cgrim29588
- Joined
- Mar 27, 2010
- Messages
- 224
- Thread Author
- #1
Use netstumbler to check your channel used and for any other Wireless Access Points using the same.
Place your wireless router centrally and on an upper floor, If you are on a single floor place it as high as possible maybe on top of a piece of furniture.
Position your wireless router as far away as possible from devices that can cause interference with the Wi-Fi signal this includes microwave ovens, cordless phones, intercom systems, baby monitors and halogen lights.
Always change the channel used on your wireless router. Most people never change this and it results in many routers using the same channels. If you have other wireless router signals in your area, change the channel to reduce the chance that you are using the same channel as another Wi-Fi router in your area.
Try to place the wireless router in a location that minimizes the number of walls and hard surfaces (fish tanks, windows, mirrors, metal surfaces) that might interfere with the signal path before it reaches your computer.
Take a look at this useful guide at Link Removed due to 404 Error
Check your router is using the latest firmware.
let us know how it goes
1) My router is on top of my dads desk in his room since I only live in a 1 story house.
2) Would TV's cause interference? My router is positioned close to a TV.
3) How do I change the channel used by my router? I have a Linksys router.
4) I'll try moving the router to minimize of wall and hard surfices that might cuase interference
5) Thanks for the link and I'll make sure the fireware is up to date, but how do I check it and update it as needed?
2) yes
3) access your router from your web browser by typing 192.168.1.1 and save as a bookmark in your browser, then if it's still using default settings username:admin password:admin , when logged in your firmware version should be top right of the login page ? Navigate to your wireless settings page and you should be able to change the channel ?
while your in there change your username and password and make sure you make a note of them ?
5) see bullet point 3
can you please post a screenshot of your netstumbler output ?
Unable to connect
Firefox can't establish a connection to the server at 192.168.1.1.
Thanks I found the default IP address.
There are times when I have a good signal and times when I have a bad signal.
