shadows
Hi there Windowsforum
It's getting a monthly habit to come here to ask for help now,
Lately I have been having problems with my DNS. where it disconnects me from the router.
I run with netcable on my desktop PC, since our provider has abit unstable wi-fi connection, and its been lately I've gotten these funky errors which I do not understand quite what I have done wrong. And tried pretty much every solution now to this issue.
My provider says its my PC that is having some issues, which I can say I don't think its my computer that is doing anything wrong.
They adviced me to do a complete reset of my router, which I did, that never worked, I stopped calling in to give them the information of the problem, because they keep saying I have to reset my router, I have done that 5 times by now in a week now.
For the info: My girlfriends phone / laptop, my phone, our PS3 connects without any issues. And thats through wi-fi connection.
The msg I get and this has been taken out from Event viewer windows 7
The client was unable to validate the following as active DNS server(s) that can service this client. The server(s) may be temporarily unavailable, or may be incorrectly configured. 193.162.153.164 < (my own IP)
The client was unable to validate the following as active DNS server(s) that can service this client. The server(s) may be temporarily unavailable, or may be incorrectly configured. 208.67.222.222 Name resolution for the name dns.msftncsi.com timed out after none of the configured DNS servers responded.
What shall I do to fix this problem?
I was thinking of getting a new networkscard and see if that helps,but I don't know what to do anyways.
Best Regards René
I might have solved my problem now.
Doing the flushdns command have worked o_O
I have no random disconnections nor when I start my pc up. I still run the wireshark in the background to keep an eye on things.
Neemobeer
Windows Forum Team
This would be your issue. Something is corrupting your ARP table.
Could be malware, faulty proxy, or loadblanacer or arp cache poisoning.
Interface: 192.168.0.13 --- 0xa
Internet Address Physical Address Type
0.0.0.0 00-00-00-00-00-00 invalid
8.8.8.8 00-00-00-00-00-00 invalid
192.168.0.1 f8-ab-05-65-ab-96 dynamic
192.168.0.255 ff-ff-ff-ff-ff-ff static
192.228.79.201 00-00-00-00-00-00 invalid
224.0.0.22 01-00-5e-00-00-16 static
224.0.0.251 01-00-5e-00-00-fb static
224.0.0.252 01-00-5e-00-00-fc static
255.255.255.255 ff-ff-ff-ff-ff-ff static
A temp fix would be to create a file, something like arp-clear.bat on your desktop. The only command in the file should be
arp -d *
When you have the issue right click the batch file and select 'Run As Administrator'
TRACKING THIS DOWN
You may want to download wireshark Wireshark · Download
  • Run wireshark
  • Select your interface, in this case 'Local Area Connection'
  • In the 'Apply a display filter..' box type arp and press enter
  • Leave the computer alone and check every now and then to see if it's broken. If it is hit the red square then file > 'Export specific packets'
  • Make sure down in the 'Packet range' Displayed is selected
  • Zip and pm me the capture file
shadows
When you say if it hits the red square, is this you mean?
An image from 'DNS connection problems'. Wireshark network traffic capture window with various TCP/IP protocol packets displayed.
Neemobeer
Windows Forum Team
Your filter isn't applied you need to click where it says arp and press enter. The red square is below where it says file
Neemobeer
Windows Forum Team
arp won't show red, that's a TCP RST. You'll just need to capture arp until it breaks again.
shadows
Shall I run the program when I get the DNS connection error?
or just let it run like I have done now.
shadows
Good morning Neemobeer
There were no disconnection all night long. I runned the program as you told me to do.. i stopped recording at 03:30.
After that time I tried out the ipconfig /flushdns command instead just to see what will happen. I can first turn on my pc later on today and see if something has changed. If it doesn't work, I will start a malware scan of my harddrive.
I will give you an update this evening (Europe time)
shadows
Update: I just turned on pc about my situation.
After doing the flushdns command yesterday, my pc reconnects, first I could see that yellow triangel on the left buttom screen, and I thought it wouldn't log on, after a couple of seconds it went online. But I still have my doubts. I will perform a malware scan soon and give an update, also I will run the WireShark in the background to be 100% sure.
Update: No virus / malware found on my pc
shadows
shadows
Its been almost a week now. And I can say everything is working now.
I advice that next time you guys are helping, try give them the solution with "Flushdns", it helped for me :D
And ofc. your help was as always the best. Thank you once again for the great work and support.
Neemobeer
Windows Forum Team
That may have helped, but the local dns cache should expire on it's own and refresh. I believe the corrupt arp table was the fix for this situation.
