Microsoft is quietly testing a small but notable convenience feature in Windows 11: a one‑click internet speed test shortcut embedded directly in the network flyout and taskbar context menu — a shortcut that, for now, simply launches Bing’s online speed‑test widget rather than running a native diagnostic inside the OS.
Windows desktop showing a Bing Internet speed test page with a One-click speed test badge.Background / Overview​
Windows has steadily moved many diagnostic workflows from legacy, local tools into cloud‑backed and web‑driven experiences. The new speed‑test shortcut follows that trend: it places a Perform speed test action where users already go to manage adapters, Wi‑Fi networks, and troubleshoot connectivity. Early reporting and screenshots surfaced from Windows Insider preview builds in the Dev and Beta channels, and the discovery was shared publicly by preview‑build sleuths and technology sites before Microsoft documented the change.
The shortcut’s current behavior is straightforward: click the network indicator in the system tray, open the network flyout, and select the new speed‑test button next to the Wi‑Fi refresh control. Windows then opens your default browser and directs you to Bing’s internet speed test widget — the same web‑based tool that runs when you search “speed test” in Bing. That Bing widget, in turn, uses a well‑known third‑party engine for the measurement backend. This article examines what Microsoft appears to be testing, why it matters to everyday users and IT professionals, the strengths and limits of the approach, alternatives and practical advice for diagnostics, and suggestions Microsoft could adopt to make the feature more robust for enterprise use.
What was discovered and how it behaves​
The UI discovery​
Preview‑build testers found a new icon/button placed inside the network flyout — the same compact window you get when you click the network icon on the taskbar. The button sits near other quick actions such as the Wi‑Fi refresh control and, in early builds, also appears in the right‑click context menu for the network icon (alongside Network Troubleshooter and Network settings). The placement is deliberate: connectivity checks are now a single click away from the same UI where users already validate signal, adapter selection, and connection profiles.
What the button actually does​
The current implementation is not a built‑in, offline diagnostic. Instead, it opens the browser and runs Bing’s online speed test widget. That web widget relies on established speed‑test infrastructure (the Bing widget has been reported to surface Speedtest/ Ookla engine integrations), so Microsoft avoids rebuilding server selection and measurement code locally. Multiple independent writeups confirm Bing offers an embedded speed‑test widget and that it delegates to known speed‑testing infrastructure.
Important caveat: work in progress​
Because the feature was discovered in Insider preview builds, the UI, wording, and behavior could change before a public roll‑out. Reports and screenshots come from community sleuthing and early‑access builds; Microsoft has not yet published formal release notes describing the feature at the time of the discovery, so treat specifics as provisional.
Why Microsoft might be doing this (and why it’s sensible)​
  • Improved discoverability: average users rarely know or remember to open a browser and search for “speed test.” Putting the action directly in the network flyout reduces friction for quick verification.
  • Consistent support workflow: IT support staff can standardize on a single, easily reached test location when guiding users, reducing back‑and‑forth during triage.
  • Leverage mature engines: by routing to Bing’s widget (which uses established server selection and backend engines), Microsoft avoids reinventing an entire measurement stack — especially the hard part of selecting geographically appropriate servers and managing test artifacts.
  • Low engineering overhead: a web redirect requires less OS code, fewer compatibility concerns, and can be iterated independently from OS servicing cadence.
These rationales match a broader Microsoft strategy that has shifted many utilities from legacy local code to web/cloud experiences and centralized engines for maintenance and consistency.
Technical verification — what we checked​
  • The Bing speed‑test widget exists and is accessible directly via Bing’s tools page and search results.
  • Independent reporting about Microsoft and Edge integrating that same widget into product UIs confirms the widget’s presence and the general pattern of redirecting to Bing for speed tests. Multiple outlets describe Edge’s sidebar or toolbox linking into Bing’s speed test, showing the same redirect pattern that the Windows network flyout appears to adopt.
  • Reporting and community captures that show the new Windows UI element came from preview builds — these are community‑sourced findings rather than official Microsoft documentation at present, and are therefore provisional.
When possible, claims have been cross‑referenced with at least two independent sources: the Bing tool page plus coverage in mainstream tech outlets describing Edge/Bing speed‑test integration. That triangulation supports the conclusion that the Windows button launches Bing’s speed test rather than executing a native OS test.
Strengths — why casual users and support teams will like this​
  • One‑click convenience. The action is placed where users already go for network checks, so the discoverability and user flow are excellent.
  • Low friction for non‑technical verification. Clicking the button is faster than asking users to remember a URL or install a third‑party app.
  • Standardized test endpoint for support. If Microsoft documents the feature, help desks can reference the same test and result wording when assisting users.
  • No client maintenance burden. Because the test runs in a browser and uses a web widget, Microsoft can update the measurement backend independently, fix bugs in the web UI, and iterate server selection logic without OS updates.
Risks and limitations — why many power users and IT pros will bristle​
  • Not an offline diagnostic. If the network issue prevents the browser from loading the test (DNS failure, captive portal, or severe packet loss), the button is useless. Native diagnostics that measure adapter throughput, packet loss and local interface health remain necessary for deeper triage.
  • Browser dependency and environmental variance. Results from the browser may differ from a native client due to browser networking stacks, extensions, parallel tabs, VPNs, or proxy settings — leading to inconsistent numbers when compared to other test methods.
  • Single‑provider lock‑in (so far). Early builds show the button tied to Bing’s widget; there’s no obvious user‑visible option to select a different test provider such as Speedtest.net, Fast.com, TestMy.net, or an ISP‑provided meter. Users who prefer a particular provider may resent implicit defaults.
  • Privacy and telemetry concerns. A web test routes data through third‑party endpoints and is subject to Bing/Edge privacy policies, server logs, CDN routing, and potential cross‑region server selection. Enterprises that are sensitive to telemetry may prefer an offline test or an internally hosted test endpoint.
  • Reproducibility for dispute with ISPs. ISP negotiations sometimes use specific provider results. Browser‑based tests that don’t publish server IPs or selection heuristics make reproducing or validating claims harder.
  • Enterprise management and policy gaps. Managed devices may block web‑based tests or custom browser behavior can alter results. Group Policy/MDM may need new controls to allow, block, or redirect the action in corporate environments.
Real‑world impact and examples​
  • For a home user who suspects a slow Netflix stream, the new shortcut lets them confirm if their connection is down to ISP throughput quickly — a helpful triage step.
  • For help‑desk staff instructing remote users, the consistent UI location simplifies guidance: “Click the network icon, choose Perform speed test, and send me the numbers.”
  • For an enterprise with strict telemetry rules or captive‑portal networks, the button may be disabled or suppressed through policy — meaning help desks should not rely solely on it.
Community testing of Edge’s built‑in speed test that uses the same underlying Bing experience has already flagged that browser‑embedded results sometimes differ from native Speedtest runs, reinforcing the need for caution when using the numbers as absolute evidence.
How IT teams should treat the new button today​
  • Confirm availability on managed machines: check Insider policies and ring/channel settings before relying on the feature for support scripts.
  • Use the web test for quick, user‑friendly triage; do not treat it as definitive evidence in performance disputes.
  • When accuracy or reproducibility matters, run parallel tests:
  • Command‑line and local tests: iperf3 to a known, internal test server.
  • Native apps: Ookla Speedtest desktop client or ISP‑provided diagnostic tools.
  • Router/gateway stats: check the modem/router WAN counters for end‑to‑end verification.
  • If you must capture test provenance, instruct users to note the test method (Bing widget vs. Speedtest app) and screenshot the server details and public IP if possible.
  • Prepare fallback instructions for the most common failure modes (DNS, captive portals, VPNs), including how to gather netsh, ipconfig, ping, and tracert outputs for deeper triage.
Alternatives for users who want on‑desktop speed tools​
  • PowerToys Run module: a community PowerToys plugin and Run launcher module can run a speed test without opening the browser, providing a more seamless CLI‑style workflow on the desktop. (PowerToys remains a practical, customizable option when the web‑launch approach is too limiting.
  • Native Speedtest apps: the Ookla Speedtest desktop app or Fast.com offer dedicated clients and sometimes produce more consistent results than a browser widget.
  • Taskbar meters: tools such as NetSpeedMonitor derivatives, TrafficMonitor, Networx, and other taskbar meters provide real‑time throughput counters without launching tests; these are better for spotting transient bottlenecks.
  • Network diagnostics and iperf3: for reproducible, controlled tests in enterprise environments, use internal iperf3 servers and scripted measurement routines.
What Microsoft could do to improve the feature before wide release​
  • Add provider choice. Allow users or admins to pick a default test provider (Bing/Ookla, Fast.com, ISP meter, or a custom URL) in Settings > Network or within an Advanced options pane.
  • Offer an offline micro‑benchmark. Include a lightweight local test that measures basic adapter throughput and packet loss without relying on web access; this would be invaluable when DNS or HTTP is the failure point.
  • Expose test metadata. Show server IP, server location, test methodology (single vs. multi‑thread), timestamp and RTT to the server to aid reproducibility.
  • Manageability controls. Provide Group Policy/MDM controls to disable the web launch or route tests through enterprise‑approved endpoints.
  • Integrate exportable logs. Allow users to copy or export test results in a reproducible format for support tickets (including public IP, server info, and raw measurements).
If Microsoft implements these improvements it would make the feature useful for both consumers and IT professionals.
Quick how‑to: use cases and step‑by‑step options​
For quick consumer checks (one click)​
  • Click the network icon in the system tray.
  • Click the new Perform speed test button.
  • Browser opens to Bing’s speed test widget; click Start to measure download, upload, and ping.
For reproducible enterprise tests (recommended)​
  • Run iperf3 against a controlled internal server or a trusted external server.
  • Run the Ookla Speedtest desktop client (if you require ISP‑facing testing with an app).
  • Collect netsh wlan show wlanreport, ipconfig /all, ping and tracert outputs to document local adapter and routing behavior.
Privacy, telemetry, and enterprise policy considerations​
The web‑based flow inherits Bing/Edge privacy semantics: server selection, logs, cookies and any telemetry the widget emits are governed by Bing’s server policies and the browser. Organizations with data‑handling concerns should either:
  • Use internal test endpoints and native tools that keep telemetry on‑premises, or
  • Implement policies to block the web test or route traffic through enterprise proxies that allow inspection and logging as required.
Managed devices may not show the preview feature depending on build policy; enterprise admins should confirm how Insider preview updates are applied in their environment before changing support workflows.
Balanced conclusion​
Placing a speed‑test shortcut inside Windows 11’s network flyout is a logical UX move that reduces friction for simple connectivity checks. For casual users it’s a sensible convenience: the test is a single click from where people already look when they suspect connectivity problems. However, the current implementation — a browser launch to Bing’s web widget — is a pragmatic but imperfect compromise.
The approach is quick to deploy and maintain, but it leaves gaps that matter for troubleshooting, reproducibility, and enterprise control. Until Microsoft either ships a configurable provider option or adds a lightweight, built‑in micro‑benchmark, IT professionals should treat the new button as a useful starting point, not a replacement for established diagnostic workflows.
The discovery of the button in preview builds is community sourced and still subject to change; whether Microsoft keeps the exact placement, behavior, and default provider when the feature ships will only be confirmed when the company publishes release notes or rolls the feature to production devices.
Practical takeaway for Windows users and IT teams​
  • For everyday, quick checks: use the new network flyout button — it’s fast and convenient.
  • For troubleshooting, ISP disputes, or enterprise environments: continue to use dedicated clients, internal tests, and controlled measurement tools that provide reproducible, auditable results.
  • For administrators: review policy controls for Insider channels, prepare guidance for support staff to capture provenance of web‑based tests, and consider a standardized internal testing toolkit to avoid reliance on a single external provider.
The new Windows shortcut is a small but meaningful UX change that reflects a larger shift toward web‑backed utilities — a step forward for convenience, but not yet a replacement for the deeper, offline diagnostics IT teams and power users rely on.
Source: Neowin Windows 11's taskbar is getting an internet speed test button
Microsoft is quietly testing a tiny but useful convenience: a one‑click network speed test tucked into Windows 11’s Taskbar network menu that — for now — simply opens Bing’s web speed‑test widget in your default browser rather than running a native, offline diagnostic inside the operating system.
Futuristic Windows desktop with a Bing speed test overlay on a blue abstract background.Background / Overview​
The discovery surfaced in Windows Insider preview builds and was publicized by community sleuths and tech reporters who monitor Insider channels. Early evidence shows a new “Perform speed test” control available from the network icon’s context menu and inside the Wi‑Fi quick settings flyout; clicking it launches the browser and opens Bing’s embedded speed‑test tool. That Bing tool reports download, upload, and latency figures using established measurement backends.
This change sits squarely inside a larger trend at Microsoft: moving lightweight troubleshooting and consumer‑facing diagnostics to web‑backed experiences that can be updated outside the OS servicing cadence. That design decision reduces local engineering burden and simplifies delivery, but it shifts some control — and some telemetry — to web services and browser contexts.
What was found in preview builds​
Where you’ll see it​
The UI element appears in two obvious places in preview builds:
  • The right‑click context menu for the network icon in the system tray (alongside Network Troubleshooter and Network settings).
  • A button inside the Wi‑Fi quick settings flyout, positioned near the Wi‑Fi refresh and other quick actions.
Screenshots and community captures indicate the placement is deliberate: the control appears exactly where users already go to verify connectivity and manage adapters. Early reports came from Insider Dev and Beta Channel testers and third‑party observers.
What the control does today​
Clicking the control does not run a built‑in Windows diagnostic. Instead, it opens the default web browser and navigates to Bing’s speed‑test widget, where the user can manually start a test that measures download throughput, upload throughput, and latency (ping). The Bing widget is accessible directly at Bing’s Tools / Speedtest page and is already used in other Microsoft products (for example, Edge’s sidebar/toolbox shortcuts), which suggests the network button simply funnels users to the same web endpoint.
Why Microsoft likely implemented it this way​
Putting a speed test into the network flyout solves a real, practical problem: many users don’t know how (or don’t want) to navigate to a speed‑test website or install a third‑party app when their connection seems slow. A one‑click action in the Taskbar reduces friction for quick checks and gives support staff a predictable place to send users during triage.
From an engineering perspective, routing users to a web widget avoids the complexity of integrating and maintaining measurement code and global server selection in the OS. Speed tests require geographic server selection, throughput calibration, and a backend to host test endpoints — all of which are easier to manage on web services operated by a large provider. That explains why Microsoft would opt for a browser‑based widget while the company iterates on the idea.
Strengths and immediate benefits​
  • Discoverability: Users already glance at the network icon when connectivity is suspect; placing a speed test there is high‑value, discoverable UX.
  • Low friction: No need to remember a URL or install an app. For the majority of quick checks (e.g., is my ISP down?, the web test is sufficient.
  • Centralized updates: Microsoft (and the Bing experience) can change server selections or UI without shipping an OS update, enabling faster iteration on test logic and UX.
  • Consistency for support: Help desks can standardize on one test location when walking end users through troubleshooting steps, reducing ambiguity.
Limitations, technical caveats, and accuracy concerns​
Browser dependency and offline scenarios​
A web‑based speed test requires a working browser and network stack sufficient to load the test page. If the failure mode is DNS corruption, captive portal authentication, or catastrophic HTTP failures that prevent page loads, the Taskbar button will be useless. That makes the feature convenient but not comprehensive. IT pros and advanced users should continue to use local diagnostics and command‑line tools for those cases.
Variability introduced by browser environment​
A browser‑run speed test can yield results that differ from native clients or ISP‑hosted meters. Factors that introduce variance include:
  • Browser networking stack and connection limits (e.g., parallel streams, HTTP/2 behavior).
  • Active browser extensions, background tabs, or other system activity.
  • VPNs, proxies, or corporate traffic shaping that only affect browser traffic.
These differences mean that browser results are useful for quick triage but should not be the sole evidence in disputes with ISPs or for contractual verification. Independent analyses have shown small but actionable differences between Edge/Bing‑embedded tests and a dedicated Speedtest client.
Single provider lock‑in (so far)​
Early builds tie the Taskbar shortcut to Bing’s widget with no obvious user‑facing setting to change the provider. That implicit default could frustrate users who prefer other services (Ookla, Fast.com, TestMy.net) or who have enterprise rules requiring specific test endpoints. For enterprise IT teams, the lack of a configurable provider is a notable omission.
Because the test runs via Bing in the browser, it follows Bing’s and the browser’s privacy rules. That raises several operational considerations for managed environments:
  • Telemetry and logs: Test endpoints may record the client’s public IP and test server selection — data some organizations restrict from leaving premises.
  • Policy control: Managed devices may or may not surface preview features depending on Windows Update ring policies and Insider settings; organizations should confirm that the shortcut will appear (or be suppressed) under their configuration management rules.
  • MDM/Group Policy requirements: Administrators may want the ability to block the web launch, replace the default provider with an internal endpoint, or force tests through an enterprise proxy to capture logs. Microsoft has not (in the preview evidence) published such controls.
How IT and support teams should treat the Taskbar speed test​
  • Use it as a fast, first‑step check. The button is ideal for verifying whether throughput generally aligns with expectations during an initial help‑desk triage.
  • Don’t rely on it for authoritative evidence. When contesting ISP performance or building a reproducible test, run a native client (e.g., Ookla Speedtest desktop app), use iperf3 to a known test server, or extract router/gateway WAN counters.
  • Prepare fallback diagnostics. If the browser cannot load Bing, instruct users on local commands to collect evidence: netsh wlan show wlanreport, ipconfig /all, ping, tracert, and logs from Resource Monitor or Task Manager.
  • Audit managed device behavior. Confirm whether Insider rings or preview features are enabled in your environment, and add guidance to internal KBs so help agents know when the Taskbar feature will or won’t be available.
Alternatives and existing tooling​
For users who want on‑desktop or offline options, several established tools remain superior to a browser shortcut in different scenarios:
  • Dedicated speed‑test apps: Ookla’s Speedtest desktop client and Fast.com apps provide consistent results and richer exportable metadata.
  • Taskbar meters: Utilities like TrafficMonitor, NetSpeedMeter, Networx and other taskbar/network indicators give continuous, real‑time throughput counters useful for spotting transient bottlenecks.
  • Enterprise testing: iperf3 (to an internal test server) enables controlled, reproducible measurements and is the recommended method in professional diagnostics and SLA verification.
Edge already surfaces a speed‑test shortcut in its side panel/toolbox that opens Bing’s test — an existence proof that Microsoft has already been routing users to this web widget inside other products. That integration has been examined by independent outlets and shown to use the same web‑hosted measurement flow.
What Microsoft could and should add before wide release​
The preview evidence shows a useful starting point. If Microsoft intends this to be more than a convenience shortcut, here are tactical improvements that would make it far more usable for power users and IT admins:
  • Provider choice: Add a Settings control to choose the default speed‑test provider (Bing, Ookla/Speedtest, Fast.com, ISP tool, or a custom URL). This preserves user agency and enterprise compatibility.
  • Offline micro‑benchmark: Ship a small local micro‑benchmark that tests adapter throughput, basic packet loss, and link quality without requiring web access. This would be invaluable when DNS or HTTP is impaired.
  • Exportable test metadata: Enable copying or exporting of results with server IP, test timestamp, client public IP, and methodology so support teams can reproduce and validate results.
  • MDM and Group Policy controls: Provide enterprise controls to disable the web launch, force a specific provider, or route tests via an internal endpoint. That would make the feature safe for regulated environments.
Verification and what’s still provisional​
  • The presence of the Taskbar speed‑test shortcut in Insider Dev/Beta preview builds comes from community captures and reporting; Microsoft had not published an official release note describing the exact feature in the early previews, so details remain provisional. Treat the UI text, placement, and provider behavior as subject to change before general availability.
  • Bing’s speed‑test widget is public and accessible via Bing’s tools page; independent reporting confirms it’s the same widget surfaced by Edge and other Microsoft properties. That makes the claim that the Taskbar control opens Bing’s test verifiable with the current preview behavior.
  • Microsoft’s broader release strategy for Windows 11 updates has shifted: version 25H2 was designed to share the same feature branch and servicing stack as 24H2, meaning features are delivered via a continuous‑innovation model rather than a single big jump. That context explains why this kind of feature can appear in preview builds and then roll out to user devices independent of the annual version label. Microsoft has documented that 25H2 and 24H2 share a platform and servicing approach.
Practical how‑to (for home users)​
  • Click the network icon in the system tray (lower‑right corner).
  • Either right‑click the icon and choose Perform speed test (if present) or open the Wi‑Fi quick settings and click the Speed test button.
  • Your default browser will open a new tab with Bing’s speed‑test widget; click Start to run the test.
  • If the page fails to load, follow local diagnostics: netsh wlan show wlanreport, ipconfig /all, and ping/tracert to gather evidence.
Final analysis — why this matters to Windows users​
This small UX addition is a pragmatic win for everyday users. A one‑click speed check reduces cognitive friction for basic triage and brings a common web task into the context where people already inspect connectivity. For the majority of home users who simply want to confirm whether an ISP is performing, the Taskbar shortcut is an elegant shortcut.
However, the implementation choice matters. Microsoft’s decision to route to a web widget is fast and maintainable but leaves gaps for power users, enterprises, and contested ISP disputes. Until Microsoft adds provider choice, offline micro‑benchmarks, metadata export, and enterprise controls, the Taskbar button will be a convenient starting point — not a replacement for robust, reproducible network diagnostics.
In short: useful, but limited; polished for consumers, incomplete for professional troubleshooting. The preview builds give a strong signal about Microsoft’s priorities — convenience and centralized web delivery — and the community will rightly press the company to add the enterprise and reproducibility features that make this kind of functionality trustworthy in the field.
The Taskbar speed‑test shortcut is a sensible addition to Windows 11 that improves basic troubleshooting for the average user by surfacing a quick way to measure throughput. The current implementation — a browser launch to Bing’s speed‑test widget — is a pragmatic, low‑maintenance approach that aligns with Microsoft’s broader shift toward web‑delivered diagnostics. That said, the feature’s usefulness for power users and IT organizations depends on future additions: provider selection, offline diagnostics, exportable metadata, and management controls. Until those arrive, treat the Taskbar speed test as a rapid sanity check rather than definitive proof of network performance.
Source: Windows Central You'll soon be able to run a network speed test directly from Windows 11's Taskbar — powered by Bing
Microsoft is quietly testing a built‑in internet speed checker in Windows 11 that surfaces a one‑click “Perform speed test” control from the taskbar’s network menu — a shortcut that currently opens Bing’s speed‑test widget in the default browser rather than running a local diagnostic inside the OS.
Windows 11 desktop showing a blue Internet speed test widget with 0 Mbps.Background / Overview​
Windows 11 has been receiving steady incremental updates through the Insider channels, and this small convenience feature has been discovered in recent Dev and Beta preview builds. The control appears in two places: the right‑click context menu for the network (system tray) icon and as a button inside the Wi‑Fi Quick Settings flyout, adjacent to other quick actions. Clicking the control launches your default browser and loads the Bing speed‑test widget, where users can run a standard download/upload/latency measurement.
The new behavior follows Microsoft’s broader trend of surfacing web‑backed utilities inside system UI shortcuts: rather than embedding a full measurement engine and selecting global test servers inside the OS, Windows links users to a web tool that Microsoft already maintains as part of Bing. That Bing widget, as publicly documented and visible on Bing’s tools page, presents a one‑click speed test experience.
  • Right‑click the network icon in the system tray and look for a “Perform speed test” entry in the context menu.
  • Open the Wi‑Fi Quick Settings flyout (left‑click the network icon) and look for a speed test button near the Wi‑Fi refresh/quick actions.
Early screenshots and community captures indicate Microsoft has placed the control exactly where most users already go to check signal, adapter selection, and connectivity details — a deliberate UX placement designed for discoverability.
The control does not run a native speed measurement inside Windows. Instead:
  • The button opens the default browser.
  • The browser navigates to the Bing speed‑test widget.
  • The widget runs a web‑based speed test (download, upload, latency) and displays results.
Because the widget runs inside the browser, the measurement relies on web‑facing servers and infrastructure rather than any new, local OS subsystem. Reports indicate the Bing widget delegates to established speed‑test backends rather than reinventing the server selection or measurement stack.
Putting a speed‑test control into the network flyout solves a real, common pain point: when connections appear slow, many users do not know to open a browser and visit a speed‑test site. A one‑click path lowers friction for basic triage and gives help‑desk staff a predictable place to send users during remote troubleshooting. It also aligns with Microsoft’s strategy of shifting lightweight consumer diagnostics to web services that can be updated independently of OS servicing cycles.
Key practical reasons for the web‑backed approach:
  • Avoids building and maintaining global test servers and server‑selection logic inside Windows.
  • Lets Microsoft leverage an existing Bing/Edge experience and third‑party measurement engines.
  • Enables quicker iteration and updates to the test UI without shipping OS updates.
These trade‑offs make sense for a consumer‑facing convenience shortcut, but they also expose limits when the intent is precise, reproducible network diagnostics.
How it behaves in practice (quick how‑to)​
  • Click the network (Wi‑Fi / Ethernet) icon in the system tray.
  • Either right‑click the network icon and select Perform speed test, or open the Wi‑Fi Quick Settings and click the speed‑test button.
  • The default browser opens to Bing’s speed test widget; click Start to begin the test.
  • Results display download, upload, and latency values — exactly the same flow you get by searching “speed test” in Bing.
What’s verified and what remains provisional​
Verified claims
  • The UI element is present in Insider Dev and Beta builds according to preview reports and community captures.
  • The control opens Bing’s speed‑test widget in the browser rather than a local, offline diagnostic.
  • Bing’s speed‑test experience currently uses widely adopted speed‑test backends (notably Ookla/Speedtest integration in Bing/Edge experiences).
Provisional / unverifiable claims
  • Whether Microsoft will later replace the web launch with a native, system‑level speed tester or ship a dedicated local app is not confirmed. Insiders see the web‑launch behavior in previews; Microsoft has not formally published release notes describing a final implementation for general availability. Treat future behavior as subject to change.
Strengths: why this is a useful addition​
  • Immediate discoverability — a speed check is accessible where users already inspect connectivity, reducing the cognitive steps needed to triage a slow connection.
  • Consistent support workflow — support reps can direct users to a single, familiar UI location to run the same test, making remote troubleshooting faster and less error‑prone.
  • Low engineering cost — routing to Bing avoids the complexity of implementing server selection, hosting test endpoints, and maintaining a measurement backend inside Windows.
  • Leverages mature infrastructure — by pointing to Bing’s widget (which uses established engines), Microsoft benefits from existing server networks and methodologies for measuring throughput and latency.
Limitations and risks — what power users and administrators should know​
Accuracy and reproducibility​
Browser‑based tests can differ from native clients because of how the browser or the widget initiates parallel connections, respects throttling, or selects test servers. Independent reporting has already flagged discrepancies between the Bing/Edge embedded experience and native Speedtest results. For SLA verification or legal/contractual disputes with ISPs, web‑widget results should not be treated as authoritative without corroboration.
Telemetry and privacy​
Because the test runs in the browser and on web servers, it may involve network calls that log server selections, timestamps, public IP, and other metadata. Enterprises with strict telemetry or data‑exfiltration policies may need to control or block this shortcut via Group Policy/MDM or rely on internal tools instead. There’s no documented enterprise management control for the feature in early previews.
Captive portals, VPNs, and network path differences​
A browser‑launched web test can be affected by captive portal sign‑in pages, VPN routing, or DNS interception, leading to misleading results. A native, local micro‑benchmark (if it existed) could show whether the link layer and adapter are functioning independently of web reachability — something a browser widget cannot reliably do when HTTP is itself the failure point.
Enterprise manageability and governance​
Without explicit Group Policy or MDM controls (not present in the preview evidence), enterprises cannot centrally change the provider, force a private test endpoint, or disable the UI element. Relying on a browser‑hosted provider introduces operational uncertainty for regulated environments.
Practical alternatives for accurate testing​
For users or IT pros needing reproducible, auditable results, the following options remain preferable:
  • Native desktop clients: Ookla Speedtest desktop app or Fast.com app produce consistent results and can export logs.
  • Command line / scriptable tools: Speedtest CLI (Ookla) or PowerToys Run Speed Test (which now wraps Ookla’s Speedtest CLI in PowerToys) for scripted checks.
  • Controlled local testing: iperf3 to an internally hosted server for deterministic and reproducible throughput and latency measurements.
  • Router/gateway counters: verify WAN interface counters on the modem/router to cross‑check provider‑side throughput.
When accuracy matters, run at least two different tests (web widget and native client) and, where possible, test to a known internal server. This produces a more robust diagnostic picture than relying on a single click.
Suggestions Microsoft could adopt to make the feature enterprise‑ready​
The current web‑launch approach is a reasonable starting point for consumer convenience. To make it useful for IT admins and power users, Microsoft should consider the following before wide release:
  • Provider choice — allow Settings or MDM to select a default provider (Bing/Ookla, Fast.com, ISP meter, or custom internal endpoint).
  • Offline micro‑benchmark — include a lightweight local test to measure adapter throughput, basic packet loss, and link quality without relying on HTTP. This helps when DNS or HTTP is the failure mode.
  • Exportable metadata — let users export test logs with server IP, test timestamps, public IP, and raw measurement data for support tickets.
  • MDM / Group Policy controls — provide IT controls to disable the feature, lock the provider, or route tests to an enterprise proxy / internal endpoint.
  • Transparent methodology — surface server selection, single vs. multi‑threaded test mode, and any browser limitations that affect results to aid reproducibility.
These changes would let Microsoft preserve the usability win while addressing the needs of administrators and technical users who demand evidence and reproducibility.
Real‑world scenarios: how this will be used — and misused​
Good use cases​
  • Quick consumer checks: confirm whether a home connection is broadly healthy before calling ISP support.
  • Help desk triage: ask a user to run the one‑click test and report download/upload/latency numbers to speed remote troubleshooting.
  • Rapid comparison: check whether a laptop on Wi‑Fi matches another device on the same network.
Misuse and false confidence​
  • Using the web widget as hard evidence in an ISP speed dispute without cross‑validation can lead to incorrect conclusions.
  • Running the test behind a VPN or captive portal without recognizing path differences can misattribute slow speeds to the ISP when the issue is local routing.
  • Assuming the measurement is system‑level: the test only evaluates the path from the device’s browser to the web test server — it doesn’t isolate driver or link‑layer problems.
What independent reporting says about the Bing/Edge integration​
Microsoft has already embedded a similar speed‑test shortcut into Edge’s sidebar toolbox; that experience opens Bing in the panel and relies on the same underlying web test, and independent coverage noted that Edge’s sidebar test routes users to Bing and uses Ookla’s engine behind the scenes. Some reporters observed that results from the embedded experience could differ from running the native Speedtest site or client. That same arrangement appears to underpin the Windows taskbar shortcut in preview builds.
Security, privacy, and telemetry considerations (detail)​
  • The browser‑based test will expose your public IP and route test traffic to a third‑party testing server. For private networks that restrict external telemetry, this can be a compliance issue.
  • Test metadata may be logged by the test provider (e.g., server IP, timestamps, region), and organizations should evaluate whether that logging is permissible by policy.
  • In environments that require all web traffic to go through a corporate proxy or DLP, the test may produce false negatives if HTTP access is blocked or redirected.
  • Admins should test preview behavior in a controlled ring before allowing the feature in production environments.
When deploying Windows across managed fleets, administrators should consider adding test guidance to their runbooks and creating internal measurement endpoints (iperf3) for official diagnostics.
Bottom line — pragmatic assessment​
This one‑click taskbar speed test is a pragmatic, user‑facing convenience: it reduces friction for quick checks and aligns with Microsoft’s move to web‑hosted tooling for simple utilities. For everyday consumers and most help‑desk triage, the feature will be welcome and save a couple of clicks.
That said, the current implementation — a browser launch to Bing’s widget — is not a substitute for reproducible, auditable diagnostics. IT professionals, enterprise admins, and power users should treat the shortcut as a triage tool rather than definitive proof of provider compliance. To be enterprise‑grade, the feature will need provider choice, exportable metadata, offline micro‑benchmarks, and management controls.
Quick checklist for readers​
  • If you’re a home user: expect a convenient one‑click test in recent Insider builds that opens Bing in your browser for an instant check. It’s useful for quick verification but not for contract disputes.
  • If you’re IT support: treat the test as a fast triage step. Always corroborate with iperf3 or native Speedtest clients when precision matters.
  • If you’re an admin: test group policy/MDM behavior in a preview ring and prepare a fallback workflow that uses internal test endpoints for sanctioned diagnostics.
Final thoughts​
Small UX additions can have outsized practical value — placing a speed‑test control where users already look for connectivity is an ergonomics win. Microsoft’s choice to reuse the Bing/Edge web widget keeps engineering costs low and leverages proven infrastructure, but it sacrifices control and auditability. If Microsoft extends this starter approach with manageability, exportable logs, and a lightweight offline test, the taskbar speed test could become a genuinely useful diagnostic tool for both consumers and enterprise operators. Until then, it’s a welcome convenience with real limits: quick, easy, and good enough for most people, but not the final word when network accuracy and provenance are required.
Source: Gagadget.com Microsoft in Windows 11: a new network speed test right from the system tray
Microsoft is quietly testing a one‑click internet speed test in Windows 11’s system tray — a small UX convenience that opens Bing’s web‑based speed test from the network flyout and the taskbar icon’s context menu, rather than running a native in‑OS diagnostic.
Windows desktop with Bing Start page in a browser and a speed-test popup on a blue abstract wallpaper.Background / Overview​
Windows 11 has been evolving through incremental feature rollouts delivered via Insider preview channels, and recent Dev and Beta builds contain a subtle but practical addition: a Perform speed test control placed directly in the network flyout and the right‑click context menu for the network indicator. Early community captures and reporting show the control appearing next to familiar quick actions — notably the Wi‑Fi refresh control — making a basic throughput check reachable in a single click from where most users already look when connectivity seems slow.
This new control does not perform measurements locally inside the Settings app or as a built‑in OS tool. Instead, clicking the button opens the default browser and loads Bing’s internet speed test widget, which itself delegates measurement work to established speed‑test infrastructure. That practical tradeoff reduces engineering overhead for Microsoft but changes the operational profile of the feature compared with native diagnostics.
The shortcut appears in two places in Insider preview builds:
  • As a button inside the Wi‑Fi Quick Settings flyout that opens when you left‑click the network icon on the taskbar.
  • As a Perform speed test entry in the right‑click context menu for the network/system tray icon.
Screenshot captures and forum summaries show the button positioned deliberately near other connectivity quick actions to maximize discoverability for non‑technical users.
What clicking the control does​
  • Click the network icon (system tray).
  • Click the speed‑test button or select Perform speed test from the context menu.
  • Your default browser opens and loads Bing’s speed‑test page; you then start the test from the web UI.
Because the flow relies on the browser and Bing’s web widget, tests require an operational HTTP path to the test servers — in other words, if the problem prevents the browser from loading the page (DNS failure, captive portal, severe HTTP issues), the shortcut will not help.
Verification: Bing, Ookla, and the measurement backend​
Microsoft has been surfacing speed tests inside Bing and Edge for some time. Independent reporting and Microsoft’s own Bing tools page confirm a built‑in internet speed test accessible via Bing search and the Bing tools hub. The Bing speed test page is a live, web‑hosted tool that measures download, upload, and latency metrics. Multiple outlets that examined Bing and Edge integrations report that the Bing/Edge speed test uses Speedtest by Ookla as the underlying measurement engine (or delegates to Ookla’s infrastructure), which is a widely used third‑party service for internet performance measurements. Tech sites that inspected Edge’s sidebar tool and Bing’s search widget concluded the same: the browser‑embedded test redirects to Bing’s web test, which in turn uses Ookla’s proven measurement backend. Because the Windows taskbar button opens Bing’s web widget, the Windows flow inherits the same provider behavior and measurement characteristics: browser environment, chosen test server, and any provider‑side logging or telemetry. That means results may match other browser‑launched Bing tests but can differ from native Speedtest clients or other provider tools.
Putting a speed test in the network flyout is ergonomically sensible. It reduces friction for everyday users who simply want to know whether an ISP is underperforming and gives help‑desk staff a predictable place to send users for a quick triage result.
Key operational reasons for the web‑backed approach:
  • Low maintenance: Routing users to an existing Bing tool avoids embedding server infrastructure or creating OS‑level server selection logic.
  • Fast iteration: Web tools can be updated outside of the Windows servicing cadence.
  • Leverage mature engines: By delegating to established providers such as Ookla, Microsoft benefits from an existing global server footprint and proven measurement code.
These choices align with Microsoft’s pattern of surfacing web‑hosted utilities inside product UIs (Edge sidebar, Bing tools), trading local control for convenience and maintainability.
Strengths: what this brings to end users​
  • Discoverability: Non‑technical users can run a basic bandwidth/latency check without remembering a URL or downloading an app.
  • Speed: One click from the taskbar is markedly faster than opening a browser, searching for a test, and launching it manually.
  • Consistency for help desks: Support teams can standardize on a single, easily described workflow for first‑level triage.
  • Central updates: Measurement logic improvements and UI tweaks can arrive through Bing without modifying Windows.
Limitations and risks — why power users and IT will be cautious​
The shortcut’s reliance on a browser means it’s useless when the browser can’t load the test page — for example, DNS failures, captive portals, or scenarios where HTTP traffic is blocked. Native or offline diagnostics remain necessary in those cases.
Measurement variance​
Browser‑based tests can give different numbers than native clients or other providers because of:
  • Browser networking constraints (parallel connections, HTTP/2 behavior).
  • Extensions, content blockers, or background tabs that affect throughput.
  • VPNs, proxies, or corporate traffic shaping that only apply to browser traffic.
Independent analyses have observed discrepancies between embedded browser tests and the same provider’s native app; these differences can be material for high‑precision requirements.
Single‑provider default and lack of configurability​
Early preview evidence shows the feature points to Bing’s widget without a visible setting to select a different provider. Users and admins who prefer Ookla, Fast.com, TestMy.net, or internal test endpoints may find the lack of a provider choice limiting. If Microsoft does not expose provider selection or allow an enterprise override, the shortcut could create friction in managed environments.
Privacy and telemetry concerns​
A browser‑based test routes data through external servers and may record the client’s public IP, timestamps, and server selection. Organizations with data handling or privacy constraints should evaluate whether this telemetry is acceptable or whether internal testing endpoints are required. Controlled environments that force traffic through corporate proxies may produce different or misleading results if the proxy affects traffic flows.
Practical alternatives and workarounds​
For users and IT professionals who need more control, reproducibility, or offline capabilities, there are several proven alternatives:
  • Dedicated desktop/mobile clients
  • Speedtest by Ookla native apps give richer metadata and often more consistent results across runs.
  • Fast.com (Netflix) is a simple single‑provider test useful for basic downstream checks.
  • Command‑line and controlled tests
  • iperf3 to a known internal server provides reproducible, auditable throughput tests and is the recommended approach for enterprise SLA verification.
  • Local diagnostic tools
  • netsh wlan show wlanreport, ipconfig /all, ping/tracert, and Windows’ Network Troubleshooter produce locally observable evidence when the browser path is unavailable.
  • On‑desktop convenience options
  • Third‑party taskbar meters and lightweight utilities such as TrafficMonitor, NetSpeedMeter, or NetWorx give continuous, real‑time throughput readings without opening a browser.
If a quick test from the desktop without launching the browser is preferred, PowerToys users can install a third‑party SpeedTest plugin for PowerToys Run that runs tests from the keyboard launcher and returns download/upload/ping and server information without a browser window. GitHub repositories for PowerToys Run SpeedTest plugins provide releases and installation instructions.
Guidance for IT administrators and help desks​
The new taskbar shortcut is a useful triage step but should be incorporated into documented support processes rather than treated as authoritative evidence.
Recommended steps for help desks:
  • Use the taskbar speed test for rapid first triage when user complaints are vague.
  • If the web test shows degraded performance, collect corroborating evidence using:
  • iperf3 to a controlled server for reproducible throughput.
  • Native Speedtest clients for provider‑facing tests.
  • Router/modem WAN counters and historical telemetry.
  • Prepare KB entries that explain when the taskbar test is or isn’t appropriate (e.g., captive portal or TLS/HTTP failures).
  • Trial the preview behavior in a controlled Insider ring to confirm how MDM and Group Policy interact with the UI before the feature reaches production devices.
Administrators should consider building internal test endpoints where possible and provide agents with scripts to run iperf3 or extract netsh/wlanreport outputs for deeper diagnostics.
What Microsoft could — and perhaps should — add​
To make the feature more useful to power users and enterprises, these improvements would matter:
  • Provider choice: A Settings toggle to pick the default provider (Bing/Ookla, Fast.com, custom URL or internal endpoint).
  • Offline micro‑benchmark: A lightweight, local throughput test that does not require browser access, to be used when web paths are impaired.
  • Exportable metadata: Ability to export server IP, test timestamp, client public IP and raw results to support reproducibility and audits.
  • Management controls: Group Policy / MDM controls to disable the browser launch, force a provider, or route to enterprise endpoints.
  • Provenance: Clear UI language that indicates the provider and what is being measured (browser path vs. OS‑level throughput).
These features would convert the convenience shortcut into a verifiable tool for operational troubleshooting without sacrificing the easy access that makes the idea valuable.
Short practical walkthroughs​
Quick consumer check (one click)​
  • Click the network icon on the taskbar.
  • Click the speed‑test button or select Perform speed test from the right‑click menu.
  • A browser tab opens to Bing’s speed test; click Start to run the test.
Reproducible enterprise test (recommended)​
  • Run iperf3 from the client to a controlled internal test server (record test parameters).
  • Run the native Speedtest desktop client targeting a named external test server if you need ISP‑facing validation.
  • Collect netsh wlan show wlanreport, ipconfig /all, and traceroute outputs to document local conditions.
A note on accuracy, comparability, and real‑world expectations​
No single speed‑test is the absolute truth — results vary based on server selection, concurrency model, browser stack, proxying, and transient network load. Browser embedded tests are excellent for quick checks but are less suitable for contractual disputes or SLA verification without corroboration.
  • Expect small but measurable differences between browser tests and native clients.
  • Expect greater variance when VPNs, proxies, or corporate filtering are involved.
  • Use controlled tests (iperf3) when you need to demonstrate compliance against a service level.
Independent analysis of Edge’s sidebar speed test and Bing’s widget has shown that the embedded test can report different values than the native Speedtest client, underscoring the need for corroboration in formal contexts.
Final analysis — practical takeaways​
Placing a one‑click speed test inside Windows 11’s taskbar network flyout is a small but meaningful UX win for everyday users. It reduces friction for a common troubleshooting task and aligns with Microsoft’s broader design pattern of surfacing web‑hosted tools across their product ecosystem. The current implementation — a browser launch to Bing’s web widget that uses established third‑party measurement engines — is pragmatic and low cost to maintain, but it is also limited.
For most home users and front‑line support, the taskbar shortcut will be a welcome timesaver. For power users, IT professionals, and regulated environments, it is a convenient starting point that must be supplemented with reproducible, auditable testing tools and internal processes. Administrators should pilot the behavior in controlled rings, update support documentation accordingly, and prepare alternative testing paths for situations where a browser‑based test is not usable or acceptable.
Closing thoughts​
Small ergonomics changes can deliver substantial day‑to‑day benefits. The Windows 11 taskbar speed‑test shortcut is an elegant example: it places a familiar diagnostic step where users already expect to look. The real question is how Microsoft will evolve the feature between Insider preview and public roll‑out. If Microsoft adds provider choice, exportable metadata, offline micro‑benchmarks, and management controls, the taskbar button could become a productive tool for both consumers and enterprise operators. Until then, it is a fast, useful convenience — and nothing more than the first step in a sensible but still incomplete approach to delivering network diagnostics inside the operating system.
Microsoft is adding a one‑click internet speed checker directly to the Windows 11 taskbar, visible in recent Insider preview builds and implemented as a shortcut that launches Bing’s speed‑test web widget from the network icon’s context menu and Wi‑Fi quick settings.
Windows desktop showing a Bing Speed Test window overlay on a blue abstract wallpaper.Background​
Microsoft has been gradually moving lightweight utilities and troubleshooting flows out of heavy, in‑OS subsystems and into web‑backed experiences that are easy to update without a full OS servicing cycle. The built‑in taskbar speed‑test shortcut follows that exact pattern: rather than embedding a local measurement engine, Windows 11 surfaces a context menu command and a quick‑settings button that open a browser to Bing’s internet speed test. That behavior has been spotted in the Windows Insider Dev and Beta channel preview builds and documented by multiple independent observers. This is not Microsoft inventing a brand‑new measurement protocol — Bing’s speed test has existed in search and web tools for years and, in various places, delegates measurement to established backends (including integrations with third‑party measurement engines). The taskbar control is best understood as a discoverability and convenience improvement: put a single‑click path where users already go to check connectivity.
What the new taskbar speed checker actually is​
  • It appears as a “Perform speed test” entry in the right‑click context menu for the network/system tray icon.
  • It also shows up as a small speed‑test button inside the Wi‑Fi quick settings flyout (the panel you get when left‑clicking the network icon).
  • Clicking either control opens your default browser and navigates to Bing’s internet speed test page; the test itself is performed from that web page rather than as a purely local OS diagnostic.
Why Microsoft took this route​
Microsoft’s engineering tradeoff is straightforward: by linking to a web tool it can:
  • Ship the UX quickly across channels and update the measurement engine or server endpoints without pushing OS updates.
  • Reuse an existing, tested UI (the Bing widget) instead of building and maintaining a separate measurement stack inside Windows.
  • Avoid increasing the OS footprint and surface area for maintenance by delegating the heavy lifting to a web backend.
At the same time, this design choice carries implications for accuracy, offline diagnostics, and privacy that users and IT staff should understand before treating the taskbar control as a full replacement for dedicated testing tools.
How to use it (what testers are seeing now)​
  • Left‑click or right‑click the network icon in the taskbar notification area (system tray).
  • Either select Perform speed test from the right‑click context menu or tap the small speed‑test button inside the Wi‑Fi quick settings.
  • Your default browser opens and loads the Bing speed test page; click Start on the web UI to begin measuring download, upload, and latency.
This workflow is simple by design: it’s intended to be a diagnostic convenience for end users who need a quick verification of throughput without hunting down third‑party websites or apps.
Cross‑checking the claim: multiple independent confirmations​
The initial discovery and screenshots were circulated on social media and in community forums and were reported by major outlets covering Windows. Windows Central published a write‑up showing the context‑menu entry and the Wi‑Fi flyout button in preview builds. Independent forum captures and hands‑on posts reached the same conclusion: the control opens Bing’s existing web‑based speed test rather than executing a native local measurement. Those separate reports provide strong corroboration that the feature is present in Insider builds and behaves like a web shortcut. Bing’s own speed test page is available as a web tool and has been part of Microsoft’s toolkit for some time. Earlier coverage and documentation show that Bing’s speed widget has historically delegated measurement to well‑known speed‑test backends, and browser integrations (for example Microsoft Edge’s sidebar tool) have similarly opened Bing’s web widget for measurement. That history explains why the taskbar control would call the same web endpoint.
Technical analysis: accuracy, measurement methodology, and limitations​
It’s essential to distinguish between a convenience shortcut and a formal network diagnostic tool. The taskbar option is a launcher that opens a web page. That design decision imposes several practical realities:
  • The test runs over HTTP/S from the browser: if the device cannot successfully open the web page because of captive portals, DNS failures, or blocked web access, the shortcut cannot run the measurement. This limits usefulness for some connectivity failure scenarios.
  • Measurement endpoints and methodology are controlled by the web service: Bing’s widget historically relies on established backends (commonly Ookla’s Speedtest engine or similar providers) to select test servers and measure throughput. That backend selection, server proximity, and throttling behavior influence results. Users may see modest differences compared to running a dedicated native client.
  • Accuracy caveats: web‑based tests can be affected by browser throttling, background tabs, extensions, VPNs, and the OS’s network stack. Tech reporting on the Edge speed test (which uses Bing’s web widget) found that results sometimes differed from running Speedtest’s own app or dedicated command‑line tools. Expect the same here: useful for quick checks, but not authoritative for forensic diagnostics.
  • Not a substitute for device‑level metrics: the taskbar button won’t tell you the link speed negotiated by the NIC (for example 1 Gbps auto‑negotiated link) or internal LAN throughput; it measures internet path performance to public test servers. For adapter link speed, PowerShell and the Resource Monitor still provide authoritative local values.
UX, discoverability, and practical value​
For everyday users and technicians alike, the value is immediate: rather than opening a browser, typing “speed test,” and clicking the first result, the user can run a test from a place they already interact with network settings. This reduces the friction in troubleshooting intermittent problems and can rapidly confirm whether throughput falls within the expected range.
Benefits:
  • Quick access from the system tray where connectivity information is already centralized.
  • Consistency: everyone on the same Windows 11 release will be directed to the same web tool rather than using a mix of random third‑party sites.
  • Easy updates: Microsoft can change the Bing widget behavior without a Windows update, keeping the experience current.
Limitations to weigh:
  • If the browser cannot load the test page, the shortcut is useless — a problem for captive portal or DNS‑level outages.
  • It’s a web test, not a local diagnostic; it measures the external path and may give false negatives for LAN issues.
  • Potential UX inconsistency across browsers: results and rendering can vary slightly depending on the user’s default browser and installed extensions.
Privacy and telemetry considerations​
Because the measurement is performed by a web endpoint, the test necessarily exchanges data with Microsoft’s web services (and potentially third‑party measurement backends). Practical implications:
  • Your public IP and test metadata are visible to the web service; that’s how download/upload and latency measurements are computed. The web endpoint will typically log IP addresses, test timestamps, and server selection for operation and analytics.
  • Third‑party backends and integrations: reports show that Bing’s speed test has historically used external measurement engines (for example, Ookla), so data might be relayed to those services depending on the implementation. That introduces third‑party processing for measurement results.
  • Organizational policies matter: enterprises and privacy‑conscious users should treat the taskbar link like any other web request — it will be subject to an organization’s network monitoring, proxies, and corporate privacy policies. If data residency or handling of diagnostics is a concern, administrators should evaluate how the test interacts with network controls and logs.
Because Microsoft has not published a specific whitepaper or product brief for the taskbar shortcut, some specifics about telemetry and storage are not yet publicly documented; those details should be treated as provisional until Microsoft makes them explicit. Flag: telemetry handling for this specific taskbar shortcut remains partially unverifiable until Microsoft publishes clarifying documentation.
Availability, channels, and rollout expectations​
The taskbar speed‑test option has been observed in Windows Insider Dev and Beta preview builds. Public reporting suggests the feature is hidden behind preview flags and is not yet part of the general public release or tied to a specific major feature update. Microsoft’s preview cadence and past behavior mean the control could roll out slowly, be gated by a feature‑flight toggle, or be included as part of a broader cumulative feature drop. Expect a phased deployment if Microsoft follows its usual Insider → General rollout pattern. Microsoft has previously signaled that many UI/utility improvements may arrive independently of named feature updates, so the timeline for general availability is not guaranteed and could be measured in weeks to months depending on testing feedback.
How this fits with other Microsoft moves​
Microsoft has been embedding or linking to web utilities across products:
  • Edge: the browser’s sidebar toolbox has included a speed‑test option that opens Bing’s web widget. That same widget now appears to be the speed‑test target for the Windows taskbar control, showing reuse of a single web endpoint across Microsoft’s product family.
  • Bing tools: the search engine long ago added a speed‑test widget to answer “speed test” queries directly, and this new taskbar control simply funnels users to that existing asset.
The strategy is predictable: centralize the measurement frontend (Bing) and surface it from multiple client entry points (Edge, Windows taskbar). That keeps the client lightweight while concentrating the implementation and updates on a web service that Microsoft controls.
Practical recommendations for users and IT admins​
  • For a quick health check, use the taskbar shortcut — it’s the fastest way to confirm whether internet throughput is broadly within expected parameters.
  • For accurate, repeatable measurements (for SLA verification, carrier disputes, or performance baselining), prefer dedicated measurement tools:
  • Use official Speedtest clients (desktop or CLI) or direct Ookla test pages where server selection can be controlled.
  • Use command‑line and OS tools for adapter link speed and local diagnostics (PowerShell’s Get‑NetAdapter and Resource Monitor).
  • If you manage corporate networks, consider the impact of proxies and content filters. The web‑based test will follow whatever routing the browser uses; that includes corporate proxies which can distort or mask true path performance. Plan internal diagnostics that bypass proxies for sanity checks where policy allows.
  • When reporting issues to ISPs or support, provide multiple data points: a taskbar‑initiated Bing test for convenience and a dedicated Speedtest result (or server‑controlled measurement) for precision.
Risks, unknowns, and things to watch​
  • Accuracy differences: tech reviews have observed that Microsoft’s web‑hosted speed tests (as surfaced via Edge) can yield results that differ from dedicated clients. Expect similar variance with the taskbar shortcut. Don’t use a single test as definitive proof in disputes.
  • Service availability constraints: national blocks or regional restrictions can affect the availability of third‑party measurement services. For example, regulatory action has previously impacted access to Speedtest’s services in some countries; availability of specific backends may vary by region. This can change whether Bing or other endpoints are usable in certain jurisdictions. Flag: geopolitical or regulatory restrictions can make web‑based tests unreliable in specific markets.
  • Telemetry transparency: while Microsoft publishes general privacy documentation for Bing and Windows telemetry, specifics about what is collected during a taskbar‑initiated speed test (beyond normal web request metadata) have not been published in a dedicated feature brief. That gap should be closed by Microsoft to fully reassure enterprise and privacy‑conscious users. Flag: telemetry specifics for this shortcut remain partially unverifiable.
Final assessment​
The taskbar speed test is a pragmatic, low‑friction addition to Windows 11 that will benefit most users who need a quick, on‑demand check of download, upload, and latency without launching a browser and hunting for a test site. It fits within Microsoft’s larger pattern of outsourcing lightweight utilities to web services for faster iteration and shared maintenance.
However, the implementation is not a silver bullet: it’s a convenient web shortcut rather than a local diagnostic engine. For serious troubleshooting, measurement accuracy, and forensic network analysis, traditional tools and controlled measurement clients remain essential. Enterprises and privacy‑aware users should treat the taskbar control as a convenience feature and seek clarity from Microsoft on telemetry handling before adopting it as an official diagnostic tool in managed environments.
Quick reference: summary and next steps​
  • What it is: A taskbar shortcut in Windows 11 Insider builds that opens Bing’s web speed test from the network icon.
  • How it works: Right‑click the network icon or open Wi‑Fi quick settings → choose Perform speed test → browser opens → run the test on the Bing page.
  • Best for: Fast, casual verification that internet throughput is roughly as expected.
  • Not best for: Formal diagnostics, SLA verification, forensic troubleshooting — use dedicated clients or server‑controlled tests for accuracy.
As this feature moves through Insider channels toward broader release, attention should focus on Microsoft clarifying telemetry and backend details and on independent testing of accuracy across browsers and networks. For now, the taskbar speed checker is a sensible user convenience — clear, discoverable, and useful — but it should be treated as a quick check rather than the final word on network performance.
Source: Gagadget.com Windows 11 will get a built-in Internet speed checker right from the taskbar
Microsoft is quietly adding a one‑click internet speed test to Windows 11’s network menu — and while the button is a tidy UX win for quick troubleshooting, the current implementation simply opens Bing’s web speed‑test widget rather than running a native, in‑OS diagnostic, raising important questions about accuracy, telemetry, and enterprise suitability.
Isometric laptop screen showing a speed-test dashboard with a line graph and a floating menu.Background​
Microsoft continues to iterate on Windows 11 via the Insider channels, and recent Dev and Beta preview builds (notably builds 26220.6682 and 26120.6682, delivered as KB5065782 to Insiders) have revealed a handful of small-but-notable user‑facing changes. Among those discoveries are:
  • A new Perform speed test control surfaced in the network indicator: visible in the right‑click context menu for the network (system tray) icon and as a button on the Wi‑Fi quick settings flyout. Clicking it opens a browser tab and loads Bing’s speed‑test widget.
  • A revamp of the Mobile devices settings page under Bluetooth & devices that consolidates linked phone controls into the main settings surface rather than a separate “Manage mobile devices” window.
  • Rework of the Privacy and Security settings pages with clearer headings and descriptions, plus a new Background AI tasks settings area that has been reported to be unstable in early previews. These layout and copy changes are intended to improve clarity but remain in testing.
The Insider blog for the Dev channel confirms the cumulative build and describes many broader improvements and fixes, even though the granular UI discoveries above have largely been reported by preview‑build sleuths and technology outlets rather than presented as headline items by Microsoft for public release.
What’s actually changing in Windows 11 (practical view)​
Speed test: two UI entry points​
  • Right‑click the network icon in the system tray: you may see a Perform speed test entry alongside items such as Network troubleshooter and Network settings.
  • Left‑click the network icon to open the Wi‑Fi quick settings flyout: a small Speed test button appears near the Wi‑Fi refresh/quick actions area.
Clicking either control launches your default browser and navigates to Bing’s speed‑test tool, where you can run the familiar download/upload/latency measurement. In this early implementation the test is not executed by a new Windows networking subsystem — it is a browser‑backed flow that reuses Bing’s existing speed‑test experience.
Mobile devices: consolidated controls​
The Mobile devices page under Bluetooth & devices is being redesigned to list linked phones and let users toggle and manage those device‑specific settings directly from the same page instead of opening a separate management window. This aims to reduce friction and keep related settings in a single location (and aligns with Microsoft’s long‑running effort to migrate legacy Control Panel functionality into Settings). The change is visible in Insider previews and has been highlighted in community captures.
Privacy, security and the odd Background AI tasks page​
Settings pages for Privacy and Security are being reorganized into clearer sections with more descriptive text and headings to help users understand what each toggle does. Additionally, a new Background AI tasks page has appeared in early builds — it’s meant to show and control AI workloads running in the background, but testers report that the page currently crashes or is unstable in some preview builds; this appears to be a work‑in‑progress rather than a finished feature. Because this behavior is drawn from Insider reports rather than Microsoft documentation, it should be considered provisional.
Why Microsoft likely implemented the speed‑test button this way​
  • Low maintenance: routing to an existing, web‑hosted tool avoids the complexity of embedding server selection and a global test backend into core OS code. That reduces engineering and maintenance costs.
  • Faster iteration: a web tool can be updated independently of Windows servicing channels, allowing Microsoft to tweak UI and test logic without requiring an OS update.
  • Consistency across products: Microsoft already surfaces Bing’s speed‑test widget in other places (for example, Edge’s toolbox or sidebar experiences), so funneling users to the same endpoint keeps the experience consistent. Independent reporting shows Edge and Bing already reuse this same web widget.
These are sensible operational reasons for choosing a browser‑backed approach for a consumer‑targeted convenience: discoverability and convenience mattered more than building an enterprise‑grade diagnostic engine for this initial implementation.
Strengths — what Windows users gain immediately​
  • Discoverability: the network menu is exactly where most users look when connectivity is suspect. Putting a speed test there removes the friction of opening a browser and searching for “speed test.”
  • Speed: a one‑click path from the Taskbar to a measurement is faster for casual verification than manually navigating to a site.
  • Consistency for support: help‑desk staff can standardize on a common instruction (click the network icon → Perform speed test) for first‑line troubleshooting, reducing back‑and‑forth with end users.
  • Centralized updates: any improvements to the measurement widget or its server selection can be rolled out via Bing without shipping a Windows CU.
These are real, tangible benefits for the majority of home and light‑business users who need a quick sanity check rather than a forensic measurement suitable for binding SLA verification.
Risks, limitations and what power users / IT should worry about​
  • Not a native diagnostic: because the test runs in the browser, it cannot help when HTTP itself is the failure mode (captive portal, DNS poisoning, or a broken HTTPS path). If you can’t load Bing, the speed button won’t help.
  • Accuracy and reproducibility: browser‑based tests can report different values versus native clients (differences in concurrency models, socket stacks, and browser optimizations). For formal evidence, iperf3 or a native Speedtest client is still the recommended approach. Independent reporting has already noted discrepancies between embedded browser tests and dedicated clients.
  • Single provider default: early builds route to Bing’s speed‑test widget with no obvious option to change the provider. That locks users into a single test path that may not match their preferred measurement method.
  • Telemetry and privacy: tests run in the browser and hit third‑party test servers; server selection, timestamps, and your public IP will be visible to the test provider. Managed environments with strict telemetry policies need to consider whether that outbound connection is acceptable. There is no documented Group Policy/MDM control for disabling the shortcut in these early previews.
  • Enterprise suitability: the lack of exportable metadata (server IP, raw packets, precise methodology) and controllable endpoints makes the button unsuitable for SLA disputes or regulatory audits. Enterprises should continue to rely on internal test endpoints and tools that keep telemetry on‑premises.
  • Unverified test behavior: the Insider discovery model means the UI, wording, and behavior are provisional. Microsoft could change the provider, add controls, or drop the feature entirely before public release. Treat current behavior as experimental.
How the Bing/Edge/Built‑in speed test relationship works (technical clarity)​
  • Bing hosts an embedded speed‑test widget that measures download, upload, and latency and is reachable through Bing’s tools hub or by searching “speed test.” The widget has been integrated into Edge’s toolbox/sidebar and now appears to be the target for the Windows network menu shortcut.
  • Multiple outlets have reported that Bing’s widget delegates to widely used measurement technology (Speedtest by Ookla) for server selection and throughput testing. That means the Windows Taskbar shortcut, as currently implemented, funnels users to a web experience backed by mature third‑party infrastructure rather than a Microsoft‑managed OS test harness.
Because of that chain (Windows UI → Browser → Bing widget → measurement backend), the final result depends as much on the browser environment and routing as it does on local NIC and OS stack behavior.
Suggested improvements Microsoft should consider before a wide rollout​
  • Provider choice: Add a Settings option to let users pick the default provider (Bing, Ookla/Speedtest, Fast.com, an ISP meter, or a custom URL).
  • Offline micro‑benchmark: Ship a minimal local test that validates link‑layer throughput and checks for packet loss without requiring web access — useful when DNS or HTTP is the failure.
  • Exportable metadata: Allow copy/export of server IP, test timestamp, public IP, and raw results for support tickets and audits.
  • MDM/Group Policy controls: Provide an enterprise toggle to disable the web launch or force a corporate endpoint.
  • Clear provenance UI: Explicitly show which provider is running the test and whether the measurement was done in‑OS or via a web widget.
These changes would convert the UX convenience into a tool that can be trusted for serious troubleshooting and enterprise operations.
Practical advice — what to do (and what not to do) when you see these features on your machine​
  • If you are on a managed device or in an enterprise: hold off enabling Insider previews on production machines. Test in a controlled ring and update runbooks before pushing the feature more broadly.
  • For quick home checks: the Taskbar button is fine for a rapid sanity check — think “smoke test” not “forensic evidence.” Use the button to determine whether your internet is broadly functional, then follow up with native tools if you need precise numbers.
  • When accuracy matters: use a native Speedtest desktop client or iperf3 against a known internal server. Collect netsh wlan show wlanreport, ipconfig /all, ping and traceroute output to document the environment.
  • If you’re concerned about telemetry: consider routing the test traffic through a corporate proxy that can inspect/record it, or block the specific URL if policy forbids external test servers. There is no enterprise management control exposed for the button in early previews.
Deeper look: Mobile devices settings and the broader migration to Settings​
Microsoft’s longer‑term campaign to migrate legacy Control Panel functionality into the modern Settings app is visible in the Mobile devices revamp and other recent moves (keyboard and mouse property migrations, time/language relocations, etc.. Consolidating linked phone controls directly under Settings > Bluetooth & devices > Mobile devices reduces the number of windows and modal flows users must navigate, and helps surface cross‑device features such as resuming Android apps on the PC and file sharing. This is part of a consistent UX direction across Insider builds. The risk here is feature fragmentation: not all Insiders (or consumer devices) receive the same controlled feature rollouts at the same time, and some elements (like the Background AI tasks page) are still immature and may behave inconsistently. Administrators and power users should assume the experience is still experimental until Microsoft explicitly documents it in stable channel release notes.
Final analysis — what this small UX change tells us about Microsoft’s approach​
This Taskbar speed‑test button is emblematic of two simultaneous strategies:
  • A pragmatic push to improve everyday ergonomics for mainstream users by placing common tools where people already look. The discoverability and convenience are genuine wins.
  • A reliance on web‑hosted, centrally updated experiences to deliver lightweight diagnostics rather than embedding every utility in the OS. This reduces maintenance but transfers some control and telemetry to web services.
For most users the new shortcut will be a welcome time‑saver. For power users, enterprise IT, and anyone who needs reproducible evidence, the feature as tested in Insiders is insufficient — it should be treated as a fast initial triage step, not a definitive diagnostic. The feature’s current browser‑launched, Bing‑backed implementation is an efficient first pass, but its usefulness and trustworthiness will hinge on whether Microsoft adds provider choice, offline diagnostics, exportable metadata, and management controls before broad rollout.
A one‑click speed test in Windows 11’s network menu is a small change with outsized day‑to‑day value: it makes a common troubleshooting task easier and more predictable for everyday users. However, the current implementation — which opens Bing’s speed‑test widget in a browser tab — is purposely pragmatic rather than comprehensive. It prioritizes discoverability and low maintenance at the cost of reproducibility, enterprise controls, and certain offline diagnostic scenarios.
Administrators should treat the button as a convenience, not a replacement for established tools. Power users should continue to use native clients and controlled measurement endpoints when accuracy matters. And consumers can safely use the new shortcut as a fast sanity check while bearing in mind its limitations and the fact that Insider behavior remains subject to change as Microsoft iterates toward a public release.
Source: Tom's Hardware Windows 11 is getting a built-in internet speed test feature that will take you to Bing, along with multiple revamped settings pages — Latest Insider channel builds reveal prominent changes coming soon to the OS
Microsoft is quietly testing a one‑click internet speed checker directly in the Windows 11 taskbar that launches Bing’s speed‑test widget from the network menu in Insider preview builds, putting a quick diagnostic just a click away for everyday users and technicians alike.
Windows desktop showing a browser speed test with a Start test button and a floating Speed menu.Background​
Windows has long lacked a built‑in, single‑click taskbar speed meter: users who wanted a persistent view of upload/download throughput or an instant speed test typically relied on third‑party tools (NetSpeedMonitor, TrafficMonitor, DU Meter, and similar apps) or visited web services like Ookla’s Speedtest or Fast.com. That gap has driven a healthy ecosystem of lightweight apps and browser‑based solutions, and it has shaped expectations about what “native” Windows should provide when diagnosing connectivity. Microsoft has previously embedded a speed test into its web experiences: Bing and Microsoft Edge already surface a speed‑test widget (the Bing Tools / Speedtest page) that users can launch from search or the Edge sidebar. That widget uses established testing infrastructure behind the scenes, meaning Microsoft doesn’t have to rebuild measurement servers or selection logic inside the OS. The new taskbar shortcut appears to be a UI funnel to that same web‑based experience.
What Microsoft is testing (overview)​
Where the control shows up​
  • The shortcut has been discovered in Insider preview builds in two places: the right‑click context menu for the network icon in the system tray, and as a button inside the Wi‑Fi quick settings flyout (the compact network menu you get when you click the network indicator). Early captures and community reports have confirmed both placements, which match where users already look for connectivity controls.
What it does​
  • Clicking the new control does not run a built‑in, offline test inside Windows. Instead, it opens the default browser and navigates to Bing’s speed test widget, where the user then starts the actual measurement (download, upload, latency). In short: the taskbar link is a quick launcher for a web‑backed speed test rather than a local measurement engine.
Which backend powers the test​
  • The Bing/Edge speed‑test experiences surface an embedded third‑party engine — widely reported and documented as the Ookla (Speedtest) engine — for the actual network measurements. That means the test uses the same kind of server selection and throughput measurement logic you’d get from Speedtest by Ookla, albeit wrapped and presented by Bing.
Why Microsoft’s approach matters​
Convenience and troubleshooting speed​
Putting a speed‑test entry point directly in the taskbar is about reducing friction. When a device reports “No Internet” or applications behave slowly, many users click the network icon first; surfacing a speed test in that exact flow is sensible and lowers the barrier to run a quick diagnostics check. For home users and support staff this can shrink the time between noticing a problem and capturing objective speed/latency numbers.
Delivery model: web‑backed, updateable by Microsoft​
By funneling users to a web widget, Microsoft avoids shipping and servicing server‑backed measurement code inside Windows. That reduces local engineering effort and lets Microsoft (or the web partner) update server lists, measurement logic, and UI without OS servicing. However, it also places the measurement experience under the control of web services and the browser, which changes where and how updates and telemetry are collected.
No dependency on extra apps​
A built‑in taskbar shortcut eliminates the need to install third‑party speed‑meter apps for casual checks. Users who only require occasional speed tests can get a usable measurement without adding software, and enterprise help desks can direct remote users to a standard path for checking connectivity.
Important limitations and technical trade‑offs​
It opens a web page — not a native engine​
Because the control launches Bing’s web widget, several limitations follow:
  • The test requires a functioning browser and an internet route to the test servers.
  • Results may vary by browser (different HTTP stacks, parallelism, or implementation quirks can affect throughput measurements).
  • Users can’t run the test entirely offline or in a restricted environment without browser access.
Provider choice and neutrality​
Early reports show the taskbar shortcut funnels users to a single provider — the Bing widget — with no obvious option to select a different measurement service from the same UI. That makes the experience simple but provider‑centric; users who prefer Fast.com, TestMy.net, or direct ISP meters would still have to navigate elsewhere. This single‑provider funnel raises questions about choice and transparency for power users and organizations that standardize on a specific testing tool.
Measurement accuracy and browser effects​
Independent reports indicate that embedded or browser‑rendered speed tests (for example, the Edge sidebar test) can produce results that differ from running Speedtest’s standalone app or visiting Ookla’s site directly — sometimes notably so for very high throughput links. Browser network stacks, TLS offloading, caching behavior, parallel connection settings, and client device constraints all influence the observed numbers. For critical benchmarking or SLA validation, a single quick test in a browser should not be considered definitive.
Telemetry and privacy considerations​
The UI design — which routes diagnostics to a web endpoint — means some aspects of the test invocation and potentially anonymized telemetry may be handled by the web service or browser context. For privacy‑sensitive or regulated environments, directing a diagnostic to a web widget may require review: administrators will want to understand what data is transmitted (IP, selected server region, timestamps) and whether the organization’s policies permit the test endpoint. Community analyses have flagged exactly this class of trade‑offs when diagnostic flows move to web services.
How the taskbar speed test behaves in practice (Insider preview guidance)​
If your device is running an Insider Dev or Beta channel build that includes the control, the flow is straightforward:
  • Click the network icon in the taskbar to open the network flyout.
  • Either right‑click the network/system tray icon or look for the Speed test / Perform speed test button in the Wi‑Fi quick settings.
  • Click the button — your default browser will open a new tab and load the Bing speed‑test widget.
  • Start the test from the web UI to measure download, upload, and latency.
This one‑click flow is designed for convenience, but the test itself still runs in the browser and presents the standard web widget controls and server selection options (if available there).
How accurate will results be? Practical testing advice​
A fast single test is useful, but for meaningful diagnostics follow these practical steps:
  • Run the test with the device connected via Ethernet when possible to remove Wi‑Fi variability.
  • Repeat the test multiple times, at different times of day, to account for network congestion.
  • Compare results from at least two providers (for example, Bing’s widget/Open Ookla, Fast.com) to identify discrepancies.
  • Close bandwidth‑heavy background apps (cloud sync, streaming, updates) before testing.
  • For enterprise validation, run tests to a known, dedicated measurement server or use the standalone Ookla app when you need reproducible, auditable results.
These steps help isolate whether a problem is an ISP bandwidth issue, local Wi‑Fi interference, or client‑side congestion. Embedded browser tests are convenient, but they are one tool in a technician’s toolbox — not a single source of truth.
Enterprise and admin considerations​
Policy control and audibility (what we know — and what remains unverified)​
  • At time of discovery, the taskbar control is present in Insider builds and Microsoft has not published formal enterprise documentation for it. There is no public evidence (yet) that a Group Policy or MDM setting exists to disable or redirect the control. Organizations with strict telemetry rules should treat the feature as provisional until Microsoft publishes management guidance or documentation. This is an important caveat for regulated customers.
Auditability and forensic use​
  • Because the test runs in a browser and connects to web servers, capturing forensic logs for a speed test will involve browser/network logs and potentially the web provider’s server records — not a simple local Windows diagnostic trace. Enterprises that require auditable diagnostics should continue to rely on dedicated tools and documented test workflows that preserve logs locally or to a controlled server.
Strengths: why this is still a net positive for most users​
  • Accessibility: The taskbar is the first place many users go to check connectivity — surfacing a speed test there shortens the troubleshooting chain.
  • Low friction: No app to install; a single click (then Start in the web widget) gets a result.
  • Easily updated: By using a web widget Microsoft and its backend partner(s) can update the test logic and servers without shipping OS updates.
  • Standardization for support: Help desks can point inexperienced users to a consistent check that will produce usable numbers for first‑line triage.
Risks and downsides to weigh​
  • Provider lock‑in: Directing users to a single provider by default can be seen as limiting choice and could raise questions in environments that standardize on different measurement tools.
  • Accuracy variance: Browser‑based tests may under‑ or over‑report throughput compared with dedicated apps. High‑speed connections are particularly susceptible to measurement variance in browser contexts.
  • Telemetry and compliance: Web‑based diagnostics shift some telemetry responsibility outside the OS — organizations will need to verify whether the test endpoint and the data it collects meet compliance and privacy requirements.
  • False confidence: A single speed reading taken without controlling background traffic, Wi‑Fi signal quality, or server choice can lull users into the wrong conclusion about where a problem lies. Emphasizing the test as an initial triage step — not a definitive audit — is important.
Alternatives and what power users should do today​
  • For a persistent taskbar readout of real‑time throughput (not a one‑off speed test), third‑party tools remain the go‑to choice: TrafficMonitor, Net Speed Meter, DU Meter, and NetSpeedMonitor (where compatible) give real‑time upload/download counters and historical usage data. These apps are still useful for continuous monitoring and produce different data than a burst throughput test.
  • For reproducible, auditable testing — especially in enterprise environments — prefer a standalone measurement application or a scripted test to a controlled server (e.g., the standalone Speedtest app, M‑Lab tools, or ISP‑provided testing endpoints). These approaches remove browser variables and allow results to be logged for records.
What to watch next​
  • Microsoft’s rollout plan: Because the feature is currently hidden in Insider preview builds, Microsoft may refine UI text, behavior, or backend before a broad roll‑out. Keep an eye on official Windows Insider release notes and Microsoft documentation for policy controls and enterprise guidance.
  • Admin controls and privacy docs: Enterprises should look for the arrival of explicit Group Policy/MDM settings and a privacy/telemetry statement describing what data the taskbar‑launched test collects and where it’s stored. Until Microsoft publishes that, administrators should assume conservative controls are needed.
  • Measurement provider options: It’s possible Microsoft may add preferences or alternate providers in later builds, or expose a configuration setting. That would address a major source of friction for power users; watch for any UI updates in subsequent Insider builds. This remains speculative until Microsoft confirms changes.
Final analysis and recommendation​
This taskbar‑level speed test is a pragmatic feature that reflects Microsoft’s broader design choice to surface lightweight consumer diagnostics through web experiences that are easier to update than native OS tooling. For most home users and first‑line support scenarios, the convenience of a one‑click test in the network menu will be a genuine usability win. However, it is not a substitute for methodical network troubleshooting. The implementation — a browser‑launched, web‑backed widget using a third‑party measurement engine — introduces trade‑offs in accuracy, provider choice, and telemetry control. Power users, network engineers, and enterprise administrators should continue to use dedicated measurement tools, controlled endpoints, and wired test scenarios for validation and auditing. Until Microsoft publishes management controls and telemetry details, cautious deployment and clear internal guidance are the prudent path for organizations. In short: expect convenience and faster triage for everyday connectivity questions, but retain the best practices that professionals rely on for reliable, auditable network measurements.
Microsoft is quietly testing a one‑click internet speed test in Windows 11 that puts a “Perform speed test” shortcut directly in the taskbar’s network menu and Wi‑Fi quick settings — but the control simply launches Bing’s web speed‑test widget in your default browser rather than running a native, in‑OS measurement.
A futuristic holographic display shows a speed-test dashboard with a glowing 'Perform speed test' button.Background​
Windows has long lacked a single, discoverable, built‑in speed‑test shortcut in the system tray, leaving users to rely on third‑party utilities or web services such as Speedtest, Fast.com, or provider portals. Microsoft has been moving a growing number of lightweight utilities and troubleshooting flows toward web‑backed experiences that can be updated independently of OS servicing, and the new taskbar speed test fits that pattern: it funnels users to an already‑available Bing/Edge speed‑test page rather than embedding measurement infrastructure inside Windows itself. This functionality has appeared in Windows Insider preview builds (reported in recent Dev and Beta flights), and early hands‑on captures show the new entry placed where users already look when they suspect connectivity issues — the network (system tray) menu and the Wi‑Fi quick settings flyout. The preview builds tied to these discoveries include build checkpoints in the 26220.6682 and 26120.6682 family (KB5065782), according to reporting on the Insider rollouts.
What Microsoft added to Windows 11​
  • A “Perform speed test” option that appears when you right‑click the network/system tray icon in the taskbar.
  • A speed test button embedded in the Wi‑Fi quick settings flyout (the panel opened when you left‑click the network indicator).
  • The buttons act as launchers: selecting either opens your default browser and navigates to Bing’s internet speed test page.
These add‑ins are small, intentionally lightweight UX changes that prioritize discoverability and convenience for everyday users who need a quick verification of download, upload, and latency numbers without hunting for an external site or installing an app. Early reporting and community captures confirm the placement and basic behavior.
How the taskbar speed test actually works​
The launcher model​
Microsoft has chosen a funnel approach rather than embedding a measurement engine into the OS. When you invoke the new control:
  • Windows opens your default web browser.
  • The browser navigates to Bing’s Speed Test tool.
  • The web widget performs the measurement (download, upload, latency) and displays results.
That means the taskbar shortcut is effectively a convenience launcher for a web‑hosted test, not a local diagnostic that collects and stores fine‑grained telemetry in the Windows diagnostic stack.
Why Microsoft likely took this path​
  • Update agility: web‑hosted tools can adjust server endpoints, algorithms, and UI without shipping OS updates.
  • Lower OS complexity: no need to manage global test servers, server selection logic, or an embedded measurement stack in every Windows SKU.
  • Consistency across products: Bing/Edge already surface a speed‑test widget; funneling users to that same endpoint provides a uniform experience.
These are pragmatic engineering tradeoffs that favor speed of rollout and maintainability over deep local control.
Accuracy, reproducibility, and technical trade‑offs​
The launcher model introduces several technical caveats that affect accuracy, repeatability, and interpretability of results.
Browser and stack effects​
Web‑based speed tests run in the browser process and therefore inherit characteristics of the browser’s networking stack, thread scheduling, and connection parallelism. That can lead to measurable differences between a browser‑embedded test and a native client performing the same test. Results can vary by browser (Edge, Chrome, Firefox), browser extensions, and background processes.
Server selection and backend provider​
Bing’s speed test is a web tool that delegates measurements to established speed‑test backends (reports indicate the experience commonly uses Speedtest by Ookla’s infrastructure behind the scenes). The chosen test server, its geographic proximity, and its current load will influence throughput and latency figures. That’s true for virtually all public speed tests, but it’s important to remember the Windows shortcut inherits whatever provider and server‑selection choices Bing/Edge make.
Reproducibility and forensic use​
For ISPs, enterprises, or troubleshooting teams that need reproducible and auditable measurements (for SLA disputes, contractual evidence, or forensic analysis), a single web‑launched test is insufficient. Dedicated clients that support explicit server selection, test scripting (iperf/iperf3), or CLI logs are the right tools for those workflows. Treat the taskbar speed test as a rapid sanity check rather than authoritative proof.
Because the test opens a browser and calls web endpoints, telemetry and request metadata are handled by the web service (Bing) and your browser, not solely by an OS component. That introduces several privacy considerations:
  • What is logged: the web test provider may log IP addresses, timestamps, and test server identifiers as part of normal operation. The specific telemetry collected during a taskbar‑initiated test is not yet documented in a standalone Microsoft feature brief. That lack of explicit documentation is a transparency gap that should be addressed.
  • Enterprise proxies and routing: managed devices that route browser traffic through a corporate proxy will have the test run under that routing path, which can mask or alter true end‑user performance. IT teams should be aware that a browser‑based test reflects browser routing and proxy behavior.
  • Regional availability: geopolitical or regulatory constraints can affect access to certain measurement backends in some regions; web‑based tests depend on the availability of remote test servers.
Until Microsoft publishes explicit telemetry details for the taskbar‑initiated flow, privacy‑conscious users and enterprise administrators should assume the test follows normal web telemetry patterns for Bing and the user’s browser.
Enterprise and IT support implications​
For help desks and network administrators, this shortcut is a mixed blessing.
Benefits for support workflows​
  • Discoverability: it gives non‑technical users a consistent, single‑click path to run a quick speed check when they report “internet is slow,” which can speed up remote triage.
  • Standardization for first‑line support: support teams can ask users to click the same UI element and read back results, reducing back‑and‑forth.
Limitations for enterprise diagnostics​
  • Not auditable: results from a browser widget are not a substitute for server‑controlled tests when evidence is required.
  • Policy control: organizations that require in‑house diagnostics should either provide an approved native client or block the web test endpoint and instruct staff on sanctioned internal tools.
  • MDM/Group Policy: managed devices may or may not receive the Insider preview features; admins should test how Insider builds and feature flags interact with organization update policies before changing support playbooks.
Practical guidance: use the taskbar shortcut as a first step in remote troubleshooting, then escalate to iperf3, a managed Speedtest client, or internal test endpoints when deeper analysis is required.
How to use the taskbar speed test (what preview testers are seeing)​
  • Click or right‑click the network (Wi‑Fi / Ethernet) icon in the notification area of the taskbar.
  • Select Perform speed test from the right‑click context menu, or open the Wi‑Fi quick settings and click the small Speed test button.
  • Your default browser opens to Bing’s speed test page; click Start to run the test.
  • Review download, upload, and latency numbers, then corroborate with a second method if precision is required.
Note: If the page fails to load (DNS failures, captive portals, or other HTTP obstacles), the shortcut cannot run — it requires a functioning browser path to the test servers.
Alternatives and when to use them​
  • Speedtest (native client or CLI by Ookla): preferred for reproducible, server‑selectable tests and for evidence in disputes.
  • iperf3: best for controlled, point‑to‑point testing inside a network or between managed endpoints. Ideal for baselining and continuous monitoring.
  • Fast.com (Netflix) or TestMy.net: simple alternatives that may use different backends or measurement techniques; useful as corroborating checks.
For any contractual or forensic need, collect multiple measurements (different times of day, different endpoints) and include client‑side logs to provide context.
Strengths of the built‑in shortcut​
  • Low friction: eliminates search time and reduces the steps for users to run a quick test.
  • Consistent UX placement: the network icon is where people naturally look when experiencing connectivity problems, so discoverability is high.
  • Leverages mature backends: by using Bing’s web test, Microsoft can reuse established measurement infrastructure and avoid duplicating server infrastructure.
Risks and gaps to watch​
  • Transparency on telemetry is incomplete: Microsoft has not, at the time of reporting, published detailed telemetry specifics for the taskbar‑initiated flow — a reasonable ask from privacy‑conscious users and admins. Flag: telemetry specifics remain partially unverifiable until Microsoft documents them.
  • Single provider funnel: the shortcut currently routes to Bing (and whatever backend Bing uses); there’s no UI to select a different provider or internal test endpoint. This raises concerns about choice and neutrality for some users.
  • Not a replacement for rigorous diagnostics: for accuracy, repeatability, and enterprise needs, it is inferior to dedicated, controllable clients.
What Microsoft could do to make this feature enterprise‑ready​
  • Add an option to choose provider or configure an internal test endpoint through Settings or Group Policy.
  • Provide a lightweight native measurement mode that can run offline or without launching a browser for on‑lane diagnostics.
  • Publish a transparency brief that details telemetry and logging behavior for the taskbar‑initiated tests.
  • Expose exportable logs (CSV/JSON) that include test server IDs, timestamps, and raw throughput measurements for auditability.
These changes would keep the convenience of the shortcut while addressing the needs of power users, administrators, and regulated industries.
Practical recommendations for readers​
  • Use the new taskbar control as a first quick check when your apps feel sluggish or your connection seems slow.
  • If you need reproducible results or are preparing evidence for an ISP, run a dedicated Speedtest client or iperf3 and record server selections and timestamps.
  • For managed devices, validate how your update and Insider policies expose this feature and decide whether it should be enabled, blocked, or supplemented with internal tools.
What to watch next​
  • Whether Microsoft ships this feature exactly as previewed or modifies it based on Insider feedback. Early captures come from Insider builds and community sleuths, and implementation details can change prior to general availability.
  • Any Microsoft documentation or support pages that clarify telemetry, backend providers, and enterprise configuration options. The feature’s value for IT depends heavily on those details.
The new built‑in internet speed test shortcut in Windows 11 is a pragmatic, high‑utility convenience that reduces friction for quick connectivity checks by placing a single‑click launcher where users already look. It follows Microsoft’s broader pattern of surfacing web‑hosted utilities in system UI for faster iteration and lower maintenance. However, because the control opens a browser and runs Bing’s web‑hosted speed test, it inherits the limitations of web‑based measurements: browser‑dependent variability, provider‑controlled server selection, and limited forensic value for enterprise disputes. Treat the taskbar speed test as a rapid sanity check — useful, discoverable, and easy — but not a substitute for dedicated measurement tools when accuracy, reproducibility, or telemetry control matters.
Source: Windows Report Windows 11 adds built-in internet speed test shortcut
Microsoft quietly rolled a small but potentially meaningful convenience into recent Windows 11 Insider builds: a “Perform speed test” entry in the network menu and Wi‑Fi quick settings that launches an internet speed check directly from the taskbar, but crucially it opens Bing’s web‑based speed test in your default browser rather than running a native diagnostic inside the operating system. This is a low‑friction, highly discoverable addition — placed exactly where users already go to check connectivity — and it highlights a broader trend in Windows design: surfacing web‑backed utilities inside system UI rather than embedding full, locally executed measurement engines.
Windows desktop shows a speed test with 950 Mbps down and 890 Mbps up.Background / Overview​
Microsoft has been experimenting with small quality‑of‑life features in Windows 11 Insider builds, and the new taskbar speed test shortcut first appeared in the Dev and Beta channel updates distributed in mid‑September 2025 (builds in the 26220.6682 and 26120.6682 families). The option shows up in two places: the right‑click context menu for the network (system tray) icon and as a small speed‑test button inside the Wi‑Fi quick settings flyout. When selected, the control simply opens your default browser to Bing’s speed‑test page, where the familiar download/upload/latency measurements can be started with a click.
This design is consistent with Microsoft’s recent pattern of using web‑hosted tools for lightweight diagnostics and consumer utilities — think of Edge’s sidebar tools or the Bing tools hub — which can be updated independently of the OS servicing cadence. For end users, the result is immediate convenience: a one‑click path to measure throughput without hunting for a third‑party website or installing an app. For power users and IT pros, it raises questions about measurement accuracy, telemetry, control, and the tradeoffs of running tests in the browser context.
What Microsoft added (what insiders are seeing)​
  • A Perform speed test entry in the right‑click menu of the network/system tray icon.
  • A speed test button within the Wi‑Fi quick settings flyout, placed near the Wi‑Fi refresh and other quick actions.
  • The control opens the default web browser and loads the Bing speed‑test widget, where the user manually starts the test and sees download, upload and latency results.
This is a shortcut rather than a native OS tool. The UI is discoverable and placed in the natural troubleshooting flow — the exact spot users click when they notice connectivity issues.
Why it’s implemented as a web shortcut (Microsoft’s likely rationale)​
  • Web‑hosted tools allow Microsoft to update tests and logic independent of OS updates, reducing the engineering burden of maintaining a local measurement engine.
  • A single web endpoint can be reused across multiple products (Bing, Edge, system shortcuts), ensuring consistent look and function.
  • Delegating the heavy lifting to an existing provider or a web widget avoids reinventing server selection, measurement logic, and global test infrastructure.
These are pragmatic engineering choices: maintainability, reuse, and a faster path to roll out improvements.
The measurement backend and accuracy: what happens behind the button​
The path the new speed test shortcut takes is simple but important to understand:
  • User clicks Perform speed test in the taskbar or Wi‑Fi flyout.
  • Windows opens the default browser and navigates to the Bing speed‑test tool.
  • The Bing page — which has itself been integrated into Edge’s sidebar and other Microsoft UIs — runs the test using established speed‑test infrastructure and presents download/upload/latency metrics.
Important technical points and caveats:
  • The test runs in the browser context, not inside the Windows network stack or a dedicated OS service. That affects how traffic is routed and measured.
  • The web widget typically delegates to established measurement engines that operate across many public test servers. In practice, the Bing/Edge speed‑test implementation has been seen to use well‑known third‑party engines for the actual throughput tests.
  • Results gathered in a browser can differ from native client apps because of browser buffering, parallel downloads, HTTP/HTTPS behavior, and the choice of test server.
Put simply: the shortcut delivers convenience, but the measurement is influenced by the browser environment — which can produce different numbers than a native app or command‑line utility.
Practical implications and interpretation of results​
A one‑click speed check is useful for quickly establishing whether a connection is broadly healthy, but it’s critical to interpret the results in context:
  • A single short test tells you a snapshot: it shows throughput at that moment and via that path. It won’t reveal intermittent packet loss, jitter under load, or upstream congestion that only appears during sustained transfers.
  • Browser tests can be affected by:
  • Browser extensions or security features that interfere with parallel downloads.
  • HTTP/HTTPS differences versus raw TCP testing used by some native clients.
  • Local caching, proxy servers, or ISP‑run web accelerators.
  • VPNs, split tunneling, and DNS configuration that redirect traffic.
  • If the network is in a captive portal state (hotel Wi‑Fi, coffee shop), the web‑based shortcut cannot reach the test servers, so the shortcut will fail to help in those scenarios.
  • For repeatable, high‑accuracy validation (for SLA verification or detailed diagnostics), native clients or manufacturer/ISP‑recommended testing tools remain preferable.
Privacy, telemetry and control — what to watch for​
Launching a web test funnels traffic out of the OS into a web service, and that shift carries several privacy and control implications:
  • The test provider (the web service hosting the test) has visibility into the test requests and may collect telemetry related to IP addresses, timing, device headers, and test outcomes.
  • Because the test is web‑hosted, it uses standard browser networking stacks — meaning browser privacy protections and any configured data‑collection preferences affect what is shared with the endpoint.
  • Relying on a single web provider for the OS shortcut raises choice and control questions: users and organizations may prefer alternate providers (Ookla, M‑Lab, Cloudflare, SpeedOf.Me) and should be able to pick their measurement partner.
  • The good news for users is that the shortcut respects the default browser choice; picking Firefox, Chrome, or Edge will open the appropriate browser rather than forcing Edge. That preserves the user’s choice of browser for the test.
Be mindful that a web‑backed test is not air‑gapped: network diagnostics are now partially dependent on the remote provider’s policies and telemetry.
Accuracy tradeoffs: browser vs native clients​
For readers who care about measurement fidelity, here’s a quick technical comparison:
  • Browser test (web widget)
  • Pros: instant, no install, consistent UX across devices, easy to launch from system UI.
  • Cons: subject to browser throttling and buffering, affected by extensions and web proxies, may use HTTP(S) paths that differ from native clients.
  • Native client or app (desktop or command line)
  • Pros: can use raw sockets, more control over parallel streams, fewer browser‑specific artifacts, often more repeatable.
  • Cons: requires installation or a privileged run context; not as discoverable for casual users.
For troubleshooting throughput anomalies affecting applications (gaming, VPN, streaming), a native measurement tool or multiple tests across different providers is the safer approach.
Legal, antitrust and user‑choice considerations​
Adding a Microsoft‑branded shortcut that funnels users to Bing’s web tools treads close to the long history of platform vendors steering users toward their own services. From a policy standpoint:
  • Building a convenient entry point to a first‑party or closely affiliated service can raise questions about competitive neutrality in markets where multiple well‑known measurement providers exist.
  • The implementation here avoids some past criticisms because it respects the default browser rather than forcing Edge; users still control which browser opens. That technical choice reduces the risk of a high‑profile antitrust complaint compared to a design that locked the flow into a single browser.
  • Nevertheless, the broader issue of choice — allowing users to select their preferred speed‑test provider from the OS UI — remains an important usability and fairness consideration. Device manufacturers, enterprise admins, or privacy‑conscious users may rightly want a configurable list of providers or a toggle to use a local tool instead.
Expect conversations about choice and discoverability to continue as the feature moves through the Insider program.
Security and operational risks​
  • Dependence on a web service means the shortcut is unusable when the underlying HTTP/HTTPS path is broken (DNS failures, captive portals, or ISP blocks).
  • The test provider’s availability or geopolitical restrictions (regional blocks) can impact access or consistency of the feature.
  • Browser compromises, malicious extensions, or misconfigured proxies could potentially skew test results or leak additional metadata to the test endpoint.
  • For sensitive environments, organizations should evaluate whether this convenience feature aligns with their telemetry and allowed‑outbound‑services policies.
In short: convenient, but not a fit for all environments without appropriate controls.
How to use the new shortcut responsibly (practical checklist)​
  • If you see it in the taskbar: right‑click the network icon and choose Perform speed test, or open the Wi‑Fi quick settings and tap the speed‑test button.
  • Confirm the browser that opens is your default — that ensures your privacy settings and extensions are as you expect.
  • Run multiple tests at different times (3–5 runs spaced over minutes) to average out transient variance.
  • If you need high‑precision results, follow up with a native client or an ISP‑recommended test.
  • If you suspect a captive portal or DNS issue, use a browser to load a simple website first to ensure outward HTTP(S) access is available.
  • For enterprise environments, consider disabling or restricting the shortcut via group policy or deployment configuration until you validate its telemetry behavior.
Alternatives and complementary tools​
While the Windows 11 shortcut is handy, several alternatives remain important for users and administrators who need different tradeoffs:
  • Speedtest by Ookla (web and dedicated apps): widely used, large global server network, frequently the de‑facto benchmark for consumer testing.
  • Fast.com (Cloudflare / Netflix): simple, clean, and particularly useful for quick download checks.
  • M‑Lab (Measurement Lab): open, research‑oriented measurement platform used in many academic and policy studies.
  • ISP‑provided tests: some internet providers offer their own measurement pages that test path‑specific performance to their network backbones.
  • Native command‑line tools (iperf, ping, traceroute): essential for deeper diagnostics and controlled throughput testing between known endpoints.
Encourage users to treat the Windows shortcut as a first quick check, not a single definitive measurement.
What to expect from the rollout and future improvements​
  • The feature is currently visible in targeted Insider preview builds; Microsoft is using controlled feature rollout methods, meaning not every Insider will see it immediately.
  • UX details could change before public release: wording, placement, or even the ability to choose an alternate provider could be added.
  • Microsoft could expose settings to let users select alternate speed‑test providers or to choose between the web widget and a local diagnostic tool. Such changes would address choice and enterprise control concerns.
  • If feedback indicates measurement accuracy is a pain point, Microsoft may integrate server‑side options or allow more granular control over the test behavior.
Monitor Insider release notes for explicit details as the feature matures from a pipeline experiment to a general availability addition.
Bottom line: convenience with caveats​
This Windows 11 taskbar speed‑test shortcut is a pragmatic, user‑friendly convenience that reduces friction for a common troubleshooting task. It belongs in the “small but useful” category: a quick, discoverable way to capture a snapshot of network performance without launching a browser and searching for a speed‑test site.
However, because it relies on a web widget and runs in the default browser, the test inherits the limitations and characteristics of browser‑based measurement. That means potential differences from native clients, dependency on remote servers, and privacy considerations tied to the web provider. For casual users and basic triage, the new shortcut will be welcome. For reproducible diagnostics, enterprise validation, or legal/contractual SLA verification, traditional native tools and multi‑provider testing should remain the standard.
Microsoft’s placement of the control in the network menu is a thoughtful UX decision. The broader conversation now centers on choice (which provider is used and whether users can change it), accuracy (browser versus native differences), and control (enterprise telemetry and outbound service policies). If Microsoft responds to feedback by adding configurability and clearer documentation, this small feature could become a genuinely useful addition — one that balances convenience with transparency and control.
Source: BetaNews Microsoft is giving Windows 11 users an internet speed test tool
Microsoft is quietly adding a one‑click internet speed test to Windows 11’s network flyout — but for now the shortcut simply opens Bing’s web-based speed test in your default browser rather than running a fully local diagnostic.
A computer monitor displays a browser with speed test gauges and a floating settings menu.Background​
Microsoft published Insider Preview builds 26220.6682 (Dev Channel) and 26120.6682 (Beta/Release Preview lineage) as part of the KB5065782 checkpoint, and community researchers discovered a new UI affordance that places a Perform speed test control in the taskbar network contexts. The change is visible in two locations most users already consult for connectivity: the right‑click context menu on the network (system tray) icon and the Wi‑Fi quick settings flyout. Clicking either control opens the browser and navigates to Bing’s speed test widget, where standard download, upload and latency measurements are performed. This approach makes a commonly used diagnostic a single click away, without shipping a new native measurement engine inside Windows.
What Microsoft added in the Insider build (overview)​
  • A Perform speed test entry in the network icon context menu (right‑click).
  • A Speed test button inside the Wi‑Fi quick settings panel (left‑click the network icon).
  • The button launches the default browser and loads Bing’s speed‑test page rather than executing a local binary or OS‑level test.
The capability surfaced in the Dev and Beta preview streams during the KB5065782 releases and was observed by multiple community outlets and Windows Insiders, which confirms the change exists in the builds rolling to testers. Microsoft’s official Insider posts confirm the build numbers and general settings updates distributed with the release, although they do not deeply document the speed‑test shortcut itself — that detail has been uncovered by Insider testers and press.
How the new Taskbar speed test actually works​
One click, web execution​
The shortcut is an OS‑level convenience that triggers a web flow:
  • User invokes the control — either by right‑clicking the network icon and selecting Perform speed test, or by tapping the speed test button in the Wi‑Fi quick settings flyout.
  • Windows opens the system’s default browser and navigates to Bing’s Tools / Speedtest page.
  • The user taps Start inside the Bing widget and the web service runs download/upload/latency measurements and visualizes results in the browser.
Because the work is delegated to a web widget, measurement servers, test backends and the UI are managed by Bing/Edge infrastructure rather than a Windows native module. That makes shipping the feature quick and low‑risk from an engineering perspective, but it also sets clear limitations as discussed below.
Why Microsoft likely took a web‑first approach​
  • Reuse: Bing’s speed‑test widget already exists and is integrated into Microsoft’s web properties and Edge, so Windows can reuse that investment rather than rebuild server selection, geographic peering and measurement logic.
  • Surface‑level convenience: Placing a single click in the taskbar reduces friction for common troubleshooting without creating a full diagnostic product.
  • Security and maintenance: A web flow means updates to the test logic happen server side, reducing the need for frequent OS updates to iterate measurement logic.
These rationales reflect industry trade‑offs: fast deployment and simpler maintenance versus deeper control and offline capability.
Comparison: Windows shortcut vs. third‑party speed tests​
There are meaningful differences between the new Windows shortcut and established third‑party options such as Speedtest by Ookla, Fast.com, and dedicated diagnostic utilities.
  • Speed and convenience
  • Windows: One click to reach a well‑known web tool from the taskbar. Quickest path for a casual verification.
  • Third‑party: Requires visiting a site or opening an app, but still only a small number of clicks.
  • Measurement engine and server selection
  • Windows → Bing: Uses Bing’s web widget and its chosen backends; Microsoft appears to route the test through web infrastructure and may surface results from integrated partners in the widget.
  • Dedicated tools: Often provide explicit server selection, multiple test nodes, and desktop apps that can run repeated tests and scheduled monitoring for trend analysis.
  • Offline and captive‑portal scenarios
  • Windows shortcut relies on the browser being able to load the Bing widget; if your issue prevents HTTP access (DNS failure, captive portal, severe network misconfiguration), the shortcut won’t run.
  • Native diagnostic tools can sometimes run limited local checks without external web resources.
  • Privacy and telemetry
  • Using a web service means that test metadata travels to the service operator (Bing/Microsoft or its partners).
  • Third‑party services have their own privacy practices — some may anonymize data, others contribute to global speed indices. The difference is operational and governed by each provider’s privacy policy.
In short: the Windows control is optimized for speed and reachability, not for comprehensive diagnostics or network forensics.
UX and placement: why the taskbar makes sense​
Putting the speed‑test control in the network context menu and the Wi‑Fi quick settings flyout is a deliberate UX decision.
  • Discoverability: Users already check signal strength and adapter settings in these locations, so adding a single click test reduces cognitive friction.
  • Contextual relevance: Placing diagnostics next to connection controls aligns action with context — you’re already dealing with network complaints there.
  • Minimal clutter: A single extra item keeps the UI tidy while serving a common needs case: “Is my ISP giving me the speeds I pay for?”
This design follows a modern pattern where small web‑backed tools are surfaced in OS UI to offer utility without an entire native feature set.
Privacy, telemetry and data handling — what to watch for​
Any time an OS ships a convenience that sends data to an online service, users should understand what moves off‑device.
  • What data is likely transmitted
  • Test results (download/upload/latency), IP address, user agent string and possibly geolocation inferred from IP.
  • Browser cookies or account context if the user is signed into Microsoft services in the browser.
  • Who processes the data
  • The test is served by Bing’s web infrastructure; Microsoft is the likely processor unless the widget delegates to partner providers.
  • Potential implications
  • Results could be logged and aggregated for diagnostics, ISP speed indices or product improvement.
  • If corporate regulations or privacy concerns forbid external telemetry, administrators should be aware the shortcut triggers a web call.
Flag: the exact backend chain (which partner servers, retention windows, or whether results get linked to Microsoft accounts) may not be fully documented publicly; treat backend integration assumptions with caution until Microsoft publishes precise telemetry notes for the feature. Users and IT administrators should review their organization’s policies about external diagnostics before enabling such shortcuts in managed environments.
Technical limitations and failure modes​
Placing the speed test behind a web widget introduces failure scenarios that matter for troubleshooting:
  • Browser dependency: If the default browser is broken or blocked by policy, the control will fail to open the test UI.
  • HTTP path requirements: When the problem prevents browsing (captive portal, DNS issues, proxy authentication), the web widget cannot run and the quick test is effectively unavailable.
  • Measurement variance: Web‑based tests are influenced by browser behavior, background tabs/app traffic, and OS network throttling policies, which can skew results relative to dedicated native tests.
  • No local packet capture or advanced diagnostics: This shortcut won’t provide packet loss graphs, jitter heatmaps, or traceroute integration that network engineers often need.
For basic speed verification it’s a useful convenience. For root‑cause analysis or intermittent, low‑level issues you’ll still need native tools or specialized apps.
Accessibility and localization​
Insider reporting and Microsoft’s build notes show the general rollout of many settings improvements and accessibility enhancements in KB5065782, though the speed‑test affordance was not highlighted in the official blog post. The build did include broader improvements — for example, narration and interaction refinements — which indicate Microsoft continues to emphasize accessibility across Windows features. The speed test shortcut appears visually placed to be reachable from keyboard and touch surfaces, consistent with quick settings’ existing accessibility affordances.
The broader Insider changes bundled with KB5065782​
The KB5065782 checkpoint applied to Dev/Beta builds carries several other visible changes that matter to power users and IT:
  • Click to Do (Copilot) improvements including a new Copilot prompt box for Copilot+ PCs and localized tact.
  • Emoji 16.0 additions to the emoji panel.
  • Narrator improvements for document reading, footnote navigation and list handling.
  • Reinstatement of Advanced Settings to the Settings app with some options temporarily removed.
  • Mobile devices page under Bluetooth settings has been rearranged to surface linked phones more prominently.
  • A placeholder “background AI tasks” settings area was observed but not yet functional in the preview.
These changes illustrate the release’s mix: some user‑facing conveniences, accessibility and AI/UWP feature experiments, and a small set of quality‑of‑life adjustments.
What this means for consumers and IT teams​
For casual users​
  • Benefit: Faster, frictionless way to verify whether slow performance is your home network or a particular website or app.
  • Limitation: It’s a convenience, not a troubleshooting toolkit — if the test fails to load, it may simply confirm a web connectivity issue rather than diagnose the cause.
For power users and network pros​
  • Benefit: Quick sanity checks are now a single click from the taskbar, which is useful when validating an ISP claim or confirming that a router reboot changed throughput.
  • Limitation: Professionals will still prefer dedicated tools (Wireshark, iperf, Speedtest Desktop) for reproducible, instrumented testing with loggable results and server control.
For IT administrators​
  • Awareness: The feature triggers outbound web traffic to Bing’s test endpoints. In managed networks with strict egress or telemetry policies, administrators should consider whether surfacing external diagnostics via the OS is acceptable.
  • Policy controls: Enterprises should examine group policy and MDM settings that can limit or hide quick settings entries, or restrict default browser behavior in corporate environments.
Security considerations​
The taskbar shortcut is low risk by design because it simply launches a browser page. However:
  • Phishing risk: Any UI that opens the browser must be resilient to potential spoofing if a malicious site attempts to mimic the speed test UI; browsers and Microsoft’s widget hosting need to ensure integrity of the served content.
  • Redirection and proxies: Corporate proxies or security middleboxes might intercept or modify the test traffic, producing inaccurate measurements or exposing the test to inspection.
  • Extension interference: Browser extensions (ad blockers, privacy tools) could alter the test execution or results. Users should be aware extensions can affect web‑based diagnostics.
Overall, the security surface is similar to opening any web‑based utility; hardening comes from browser security posture and admin controls.
Is this the start of more web‑backed OS tools?​
Microsoft has demonstrated a pattern of embedding web‑hosted utilities into Windows surfaces for convenience — think Edge/Chrome sidebars, web widgets in system UI, or Copilot integrations. The speed test is consistent with that strategy: provide lightweight usefulness with minimal OS expansion.
Advantages of this approach:
  • Rapid feature iteration via server updates.
  • Reduced OS size and maintenance surface.
  • Cross‑platform parity for services available on web and in browser shells.
Drawbacks:
  • Dependence on external HTTP/S paths and web infrastructure.
  • Less control over measurement methodology and reproducibility.
  • Fragmented user expectations about what “built‑in” means when functionality requires an internet round trip.
Expect Microsoft to continue surface‑level web utilities where they can deliver value with little OS footprint, while reserving native subsystems for features that demand offline or deep system integration.
Practical guidance: how to use it (and when to use other tools)​
  • When to use the Windows shortcut
  • Quick verification that an internet link is delivering expected download/upload speeds.
  • A fast check after a router reboot or ISP ticket to confirm service status.
  • When to use a dedicated tool instead
  • If you need scheduled testing, historical logs, server selection, or traceroute/packet capture.
  • When diagnosing intermittent packet loss, jitter in VoIP/video calls, or complex LAN/WAN issues.
  • Troubleshooting tips
  • Disable browser extensions or use an incognito/private window if you suspect extension interference.
  • If the shortcut fails to open the test page, try opening the browser manually and visiting the speed test URL to observe error messages (DNS failure, captive portal, proxy auth prompt).
Caveats and things Microsoft should clarify​
  • Telemetry and retention: Microsoft should publish clear notes on what telemetry is generated by the Bing speed test and whether results are linked to the user’s Microsoft account or stored for performance indexing.
  • Offline/local diagnostic fallback: A simple offline test (ping to gateway, loopback, DNS resolution checks) integrated into the network flyout would make the feature more resilient for cases when web access is impaired.
  • Domain and partner disclosures: If the Bing widget delegates to partner backends (for example, licensing a measurement engine), Microsoft should disclose this so power users and enterprise teams can properly understand measurement provenance. Some reporting has suggested such delegation exists, but the exact partner chain is not exhaustively documented publicly and should be treated as provisional until confirmed.
Rollout expectations and what to watch​
The feature is visible in Insider Dev and Beta preview builds distributed around September 12, 2025, as part of KB5065782 checkpoints for 25H2/24H2 branches. As with many Insider features, the UI, phrasing and behavior may change before a public rollout. Microsoft often performs gradual rollouts and A/B tests, so not every Insider (and certainly not every general release user) will see the change at once. Watch for these milestones:
  • Public documentation or a Windows blog post explicitly describing the speed‑test shortcut and its telemetry behavior.
  • A staged rollout through the Windows Update channels to general consumers, accompanied by settings or policy controls for enterprise environments.
  • Potential expansion into a native diagnostic option if Insiders and enterprise customers request an offline/local fallback.
The new one‑click internet speed test appearing in Windows 11 Insider builds is a pragmatic, low‑friction convenience that modernizes a frequent user task: checking whether the internet connection is performing at expected speeds. By funneling users to Bing’s web widget, Microsoft ships the experience quickly and with minimal OS changes, but that choice also limits the feature’s usefulness in offline or captive‑portal failure modes and leaves questions about telemetry and backend specifics that deserve clarification.
For everyday users the change will likely be a welcome timesaver. For network professionals and privacy‑sensitive IT environments, it is a convenience that complements but does not replace specialized native tools and policies. As Microsoft tests and iterates this capability in the Insider program, look for clearer telemetry disclosures and potential policy controls before the feature reaches broad production channels.
Source: eTeknix Windows 11 Will Soon Let You Test Internet Speed Without Third-Party Apps
Microsoft has quietly added a one‑click internet speed test to recent Windows 11 Insider builds — a seemingly helpful convenience that, upon inspection, is not a native diagnostic at all but a launcher that opens Bing’s web‑based speed‑test widget in the default browser.
A modern monitor displays a network speed test UI with a circular gauge and progress graphs.Background​
Windows has long left quick throughput checks to third‑party utilities and websites: Speedtest, Fast.com, and lightweight taskbar monitors filled a gap for users who wanted instant visibility into download, upload, or latency numbers. Microsoft’s recent Insider flights introduce a small but ergonomically meaningful shortcut inside the taskbar network contexts: a Perform speed test entry in the network icon’s right‑click menu and a dedicated speed‑test button inside the Wi‑Fi quick settings flyout. Clicking either control opens the default browser and loads Bing’s speed‑test page for an immediate measurement.
This approach follows a broader Microsoft pattern: surface lightweight utilities via web‑backed experiences rather than embedding full native subsystems inside the operating system. The tradeoff is clear — rapid iteration and smaller OS footprint in exchange for reliance on browser behavior, web backends, and the telemetry those services collect.
What Microsoft actually added​
Where the control appears​
  • A Perform speed test entry in the right‑click context menu for the network/system tray icon.
  • A small Speed test button inside the Wi‑Fi quick settings flyout (the panel that opens when you left‑click the network icon).
Both placements are deliberately chosen for discoverability: they sit where users first look when connectivity problems occur. Early captures and Insider reports confirm the control’s presence in Dev and Beta channel builds.
How it behaves​
  • Selecting the control opens the default browser and navigates to Bing’s speed‑test widget.
  • The measurement (download, upload, latency) runs from the web page — the OS does not execute a local measurement engine or store detailed, exportable telemetry as part of the Windows diagnostic stack.
  • Because it’s a web tool, behavior can vary with browser, extensions, proxies, and corporate filters.
Which backend powers the test (what we know and what remains provisional)​
Multiple reports indicate that Bing’s speed widget delegates the actual measurement work to an established measurement engine (widely reported as Speedtest by Ookla). That delegation is visible across Microsoft’s web and Edge tool integrations, but the exact partner chain and backend disclosures remain incompletely documented by Microsoft in relation to the taskbar launch. Treat the claim of specific backend providers as plausible and likely, but still partially unverified until Microsoft publishes an explicit feature brief.
Why Microsoft chose a web‑backed launcher​
Microsoft’s engineering rationale for funneling a taskbar action to a web widget is pragmatic:
  • Update agility: Web‑hosted measurement UIs and server lists can be updated independently of Windows servicing cycles.
  • Lower OS complexity: No need to ship, test, and maintain a local measurement engine and global server‑selection logic across Windows SKUs.
  • Consistent cross‑device experience: The same Bing widget can be surfaced from multiple entry points (Edge, Windows taskbar, Bing search) so improvements benefit all platforms at once.
  • Reduced footprint: Lightweight UX changes keep the OS lean and move heavy lifting to server infrastructure the company controls.
For everyday consumers who want a quick “is my ISP working?” check, this is a clear usability win: the barrier between noticing that an app is slow and getting objective numbers is now shorter.
Strengths — what’s good about the taskbar speed test​
  • Discoverability: Putting the test where users already go to inspect connectivity reduces friction and accelerates first‑line triage.
  • Zero‑install convenience: No extra app to remember or install; a single click brings the test up for casual checks.
  • Operational agility for Microsoft: Server endpoint updates or UI changes can be made server‑side without shipping OS updates.
  • Consistency across experiences: The same Bing tool is already available in other Microsoft surfaces, so users get a familiar test UI.
These strengths make the feature a pragmatic addition for non‑technical users and help desks that need a simple, common step to ask customers to run.
Limitations and risks — what the taskbar speed test is not​
1) It is not a native diagnostic​
Because the control launches a web page, it does not help when the very failure prevents the browser from loading pages (captive portals, DNS outages, or severe HTTP path failures). In those offline or HTTP‑broken scenarios, a native offline micro‑benchmark (e.g., link‑speed checks, packet capture to the gateway) would be far more useful. The current implementation is therefore a convenience rather than a full diagnostic replacement.
2) Measurement variance and reproducibility concerns​
Web‑based speed tests are influenced by browser HTTP stacks, connection parallelism, TLS negotiation behavior, and extensions. Those variables can produce different throughput numbers compared with dedicated clients or controlled, server‑selected tests. For dispute‑level evidence (ISP SLAs, regulated reporting), relying on a single browser‑based result is risky. Use dedicated clients or scripted tests (iperf3, Speedtest CLI) for reproducible, auditable measurements.
3) Provider choice and vendor neutrality​
Current Insider builds funnel users to a single provider (Bing’s widget). That removes user choice from the shortcut and may irritate those who prefer alternate measurement services or who distrust a single vendor’s metrics. Without a settings option to select a different test provider, the experience favors Microsoft’s web property rather than offering an agnostic tool.
4) Telemetry, privacy, and corporate policy implications​
Because tests run in the browser and hit web endpoints, telemetry is subject to Bing/Edge privacy policies and any server‑side logging at the measurement provider. Microsoft has not yet published a dedicated telemetry brief describing exactly what is collected when the taskbar‑launched test runs (for example, whether results are tied to Microsoft accounts or stored for indexing). Enterprises and privacy‑conscious users should treat telemetry specifics as partially unverifiable until Microsoft clarifies them.
5) Corporate environments, proxies, and management controls​
In managed networks that enforce proxies, content filters, or captive portals, a browser‑based test can be misleading: proxies may terminate or cache content, masking the actual ISP path performance. There is also no guaranteed Group Policy / MDM control available yet to disable or redirect the taskbar entry, so administrators should proactively test how Insider policies expose or hide the feature in their environment.
6) Regional and regulatory constraints​
Web services and certain backends can be blocked or restricted in specific countries for regulatory or contractual reasons. That could make the Bing widget or its delegated backends unavailable in some regions, reducing the taskbar feature’s utility for affected users.
How this compares to other tools (what to use when)​
Quick checks (use the taskbar shortcut)​
  • Fast sanity checks after a router reboot.
  • Quick verification for non‑technical users when apps feel slow.
  • First step in triage for help‑desk workflows.
Repeatable / audited measurements (use dedicated tools)​
  • Use Speedtest CLI or the Speedtest desktop app for consistent server selection and CLI logging.
  • Run iperf3 between controlled endpoints for network engineering baselining.
  • Capture diagnostics with packet captures, traceroute, and router/gateway statistics for forensic analysis.
Local adapter and link checks (use native OS tools)​
  • PowerShell: Get‑NetAdapter, Get‑NetIPConfiguration for link speed and configuration.
  • Resource Monitor / Task Manager for per‑process network usage.
  • netsh wlan show wlanreport for Wi‑Fi diagnostics.
The taskbar launcher is best considered the top of a layered troubleshooting workflow — a convenient starting point, not the end.
Recommended workflows for different audiences​
For home users (simple, three‑step flow)​
  • Click the network icon → choose Perform speed test → run the Bing test for a quick check.
  • If numbers are far below expectations, reboot the router and run the test again.
  • If the problem persists, escalate to your ISP with: a) current Bing test screenshot, and b) a second test from Speedtest.net (or provider portal) for corroboration.
For IT support staff (triage + validation)​
  • Ask the user to run the taskbar speed test for an immediate sanity check.
  • If numbers appear inconsistent, request a Speedtest CLI run or an iperf3 test against a known internal endpoint.
  • Collect system logs: netstat, ipconfig /all, PowerShell Get‑NetAdapter output, and any proxy configuration details.
  • Consider corporate proxy influence; run a bypass test where policy allows.
For enterprise administrators (policy and governance)​
  • Evaluate Insider builds in a test ring to determine whether the taskbar shortcut is exposed under your update and policy settings.
  • Decide whether to block web‑backed testing via MDM/Group Policy or to publish an internal, sanctioned testing endpoint and educate users on trusted workflows.
  • Demand clarity from Microsoft on telemetry and retention before adopting any taskbar‑initiated test as part of official troubleshooting processes.
What Microsoft should do next (practical improvements)​
  • Offer a provider selection setting so users and admins can choose Speedtest, Fast.com, TestMy.net, or internal endpoints. This would restore user choice while maintaining the shortcut convenience.
  • Add an offline micro‑benchmark fallback that runs a local link‑speed and packet‑loss check when HTTP/S paths are broken. That makes the feature useful in captive‑portal or DNS failure scenarios.
  • Expose exportable metadata (CSV/JSON) with server IDs, timestamps, and raw throughput samples so power users and engineers can reproduce and audit tests.
  • Publish a clear telemetry statement describing what the taskbar‑launched test collects, whether results are stored, and how they might be correlated to identities or devices. Enterprises need this to make informed deployment decisions.
  • Provide MDM / Group Policy controls to allow organizations to disable the web launch, redirect the test to an enterprise endpoint, or require tests to bypass proxies where policy permits.
These changes would bridge the convenience of the current model with the auditability and governance enterprises require.
Practical caveats to call out (verifiability and nuance)​
  • The presence of the shortcut in Insider builds is confirmed by multiple hands‑on reports, but as with all Insider features, the UI and behavior can change before a broad public rollout. Expect wording, placement, and backend choices to evolve.
  • Claims about the exact backend provider (for example, explicit Ookla involvement) are supported by multiple reports but not fully documented in a Microsoft feature brief tied to the taskbar control; treat those specifics as likely but not definitively verified until Microsoft issues official notes.
  • Telemetry specifics remain unclear. While Bing/Edge have published privacy docs generally, the granular telemetry produced during a taskbar‑initiated speed test — and how long results are retained — has not been published in a dedicated disclosure at the time of the Insider reports. Exercise caution in environments requiring strict privacy controls.
The user impact: practical takeaways​
  • For the typical home user, the taskbar speed test is a meaningful quality‑of‑life improvement: it reduces friction and helps answer “is the internet slow or is the app broken?” faster than before.
  • For power users, network engineers, and enterprises, the shortcut is a convenience but not a substitute for controlled measurement tools. Accurate, reproducible testing still requires dedicated clients, server selection control, and captureable logs.
  • Administrators should treat the feature as a UX experiment until Microsoft publishes explicit telemetry and management details; plan for either neutralizing the web launch via policy or providing an enterprise alternative.
Final assessment​
The taskbar speed test is a tidy, consumer‑friendly addition to Windows 11 that solves a real, everyday pain point: making a speed test discoverable and one click away. However, the implementation choice — a browser‑launched Bing widget — shapes the feature’s utility and limits. It favors rapid deployment, low maintenance, and cross‑platform parity at the cost of offline usefulness, reproducibility, and enterprise manageability. Until Microsoft adds provider choice, offline fallbacks, exportable logs, and clear telemetry disclosures, treat the taskbar entry as a handy quick check rather than a definitive diagnostic instrument.
Quick checklist for readers​
  • If you want a fast check: use the taskbar shortcut and accept the results as a quick sanity test.
  • If you need evidence for an ISP dispute: run a dedicated Speedtest client or iperf3 and record server selection and timestamps.
  • If you manage corporate devices: test how Insider policies expose the feature, and await Microsoft’s telemetry and policy guidance before standardizing the taskbar test in support procedures.
The feature is a helpful UX nudge in the right direction — fast, discoverable, and sensible for everyday users — but it must be treated as a convenience built on web infrastructure rather than a replacement for robust, auditable network tools.
Source: Windows Central Windows 11’s new speed test sounds useful — until you see it’s just Bing
Source: TechSpot Microsoft adds Bing's internet speed test to Windows 11 preview
