- Thread Author
- #1
Here is what I'v noticed.... my usb motherboard ports work fine... as long as the device is plugged in when you boot. If you pull something out... and put it back in... it does not.
Also, I have 2 front USB ports... of which one works.... (at usb1.1 speeds WHY!) and the other always just says (device not recognized) As far as I know I should have ALL USB 2.0 Ports... why is anything connecting at 1.1.... it never did this in Vista!
So on top of that the back ports seem jacked up too... I dont' want to transfer files for HOURS Instead of minutes in the front PORT... (not ports cause one of them is jacked) and the back ports light up my HDD but it is not recognized... nothing pops up... Computer Management > Disk Management shows only my C: drive. It's like the back ports just dont' work at all... that is unless stuff is plugged into them on boot up.
Another example... my xbox wireless reciever was working fine.... I unplugged it... plugged it back in... the light on the device is not even on now.
I look at my device manager... no exclamtion points... but I did notice that it's showing..... well let me just capture and show you...
Link Removed due to 404 Error
I know my motherboard is a bit older now... but if it worked fine in Vista I don't understand why Windows 7 is giving me so much trouble.
It's a crummy board (don't need sarcastic responses about that) ECS RS482-M
Thanks for your help,
James
James
