shadows
Hi there Windowsforum
It's getting a monthly habit to come here to ask for help now,
Lately I have been having problems with my DNS. where it disconnects me from the router.
I run with netcable on my desktop PC, since our provider has abit unstable wi-fi connection, and its been lately I've gotten these funky errors which I do not understand quite what I have done wrong. And tried pretty much every solution now to this issue.
My provider says its my PC that is having some issues, which I can say I don't think its my computer that is doing anything wrong.
They adviced me to do a complete reset of my router, which I did, that never worked, I stopped calling in to give them the information of the problem, because they keep saying I have to reset my router, I have done that 5 times by now in a week now.
For the info: My girlfriends phone / laptop, my phone, our PS3 connects without any issues. And thats through wi-fi connection.
The msg I get and this has been taken out from Event viewer windows 7
The client was unable to validate the following as active DNS server(s) that can service this client. The server(s) may be temporarily unavailable, or may be incorrectly configured. 193.162.153.164 < (my own IP)
The client was unable to validate the following as active DNS server(s) that can service this client. The server(s) may be temporarily unavailable, or may be incorrectly configured. 208.67.222.222 Name resolution for the name dns.msftncsi.com timed out after none of the configured DNS servers responded.
What shall I do to fix this problem?
I was thinking of getting a new networkscard and see if that helps,but I don't know what to do anyways.
Best Regards René
I might have solved my problem now.
Doing the flushdns command have worked o_O
I have no random disconnections nor when I start my pc up. I still run the wireshark in the background to keep an eye on things.
shadows
It may be worth noting that in your ipconfig listing your router was set up for DHCP to run on a 24 hour lease which would correspond with one day good running before the problem recurred. It would be worth checking your IP config parameters again to see if anything has reverted on the renewal of your IP assignment lease.
Can you explain that in a way that I can follow up what to do?
patcooke
Microsoft MVP
Microsoft MVP
Sorry. DHCP stands for Dynamic Host Configuration Protocol. It runs and your router and "dynamicall" assigns IP addresses without you having to set them manually. The DHCP assignments are renewed at an interval known as the "lease" in your ipconfig and in your case it shows this period as being 24 hours - you can check this by looking at the output for your ipconfig command.
So run the ipconfig command as you did earlier and look at the line showing DNS Servers. If they are showing 192.168.0.1 and 8.8.8.8 then they are ok. If they have reverted to something alse please tell us what they are.
patcooke
Microsoft MVP
Microsoft MVP
It's worth trying a change to your DHCP lease - the exact method and options vary from one router to another but your user guide should have a section on setting lease times - you should be able to set it to last infinitely.
shadows
Patcooke, I appreciate your help for this. It have been a very long learning process for me and I'm glad that I can get help you.
I will try look up on this DHCP, and call my internet provider monday morning, so I can have a little chat with them about this IP change.
I do have a question regarding this, would it matter if I made a complete format /boot by reinstalling windows 7? Or would it probably stay like this problem I'm having?
shadows
Also I can see what you mean by the DHCP how to change it, like in here >
An image from 'DNS connection problems'. Guide to change DHCP lease time to 24 hours via router LAN settings page.
But how many hours should I set the time on to renew leased time?
patcooke
Microsoft MVP
Microsoft MVP
As a trial it's worth setting it to say 7 days - the previous trial seemd good for about 1 day when it was set to 24 hours . . .
shadows
A update of this situation.
I managed to enter my router sittings and changed the leased time to 7 days.
I also had a talk with my provider over the phone, and they said that they will shift my routersittings into another channel, so I don't have to bother getting this problem once again. Though I have my doubts about it, because right after the router got restarted from their system, it took 10 min before the router was up for the new configs (channel), then I noticed my pc kept on giving me DNS not working problem again.
I can see we have done pretty much everything to solve this problem, and I kinda got to that point where I do think about that new netcard right now.
Neemobeer
Windows Forum Team
When you have the DNS failure can you re-run my script, but right click the script and select 'Run As Administrator' and upload the log
Neemobeer
Windows Forum Team
I'm more inclined to say it's a problem with the router than the NIC on the system. Running the script during the failure may highlight that. Also do you have any other devices on your network and do they work when you have the DNS issue on your system?
shadows
The other devices I have is 2 phones connected through wi-fi, PS3 that is also on wi-fi, and a laptop when we use it on wi-fi, and they never go off as my desktop.
Neemobeer
Windows Forum Team
Alright so probably not the router. Have you tried a different port on the router and a different cable? They can go bad as well.
shadows
all 4 ports I have tried switching.
A friend of mine said, I could try use a switch hub to see if it does the same.
