Serial Number 00001015
Week/year 45 / 07
SPD Ext. EPP
JEDEC #3
Frequency 333.3 MHz
CAS# Latency 5.0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 16
tRC 21
Voltage 1.800 V
JEDEC #2
Frequency 266.7 MHz
CAS# Latency 4.0
RAS# To CAS# 4
RAS# Precharge 4
tRAS 12
tRC 16
Voltage 1.800 V
JEDEC #1
Frequency 200.0 MHz
CAS# Latency 3.0
RAS# To CAS# 3
RAS# Precharge 3
tRAS 9
tRC 12
Voltage 1.800 V
Slot #2
Type DDR2
Size 1024 MBytes
Part Number HYMP112U64CP8-Y5
Serial Number 00005092
Week/year 06 / 08
SPD Ext. EPP
JEDEC #3
Frequency 333.3 MHz
CAS# Latency 5.0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 16
tRC 21
Voltage 1.800 V
JEDEC #2
Frequency 266.7 MHz
CAS# Latency 4.0
RAS# To CAS# 4
RAS# Precharge 4
tRAS 12
tRC 16
Voltage 1.800 V
JEDEC #1
Frequency 200.0 MHz
CAS# Latency 3.0
RAS# To CAS# 3
RAS# Precharge 3
tRAS 9
tRC 12
Voltage 1.800 V
Motherboard
Manufacturer ACER
Model MCP73
Version R01-A3
Chipset Vendor NVIDIA
Chipset Model GeForce 7100
Chipset Revision A2
Southbridge Vendor NVIDIA
Southbridge Model nForce 630i
Southbridge Revision A2
BIOS
Brand American Megatrends Inc.
Version R01-A3
Date 01/29/2008
Graphics
Monitor
Name HF229 on NVIDIA GeForce 7100 / NVIDIA nForce 630i
Current Resolution 1344x840 pixels
Work Resolution 1344x813 pixels
State enabled, primary, output devices support
Monitor Width 1680
Monitor Height 1050
Monitor BPP 32 bits per pixel
Monitor Frequency 60 Hz
Device \\.\DISPLAY1\Monitor0
GPU C73
Device ID 10DE-07E1
Revision A3
Subvendor Acer Incorporated [ALI] (1025)
Technology 80 nm
DirectX Support 9.0c
DirectX Shader Model 3.0
OpenGL Support 2.0
Bus Interface FPCI
Driver nvlddmkm.sys
Driver version 8.17.12.5896
ForceWare version 258.96
BIOS Version 5.73.32.08.01
ROPs 4
Shaders Vertex 4/Pixel 4
Memory Type System
Physical Memory 256 MB
Virtual Memory 1408 MB
Hard Drives
Manufacturer Seagate
Form Factor 3.5"
Interface RAID
Capacity 244GB
Real size 250,059,350,016 bytes
S.M.A.R.T
S.M.A.R.T not supported
Partition 0
Partition ID Disk #0, Partition #0
Size 9.75 GB
Partition 1
Partition ID Disk #0, Partition #1
Disk Letter C:
File System NTFS
Volume Serial Number 2021A846
Size 112GB
Used Space 45GB (41%)
Free Space 67GB (59%)
Partition 2
Partition ID Disk #0, Partition #2
Disk Letter D:
File System NTFS
Volume Serial Number 3C93E064
Size 111GB
Used Space 4.71GB (5%)
Free Space 107GB (95%)
Optical Drives
Media Type DVD Writer
Name HL-DT-ST DVDRAM_GH15N SCSI CdRom Device
Availability Running/Full Power
Capabilities Random Access, Supports Writing, Supports Removable Media
Config Manager Error Code Device is working properly
Config Manager User Config FALSE
Drive E:
Media Loaded FALSE
SCSI Bus 2
SCSI Logical Unit 0
SCSI Port 3
SCSI Target Id 2
Status OK
Audio
Sound Cards
High Definition Audio Device
Playback Devices
Realtek Digital Output (Realtek High Definition Audio)
Digital Output Device (HDMI) (High Definition Audio Device)
Speakers (Realtek High Definition Audio) (default)
Peripherals
HID Keyboard Device
Device Kind Keyboard
Device Name HID Keyboard Device
Vendor Unknown
Location USB Human Interface Device
Driver
Date 6-21-2006
Version 6.0.6002.18005
File C:\Windows\system32\DRIVERS\kbdhid.sys
File C:\Windows\system32\DRIVERS\kbdclass.sys
Microsoft USB IntelliMouse Explorer 4.0 (IntelliPoint)
Device Kind Mouse
Device Name Microsoft USB IntelliMouse Explorer 4.0 (IntelliPoint)
Vendor Microsoft
Driver
Date 11-26-2008
Version 6.31.230.0
File C:\Windows\system32\DRIVERS\point32k.sys
File C:\Windows\system32\DRIVERS\mouhid.sys
File C:\Windows\system32\DRIVERS\mouclass.sys
HP Officejet J6400 series
Device Kind Printer
Device Name HP Officejet J6400 series
Location USB Printing Support
Driver
Date 7-1-2008
Version 61.71.265.32
File C:\Windows\system32\hpzids01.dll
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpoj6400.cfg
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\UNIDRV.DLL
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\UNIRES.DLL
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\UNIDRVUI.DLL
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\STDNAMES.GPD
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\STDDTYPE.GDL
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\STDSCHEM.GDL
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\STDSCHMX.GDL
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\UNIDRV.HLP
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpoj6400.gpd
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpoj6400a.ini
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpzst5jy.dll
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpz3c5jy.dll
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpzur5jy.dll
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpoj6400.xml
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpzsc5jy.dtd
File C:\Windows\system32\spool\PRTPROCS\W32X86\2\hpzpp5jy.dll
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpzui5jy.dll
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpz3r5jy.dll
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpzpr5jy.dll
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpcdmc32.dll
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpbcfgre.dll
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpzsm5jy.gpd
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpz3m5jy.gpd
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpzev5jy.dll
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpzhl5jy.cab
File C:\Windows\system32\hpz3l5jy.dll
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpfie5jy.dll
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpfig5jy.dll
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpfrs5jy.dll
File C:\Windows\system32\spool\DRIVERS\COLOR\Adobe RGB (1998) D65 WP 2.2 Gamma.icc
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpfst071.rpo
File C:\Windows\system32\spool\DRIVERS\W32X86\{BD720607-D2BA-4D89-971E-F5C868E6B4C5}\hpzc35jy.dll
HP Officejet J6400
Device Kind Camera/scanner
Vendor Unknown
Location USB Composite Device
Driver
Date 1-23-2007
Version 10.0.0.0
File C:\Windows\system32\hpwwiax3.dll
File C:\Windows\system32\hpwtiop3.dll
File C:\Windows\system32\hpovst11.dll
File C:\Windows\system32\hppldcoi.dll
File C:\Windows\system32\difxapi.dll
File C:\Windows\system32\drivers\usbscan.sys
Disk drive
Device Kind USB storage
Device Name Disk drive
Vendor GENERIC-
Comment Generic- Compact Flash USB Device
Location USB Mass Storage Device
Driver
Date 6-21-2006
File C:\Windows\system32\DRIVERS\disk.sys
Disk drive
Vendor GENERIC-
Comment Generic- MS/MS-Pro USB Device
Driver
Date 6-21-2006
Disk drive
Vendor GENERIC-
Comment Generic- SD/MMC USB Device
Driver
Date 6-21-2006
Disk drive
Vendor GENERIC-
Comment Generic- SM/xD-Picture USB Device
Driver
Date 6-21-2006
Disk drive
Vendor HP
Comment HP Officejet J6400 USB Device
Driver
Date 6-21-2006
Disk drive
Vendor WD
Comment WD 3200AAK External USB Device
Driver
Date 6-21-2006
Network
You are connected to the internet
Connected through NVIDIA nForce 10/100/1000 Mbps Ethernet
IP Address 192.168.0.100
Subnet mask 255.255.255.0
Gateway server 192.168.0.1
Preferred DNS server 192.168.1.254
DHCP Enabled
DHCP server 192.168.0.1
External IP Address 65.0.80.90
Adapter Type Ethernet
NetBIOS over TCP/IP Enabled via DHCP
WinInet Info
LAN Connection
Local system uses a local area network to connect to the Internet
Local system has RAS to connect to the Internet
Wi-Fi Info
Wi-Fi not enabled
WinHTTPInfo
WinHTTPSessionProxyType No proxy
Session Proxy
Session Proxy Bypass
Connect Retries 5
Connect Timeout 60000
HTTP Version HTTP 1.1
Max Connects Per 1.0 Servers INFINITE
Max Connects Per Servers INFINITE
Max HTTP automatic redirects 10
Max HTTP status continue 10
Send Timeout 30000
IEProxy Auto Detect No
IEProxy Auto Config
IEProxy
IEProxy Bypass
Default Proxy Config Access Type No proxy
Default Config Proxy
Default Config Proxy Bypass
Captain Jack
Former Moderator
- Joined
- Mar 6, 2010
- Messages
- 1,888
Hello,
That is an odd behavior. Try to install the latest update for nVidia NVIDIA DRIVERS 178.24 WHQL and see if that solves your problem.
- Thread Author
- #5
Captain Jack
Former Moderator
- Joined
- Mar 6, 2010
- Messages
- 1,888
Thanks for the suggestion. I'm kinda working in an area I'm not real familar with. If I install these, will I be able to uninstall if I have problems? And how will I do that?? I already have an entry in Control Panel/Programs and Features named NVIDIA drivers from an update earlier this year.
Yes you'll be able to uninstall it in case of that didn't work, i have written an nVidia driver cleanup article Link Removed - Invalid URL
Hope this helps,
Captain
- Thread Author
- #7
I decided to take the "easy" approach first. I started the "ATI Catalyst Install Manager" and told it to check for updates. It came back and told me that I have no ATI hardware/software on the machine. I ended it, took a restore point, then uninstalled it. After rebooting and working a little bit, I took an image backup and also a FBACKUP 4 run. Then went ahead and upgraded to Win 7 Home Premium. Took about 2 hours but everything went fine. Machine is working great and I have only had a problem with one piece of software from FEMA.
Appreciate your help though.
Similar threads
- Replies
- 3
- Views
- 3K
- Replies
- 6
- Views
- 2K
- Replies
- 1
- Views
- 645
- Replies
- 5
- Views
- 3K
- Replies
- 7
- Views
- 6K
